Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
John deere tractor won't stay running
Starts, bogs down then dies/
    Problem Solver:
  • 9 Answers
Its using up the gas in the carb then it stalls. take the carb off and clean it and make sure the float in the bulb of the carb isnt sticking closed.
Posted on Jun 22, 2009
I have similar problem - and have been given the following advice: use premium fuel (91 octane or put in octane boost to regular gas) replace distributor cap, rotor, wires, and spark plugs (this is a common issue for this tractor) It always seems like a fuel issue but works well for a spell after replacing ignition parts. thoughts?
Posted on Dec 09, 2009
John Deere 214 with Kohler K321
Check carby is not to rich,"mixture screw" check for fuel blockage on fuel tap.
Sep 27, 2016 | John Deere Garden
I have a john deere 345 tractor starts fine but bogs down after I engage the mower and wont stay running
Although not a riding mower, when mine was doing that, dis-assembled, cleaned and then re-assembled the carburetor. Now doesn't shut off when engaging the mower. Also, if you left gas in the mower over the winter, try some of the additive, but that didn't work for mine.
Jun 14, 2014 | John Deere 420,1020,2010,2020,2510,2520...
Lawn mowers
clean air filter, clean out carby bowl and main jet
Jun 03, 2013 | Garden
John Deere L120 runs for 15 minutes, bogs down and dies. A few minutes later starts right up, runs for a few minutes and dies again. I have changed the fuel filter, all fuel lines, air filter, cleaned the...
Is this an older machine ? If so try finding the points its usualy on the front lower part of the engine behind the cover, if you see that then it needs its condensor replaced, lookes like a round battery.
If this is newer or you can also try changing the spark plug sometimes they heat up and fail.
Sep 17, 2012 | John Deere Garden
A,b,g Tractor Carburetor Float Dltx10: i had my john deere riding mower running then shut...
My John Deere only starts with a hammer. I have the Kawasaki engine and it is famous for bad starters, so I carry a hammer and tap on the bolt when I want to start it. So, you either have a bad solenoid in your starter, or the contacts are dirty, battery connections are dirty. Or the battery is dieing. Check it out. Hope this helps.
May 07, 2010 | John Deere A,b,g Tractor Carburetor Float...
JD L120 riding mower keeps dying on me
Loosen fuel cap 1 turn to see if it will stay running.Theres a tank breather hole/vent in the cap and when it becomes plugged no air can get into fuel tank when fuel is used,can also be a plugged fuel filter.
Apr 21, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John deere tractor starting,bogs down then dies
Send your injectors in to be bench tested.They should pop around 2300 psi.I could be wrong about pressure scince I havent bench tested this model injector in some time.Takes about 5 minutes for all of them.Also see if your primer pump has good pressure,
Jun 23, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
1,055 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
