Question about Transmission & Drivetrain for Pontiac Grand Prix
Can a bad PCM cause P0741 code on 07 pontiac grand prix?
07 Pontiac GP with 170k miles, transmission recently rebuilt by reputable shop. Keep getting p0741 code (tcc stuck on/off cant remember) The shop has worked on the car 4 times including the original rebuild and supposedly changed all solenoids, checked all trans wiring, including putting in a new wiring harness and I got the car back yesterday with the same code. Drove the car, and it did fine for a couple miles, stopped and car immediately stalled. It did this 5 more times in less than a mile. Got it home and it does it every time it is put in drive, unless you two feet it & hold gas & brake at the same time. Now the tranny shop says (by phone) it is probably the PCM/TCM not sure which or if the TCM is part of the PCM. I know this will have to be programmed by a dealer. Can this be the problem or something else possibly overlooked this many times? Note - every time I got the car back in the past, the code is present but the car has drove & shifted mostly good for about a month at a time, then slips very bad, I take it back, he has said 2nd gear has been "burned up" at least two times. This has been going on at least 6 months now and I am at the end of my rope with this thing.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 126 Answers
Vacume sensor not reading
Posted on May 12, 2014
3 Suggested Answers
ZX2Fast
  • 547 Answers
SOURCE: I just took my van
Without those codes it would just be a lot of guessing. Post up those 5 codes and we can give you more detailed information about your specific issues instead of just guessing. You should also post up any symptoms or driving issues you have to further help us help you.
Posted on Jun 18, 2011
  • 691 Answers
SOURCE: My pontiac GTO Transmission will
Check the vacuum line to the transmission vacuum modulator, and the modulator itself.
Posted on Aug 28, 2011
2005 pontiac grand prix transmission problems
Not necessarily.... how many miles? Have you recently serviced the transmission fluid and filter?
Feb 22, 2017 | Pontiac Cars & Trucks
How to remove transmission from a 07 pontiac grand prix
Transmission Repair Shop- on a vehicle lift, by
people that do that for a living & have the experience
You know that was the answer !
May 15, 2014 | 2007 Pontiac Grand Prix GXP Sedan
Where is the transmission control shift solenoid located on a 2004 pontiac grand prix gt 3.8 v6
most likely in the valve body. Without experience in transmissions I would not attempt. Should be performed by reputable trans shop
Jan 10, 2013 | 2004 Pontiac Grand Prix
Engine light came on 2005 pontiac grand prix 130000 miles owners manual said bad gas or emission system did diagnostic check thru onstar they said cooling system. gauges are normal heat range
Is there a way to get OBD codes for the problem? You can usually get them read at a local auto store or repair shop. Most likely if you are not experiencing noticable problems it is probably just emissions, but I would get your code read just in case.
May 03, 2011 | 2005 Pontiac Grand Prix
I have 1998 pontiac grand prix with a leaking power steering. what could be the problem?
Bad seal in pwr steering pump or rack could be leaking or one of the hoses. Have a reputable shop or mechanic look at it for you and don't put it off, if it fails when driving it could lock up and cause an accident.
Jan 03, 2011 | 1998 Pontiac Grand Prix
2001 PONTIAC GP 3800, BANK ONE O2 SENSOR
probably not the o2 sensor but some other problem causing that code does it say bank 1 lean or rich?
Jan 24, 2010 | 2001 Pontiac Grand Prix
07 Grand Prix Trans. Fluid Change Schedule
you may change the filter and fluid, but in most cases it will not do any good. Find a good trans shop to check it out.
Oct 11, 2009 | 2007 Pontiac Grand Prix GXP Sedan
I've got a 04 Pontiac Grandprix with 200,000km on
2004 PONTIAC GRAND PRIX GT 3.8L 231cid V6 FI (2) : Transmission-Automatic : Automatic Transmission Assembly
$1,688.79 Core deposit: $550.00 Total: $2,238.79
Aug 11, 2009 | 2004 Pontiac Grand Prix
Engine overheats on Pontiac 2002 GP
Check the catalytic converter. If it is clogged, it will reduce your your power and increase the temp of the car, especially on steep inclines.
Aug 22, 2008 | 2002 Pontiac Grand Prix
Transmission & Drivetrain for Pontiac Grand Prix Logo
115 people viewed this question
Top Pontiac Vehicle Parts & Accessories Experts
Jeff Turcotte
Jeff Turcotte
Dan Shibata
Dan Shibata
Jerry Pecor
Jerry Pecor
Level 1 Expert
Are you a Pontiac Vehicle Part and Accessory Expert? Answer questions, earn points and help others
