31769700 lphd up - Computers & Internet
  • Bob Sloan May 27, 2014
    It might help if you tell us a little about the kind of device you are having a problem with. Info like Make and Model would be useful. If it is a computer, please tell us the Make and Model, and the operating system you are running. If you don't know how to find this, you can download and run Belarc http://www.belarc.com/) to get the information. Then, please tell us what problem you are having?
Iomega lphd up3
Please Explain Your Query.
Jun 08, 2013 | Computers & Internet
MATCHING CABLES FOR A IOMEGA LPHD-UPC
Use a USB 3 cable it will provide more usb throughput
USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/
Jan 24, 2013 | Iomega 500GB Prestige USB 2.0 Portable...
Lphd-up
No there is no external power supply for that hard drive.
Jan 03, 2013 | Iomega (34959) 500 GB USB 20 Hard Drive
MY IOMEGA LPHD-UP3 external/usb memory device, thinks it is full.
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
hope this helps
Jun 27, 2012 | Iomega Computers & Internet
LPHD-UP will not read
Your external drive is going bad. Try another usb port, then try it on another computer.
Jun 04, 2012 | Computers & Internet
Driver for IOMEGA LPHD-UP
Please I need the Driver for iomega lphd-upc
Aug 07, 2011 | Iomega Computers & Internet
FixYa, I have an iomega external hard drive (part number 31769700; model LPHD-UP; serial number 87ak34e684. I've used the hard drive as a back-up before and it currently has data on it, however;...
I am afraid I have some bad news, whenever I have had a drive which failed to format, it turned out to be faulty, however there is one thing you could try, which "shouldn't" be destructive. Find a windows xp boot disk=c and boot from that, dont install, but go to the recovery console. You should get what looks like a command prompt, from here type: format /mbr
what this does is clear and format the master boot record. If this fails as well then I reckon your drive is poorly. another thing you could try would be to dismantle the drive casing and install the drive directly into your pc as a seconday drive and try to access the data that way. If it is the circuitry in the caddy that has the fault then the drive should work this way. If the drive is faulty, it is possible that it will stop your machine from booting. If this is the case, remove the drive to boot your machine. I would at this point contact the manufacturer and see if there is any way they can recover the data (although they do tend to charge quite a bit for this) lastly if you dont want to go through the manufacturer, examine the drive and search the internet for a controller board for the exact same model of drive. This may then allow you access to the data.
Hope I have been of some help
May 06, 2011 | Computers & Internet
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
