Question about K'nex 6-Foot Ferris Wheel Building Set
Why won't motot fit in parts or work? - K'nex 6-Foot Ferris Wheel Building Set
Will a yamaha 350 warrior cdi work on a yamaha 350 motot 4 they look exatly the same
I would call the dealer and have them check the part numbers. If the part numbers match then yes you can. Alot of the time the only difference is the connector. Yamaha has alot of interchangeable parts but the safest way is to verify the part numbers. If you just " try it " and they don't match you just may have fried the cdi box and you'll be trying to troubleshoot a bad part that you think is bad.
Nov 15, 2013 | 2008 Yamaha YZF-R15
WM2277HW LG Tromm washing machine won't start. Finding correct parts is not so easy. Why?
At 14+ appliance years of age, it doesn't make economic sense to repair it.
Mar 06, 2017 | LG WM-2277HW Front Load Washer
What motor is in my DLB6850BALWH Dryer?
the part number for the motot is WE17X10010 and runs about $100 and if you need the repair manual that part number is WX10X116 and cost around $25
May 11, 2012 | Hotpoint NBXR463EBWW Electric Dryer
I have a emerson insinkerator that has nothing working checked breaker and reset button??no power??
First check that you have voltage at the outlet and that the switch is working. There is a reset button on the bottom of the unit - have you tried to reset that? If not, try it! If that doesn't do it, unplug your unit and use an allen wrench to rotate the motor (CW), if it won't turn then you either have something like a bone or spoon wedged in it or the motor is bad. If the motot is bad it is cheaper to replace than to repair.
Aug 14, 2011 | Emerson Vacuums
Intermatic motot WG-5094-1
Open following link for Intermatic parts:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#clock-motor
WG5094 does not show in Intermatic charts as a replaceable part.
None of the regular sellers of clock motors show that part.
What timer does this come off of?
Add a comment with in-focus photo of timer (not motor) that you post on Flickr for possible help identifying part.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 15, 2011 | Watches
Belt stop working. All lights lit.
HAPPILY WALKING ALONG AN THE MOTOR JUST STOPPED. aLL OTHER CONTROLS STILL WORK. jUST THE BELT AND MOTOT WON'T FUNCTION.
iS THERE A PART ON THE POWER SUPPLY THAT HAS BURNED OUT?
May 16, 2010 | Nordic Track /proform Treadmill...
Passenger sliding door doesn´t unlock (Power locks). When pulling the handle either inside or outside with doors unlocked it won´t open.
Sound like you have a dammaged door latch assembly. It is a pain but you have to take the insid door trim panal off to see what you are doing and make sure the latch assy is un locking. Dis connect power door lock motor linkage to make sure motot is not jaming the lock in the lock possition.
Oct 07, 2009 | Ford Windstar Cars & Trucks
1995 escost diesel
Yes you might have to alter the connector to the motot a little but that is normally not a problem
Jun 21, 2008 | 1995 Ford Escort
K'nex 6-Foot Ferris Wheel Building Set Logo
Top K'nex Toys Experts
ray gallant
Are you a K'nex Toy Expert? Answer questions, earn points and help others
