Question about Hardware & Accessories
Why does the car shake after changing gears and also when increasing speed?
Good day My car has a problem of starting to shake when is in motion and sometimes when changing gears and increasing on speed, may you please assis on what could be the problem. Ford figo 1.4 ambiente petrol... thanx portia
  • 742 Answers
It sounds like you have either a bad drive axle or the differential is low on fluid and or has bad bearings. Also check tires to rule out a busted belt on the tires. This will cause a bad shake. Hope this helps, please post a comment that this is solved on fixya.com. So I get credit for a solved problem if it does. If not, check back and give me more info.
Posted on May 09, 2014
  • Daryl Gleaton May 09, 2014
The driver side tire on my Nissan Altima shakes badly I've changed the brakes but I'm wondering if I need to change the lower control arm
Can you grab the tire/wheel assembly and it has looseness while stationary or is it a shake that starts when speed increases?
If it starts to shake as speed increases,you may need a wheel balance.
If there is any looseness when you grab it while stationary,get a look under there SAFELY!! and replace any loose parts.
May 28, 2017 | Nissan Cars & Trucks
I have a SYM Joyride 200. it has a jerking motion or shakes when accelerating or at low speeds. belt, rollers and gear oil were all replaced. the mechanic I went to said its normal due to wheel clearance....
One these girly things with no gears so yet it will jerk a bit ,get a proper scooter like a vespa with manual box like or a sx 200 lambretta ,or better still get bigger wheels which are safer and get a nice cruiser style motor bike
Nov 29, 2013 | Cars & Trucks
2002 merc cougar 5 speed, slow to increase speed after it gets up to 20 for me to shift into 2nd gear, as the same jarring motion as when you to good at shifting a standard, the jerking motion. still acts...
sounds to me that your clutch needs to be replaced. There is no adjustment on the clutch pedal. It sounds like the fly wheel will need to be surfaced also.
Apr 08, 2011 | 2002 Mercury Cougar
I have a 94 olds cutlass supreme the speedometer does not read right it is off if you are in town but on the highway it is farly right on what can i do to fix this
have you changed wheel size? if you changed your tire rim size,it throws the speedodometer off.in other words if you changed the 15inch rims to '18 inch or '20 inch rims you have thrown the speedometer off. because more wheel base is turning on the fround when the cars in motion. speeding tickets,yes! you're putting more wheel base on the road,which will increase the odometer speed as well as the cars. you may think you're doing 65mph with 15inch tires[good] but upsize your rims, you may be as much as 15miles or even 20 miles above the speed limit, or else if no rim change,have your transmission checked for bad speed sensor or the gear that runs the odometer is worn.thank you for choosing fixya.com
Jan 28, 2011 | 1994 Oldsmobile Cutlass Supreme
Photos are blurred.
Blurred images are caused by several reasons: motion due to camera shake, use of slow shutter speeds and failure of the camera to focus correctly.
Slow shutter speeds
When light is low, wide apertures and slow shutter speeds will be selected automatically by the camera. Most people can't take blur-free, hand-held shots when the shutter speed is under 1/60th of a second.
Cameras that have optical Image Stabilization help but even IS has its limits. Increase room lighting, increase the ISO setting or use a tripod, or use a combination of all three.
Blurred images or misfocus
If an image is blurred due to camera shake, the blur will appear throughout the entire image. If parts of an image are in focus, and others are not, you've misfocused.
Sep 16, 2010 | Cameras
How can i increase my top speed on my pulsar 150 dtsi
when you put your bike in gear dont be hurry and gradually increase the grip. As per the bike taking motion in same rame increase grip.
It is the best technique to increase speed.
Jun 25, 2009 | 2005 Bajaj Pulsar 150
Transmission vibrations to heavy shaking between 30-45 mph
tranmission mount is broke change it before it breaks your motor mounts.
Jan 10, 2009 | 2000 Mitsubishi Montero Sport
Landrover Freelander Serengeti Diesel 2.0 2003
Sounds like the wheel balance is out on the new tyres, if the rears are out of balance expect the car to shake, if the fronts are out expect the steering to shake.
Best thing is to take it back and have the balance checked. Also good idea to stay with the same make and type of tyres all round.
Regards
Chris
Jul 07, 2008 | 2003 Land Rover Freelander
Camcorders
Almost any new digital camcorder will work great, but you want to make sure it has a high speed shutter setting.  Set the shutter speed as high as possible (which means you'll need a lot of light... day light is perfect).  You're still only shooting 30 frames per second, but each shot will be sharper (less motion blur) as the shutter speed increase.  High-end cameras can go up to as much as 1/10000th of a second, but even 1/500 would be great.  Standard, default shutter speed is 1/60th.
For playback, you can use the same camera with a remote control.  Just press play, then just before the swing press pause.  Then use the frame advance button to move 1 frame at a time.  Multiple presses of the frame button will increase the speed... to slow motion.
Apr 24, 2008 | Video Cameras
Hardware & Accessories Logo
74 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
