Question about Dishwashers
How to un clog drain on a ptb1953drw - Dishwashers
    Sergeant:
  • 283 Answers
Hi Thomas, there is drain cleaners at a Hardware Shop ask there for what to do. Cheers Greg.
Posted on May 09, 2014
Is it feasible to un-screw the drain on the Rheem 50 water heater without it breaking off inside? I want to drain my tank but the drain valve is clogged and I cannot clean it as it is a right angle hose...
POWER OFF ..ya i think its plastic so if it does break you can picj it out with a screw driver and A HACKSAW BLADE. then go buy a brass plug or a new valve.. a ball valve would be nice.. did you know that you shold drain the tank EVERY YEAR ! AND SHUT THE POWER OFF
if i was of help please tell me.. tahks ..jay
Sep 12, 2010 | Rheem Water Heater Drain Valve
Water is not draining, I removed the strainer and it was not clogged! What else should i try? My sink pipes are draining just fine.
if it not clogged does it hum like a motor is running. if so your drain pump is clogged with a restriction.un clog depending on make and model. let me know if i was helpful to you
Feb 27, 2010 | Dishwashers
1993 Nissan Pathfinder has a leak on interior passenger side.
You should be able to find the end of the drain on the fire wall at the passengers feet area. Compressed air is the method used by garages but you may be able to fish a wire up the drain and unclog it. You will know it when a lot of water comes out.
Jan 16, 2010 | Nissan Pathfinder Cars & Trucks
Water leaking about the firewall it is not the heater coil, or freeze plugs
it is the condensation from the a/c, the drain for the evap core is stopped up causing the condensation to leak into the vehicle. More than likely you have a bunch of leaves or dirt accumulated in the air box. You can sometimes get compressed air and blow it through the drain hole to un clog it. worst case the air box will need to be removed to un clog it. In the future, to avoid it from getting stopped up, run your a/c on recirculated air to avoid bringing in dirt and debri into the air box.
Nov 10, 2009 | 1995 Toyota 4Runner
My fridge has a leak on the backside of the fridge behind the light bulb section. what can i look for or do to fix it. THANKS Felix Gomez
YOUR DRAIN IS CLOGGED. WHEN YOUR FREEZER DEFROSTS THE WATER HAS TO GO SOME WHERE. UN PLUG AND TAKE THE COVER IN THE FREEZER OFF. REMOVE ATH ICE UNDER THE COILS IS A SMALL DRAIN HOLE.THAT HOLE IS CLOGGED WITH ICE AND TRASH.
Oct 28, 2009 | Kenmore Refrigerators
Air conditioner drain clogged how do i find the drain
it should be on the left hand side of the fire wall just run a wire in it to un clog it
Aug 15, 2009 | 1993 Chevrolet Lumina APV
2007 Toyota Camry. The passenger side carpet is wet,but not stained and has no real oder. It is soaked under the seat by the airconditioner duct. Its just like we spilled water. AC works fine and i...
it sounds like the drain hole for the condenser is clogged and the water is pooling up and overflowing out of the vent and spilling over onto the carpet. you need to un clog the drain hole. if you look behind the passange wheel and under neath the car you will see a black hose leading up and into your fire wall run a long semi flexible wire or like and un clog it do not jam it in to far or too hard you dont want to put a hole in the condencer but when you get through you will get a rush of water that should pour out
Jun 24, 2009 | 2007 Toyota Camry
Watwrleaks out of the bootom of the dehumidifier -
There should be a drain hose to drain water!!Check tank for leaks or obstructions-check that drain isnt clogged!!un clog and clean as necessary!!! Best of Luck!!!!
Jun 24, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
GE side by side refrigerator-1994
Check your drain pan for water.If you see none than you have a clogged drain line in the freezer.Remove the back wall lower screws and any screws that will prevent you from getting the back freezer panel off,NOTE : this is in the freezer located on the back wall. You will see the drain behind this panel , if its clogged ,un clog it.
Jul 23, 2008 | GE Profile Harmony DPGT750EC Electric...
Whirlpool adp 44045 dishwasher not drainign and geen light constantly flashing - how do i drain system
First pull off hose on your garbage disposal and look for a clog.If no disposal then un do the drain hose under sink and look there.
Jun 03, 2008 | Whirlpool Washing Machines
Dishwashers Logo
Top Dishwashers Experts
