Question about Freezers
Samsung rs21dgrs another fault!
Control panel chimes & swaps between display & child lock repeatedly. I was sitting alone in the house when this started, I have turned the mains off for 5 mins and put it back on, the fault persists! ??? any ideas ???
    Sergeant:
  • 283 Answers
Hi Adrian, a Factory Reset would be the way to go then put only Apps on that you want but not to many add them as you need them then uninstall. Just thinking take off Apps that you are not using that may fix it. Cheers Greg.
Posted on May 09, 2014
2 Suggested Answers
SOURCE: Cannot control internal temp plus clicking relay on control panel.
Where is the fast defrost button on Kenmore chest freezers?
Posted on Jun 27, 2008
With deluxe Electronic Temperature Control Freezer control panel shows "OF" and I can't restart the freezer
Search Results
    Freezer electronic temperature control manual... ' Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. ...my freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
    Control Panel is not working right - Samsung
    www.samsung.com/sa_en/support/skp/faq/239315
    Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
    Adjusting Side-bySide Refrigerator Temp Controls - Actual ...
    ? 3:50
    https://www.youtube.com/watch?v=DFzTGKVo79g
    Jun 27, 2010 - Uploaded by GE Appliances
    CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
    Electronic Temperature Controls - ManualsLib
Feb 03, 2016 | Freezers
Our fridge compressor won't run after a power outage, can it be reset?
compressors use a small start / run capacitor to start the compressor
modern fridges do not like spikes from power outages and many power boards and electronic components fail because of this and I am inclined top use a surge protector before the fridge cord plug
I went google and typed in --fault code 88-88 for samsung fridge model rf26aewp and the first site up is error codes /messages/ blinking
the site is support-us.samsung>popup>iframe
there is a detailed answer there with a list of fault codes as well and what they indicate
there are other sites that also refer to the fault that you have
Dec 15, 2015 | Samsung RF267AEWP - 26 cu. ft. French Door...
How to unlock control panel LFFH21F7HWG?
Press and hold the Control Lock key for three seconds
to activate or deactivate the function. The Control Lock
feature prevents the user from changing the temperature
and freeze settings. At the first press of any key, the
key press click tone will be heard and the display will
show "LO", but no other change will take place. Holding
the Control Lock key for three seconds will activate or
deactivate the Control Lock feature. After three seconds,
the accept tone sounds and the Control Lock LED (if so
equipped) is activated. In lockout mode, when any key
is pressed, the invalid key tone will be heard and "LO"
will be displayed for 1 second. When the lockout is
deactivated, the Control Lock LED is turned off and the
display shows "UL"
if this does not work unplug the freezer for 30seconds then plug it in. if all of the above fails replace the control.
Jul 04, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Why has my kenmore elite trio refrigerator started to intermittently started to chime
Hi! I am having this exact problem also. The best answer I have been able to discover is that it is related to the freezing up of the internal water tube that drains the fridge compartment into the freezer section. In addition, a pool of water freezes on the interior floor of my freezer and has to be manually chipped up and removed. I did try to unload the freezer and defrost it thoroughly, but it still happens and has to be chipped each week. I am still seeking a solution, but at least I can make the chiming stop by locking the temperature via the button on the front panel. Best wishes. If you discover a better or final soln, please post. I will do so as well.. Regards.
May 28, 2014 | Kenmore 22 cu. ft. TRIO French Door Bottom...
Display reads off and it will not re adjust to anything. I have unlocked display but nothing changes the setting.
There may be a child lock enabled, refer to the owner's manual to disable this feature, otherwise check the troubleshooting section of the manual.
Dec 22, 2013 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Samsung side by side refregerator door left open for some time, the door warning chime does not come on
Check the switch just inside the door. If it's not chiming, it may not be switching the fan either.
May 03, 2012 | Samsung RSH1NEPE 554L SIDE BY SIDE...
Freezer rs21dgrs water not working???
Purchase A premium Solution Package For $19.99.
One of our technical Wizards, will Sort This Problem Out For you In 1 Hour. ** Time Of Day Depending**
@ $19.99 Or £10.00 G.B.P
You Can,t lose.
Mike @ Compurepair.
Thankyou For Using FIXYA.
Feb 29, 2008 | Freezers
Freezers Logo
82 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
