Question about Canon Computers & Internet
Canon ir3300 paper at tray 1 not detected - Canon Computers & Internet
SOURCE: Canon iR5000 Tray 3 problem
look behind the tray and see if there is paper stuck behind the tray. Good luck
Posted on Dec 23, 2007
Corysf62
  • 188 Answers
SOURCE: paper not picking from tray 1
More then likely the paper feed rollers are worn. These rollers are replaceable, and are also included in the maintenance kit.
Posted on Sep 28, 2008
  • 30 Answers
SOURCE: Canon Pc 25 not pulling paper completely through from tray or from manual feed tray.
hi,clean feedrolls & paper transportation.clear any misfeed sheet in paper supply section.send me result.
thank you.
Posted on May 28, 2009
Cogz
  • 1326 Answers
SOURCE: im having canon ir400 copier.in first cassete im
First I would pull the paper tray out and look for a wade of paper jamed behind the paper tray or jamed in the paper path above the cassette. Another problem could be that the tray is not lifting. If you take the second tray out and reinstall the first tray can you look under the tray and see it raise up or does it make a noise and not lift. It could be the rachet gear is broken that lifts the paper up. These are just a few ideas.. Good Luck
Posted on Oct 10, 2009
canontech
  • 1219 Answers
SOURCE: canon ir3300 not communicating with microsoft
Under printer properties check the format of paper, it must be A4 if you have A4 in drawer. The most common fault is that under printer properties is LTR as format and A4 in drawer.
NOTICE: in paper drawer did you check the little blue wheel, is it "telling", the appropriate format as in the drawer?
Posted on Apr 30, 2010
Canon ir3300 does not showpaper in tray
hi . have you tried to put the paper in a different position ( LTR >>LTR-R)
Mar 22, 2016 | Canon Office Equipment & Supplies
Canon ir3300 showing paper jam in 2nd tray but thre is no paper jam in it
  1. Locate and dust your paper sensor eyes
  2. make sure paper size adjuster for tray 2 is locked at proper position.
  3. Examine pick up roller from tray 2, clean or replace as necessary.
Mar 12, 2015 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
How to solve the fold paper problem for canon ir3300
check the paper guld in the tray or fusing press relese on the fusing unit
Jan 09, 2015 | Canon imageRUNNER 3300 All-In-One Laser...
i m using canon ir3300 , showing paper jam at left side , but i checked there is no any paper, although there is showing jam. what to do.
Jul 17, 2012 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Hello, my copier machine cannot detect paper
Pull paper tray out and set aside,
in the back there is white lever above the spring
push lever in ,a black actuator should drop down
if it does not it may be broken or stuck.
The tray select button on the control panel should allow you to use the side tray.
Jul 21, 2010 | Canon IR1018J Black and White Copier
Dear sir i have ir3300 cannon yesterday i switch on the machine monitor showing E602-019 HOW TO SOLVE THE PROBLEM
E602
0001 A mounting fault of the HDD is detected when the HDD is started up from
the BOOT ROM.
0002 A data read fault of the HDD is detected when the HDD is started up from
the BOOT ROM.
0003 A sector fault is detected on the HDD.
0004 A fault is detected in the read /write address for the HDD.
Main cause The wiring is faulty (short circuit, open circuit). The HDD is faulty. The
main controller PCB is faulty.
BUT FIRST: TURN OFF THE COPIER SIMOULTANIOUSLY PRESS 1 AND 9, HOLD IT, AND TURN ON THE COPIER. THIS WILL INITIALIZE THE HDD DEFRAG MODE.
TRY IT, IF NOT REPLACE HDD, AND UPGRADE SOFTWARE - NOTE: FOR UPGRADE YOU NEED THE SERVICE SUPPORT TOOL - CALL SERVICE FOR THATH
Feb 13, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Canon ir3300 not communicating with microsoft windows getting error: printer load paper but trays are full. Can you help?
Jan 19, 2010 | Canon (6981A002AA) for imagerunner 2200,...
How do i refill staples in the the canon imageRUNNER 3300?
Look in the Reference Guide. This should come with your copier if you bought it new. Do you have Finisher J1 (internal finisher, paper comes out above paper trays) or the SaddleFinisher and inner2way tray (paper comes out on left hand side of machine).
For finisher J1 look starting on page 7-38. Saddle Finisher 7-61.
Can get Reference and Copy guides here: http://ww2.canon.it/supporto/manuali_operatore/elenco.asp?t=&i=IR3300&id=IR3300
The English versions (which I use, I don't speak Italian) are the ones with ENG in the name.
Jul 21, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Dec 18, 2007 | Canon imageRUNNER 5000 Copier
Computers & Internet Logo
258 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
