The little motor that mounts under the turntable do not work.
When I turn on the record player, the turntable will not turn. The little motor whick mount up under the turntable is getting lots of fire, but will not turn the turntable? Where do I find new motor??
  • Tim Swiercinsky May 11, 2010
    What is the make and model of your turntable? Is it belt drive or direct drive?
  • 69 Answers
Rs components
Posted on Aug 07, 2009
Hey there, After a power outage the motor that drives the platter "BSR turntable" does not function. Is there a fuse or some other likely suspect?
If the motor is directly connected to a mains supply then the chances are that when power was restored it burnt out or damaged the motor itself. Following the mains lead into the unit should answer where the power goes. If it goes to a transformer and it's associated power supply the problem will be found there.
Nov 07, 2016 | Audio Players & Recorders
Picks record ,clicks twice ,returns record without playing
Mechanism for moving arm over and onto record is fubar. Probably stuck and the clicks you hear are the motor fighting a losing battle and returning arm to rest mount.
Remove stylus and play with arm and simulate turn on cycle to see how it works and where the jam is- fix and then put stylus back in - those little suckers are expensive.
Dec 06, 2015 | Audio Players & Recorders
Crosley CR40 playing 33 1/2 too fast? What can I do to slow it just a little bit?
I would get a vintage turntable and not a new one inexpensive one. The new record players do not last.
Apr 20, 2014 | Crosley Stack-O-Matic CR40 Turntable
I have a califone 1430k record player, and the arm is loose. It looks like the spring must have come loose. It is still attached by wires, but nothing else. If I take it apart, do you think I could fi
The arm should have a pin through it that secures it to the bracket that is attached to the arm bearing. There should be a long spring that is used to adjust the tracking force and it is underneath the arm.
The arm can be taken off by taking the player apart, unsoldering the wires from the arm and unscrewing the nut on the turntable bearing.
Because the arm mounts to a soft rubber grommet it should feel a little loose.
Hope this helps.
Jan 16, 2014 | Califone International Audio Players &...
Record player does not turn everything else works, but when you turn the nob to phono, turntable does not work
Usually there is a belt that drives the turntable. Sometimes it is hidden under the turntable and you lift the rubber record pad to access it. They fall off or deteriorate causing these problems.
Jun 07, 2010 | Crosley CR711 Autorama - Chrome Vintage...
B & O Beocenter 4600: The record player won't spin
the turntable wont spin unless a record is on the platter,the centre 45 adapter weighs the record to determine 33/45.try pressing 33 and turning the platter by hand(remove expensive cartridge first!),if it starts to spin the motor leaf switch is at fault.is the belt in position.the motor pulley can become unglued.
Jan 08, 2010 | Bang and Olufsen Beocenter 9300 Shelf...
Turntable with varying speed
It could be a belt problem...it could also be a
line voltage problem from the ac coming out of the wall if your record player motor is not syncronous...I remember as a boy some of the cheap little record players I had would change pitch at different times during the day, based on the line voltage varying a little bit coming from the wall plug...
Check to see if your player motor is "syncronous" or some such word....
more than likely it is a mechanical problem...
regarding the physics of how the turntable is driven....
Sep 14, 2009 | Audio Players & Recorders
Old record player spins too slowly
it sounds as if the rubber belt is to slack however also worth checking ithe attachment to the spindle itself is not loose 2make sure the belt is the correct type
Feb 09, 2009 | Crosley Traveler Turntable
No sound coming from turntable
most likely this is the switch that selects among cd/tape/radio/record player. it could be the preamp circuitry in the player as well. it would not be the cartridge UNLESS you cannot see a little rubber 'seat' up inside underneath the cartridge that pushes the stylus tip out and down towards the record just a bit. if this rubber 'yoke' (seat) is missing you will get no sound even when you touch the needle tip when the record player section is selected.
Jan 29, 2009 | Crosley CR248 Turntable
Tone Arm skips past first song
Hello, A. Do not try to close the case when there is a record inside!! The fact that the turntable cannot do this is not a design flaw--you'll be hard pressed to find a portable turntable that can close with a record inside because if you were to pick up the player with one inside, it could easily slip off of the spindle and scratch against the sides of the player.
B. Are you using the cueing lever to lift the tone arm before you place it on the record? Read the instructions to see where the cuing lever is (it's a little switch on the right side of the tone arm). When you lift it, the tone arm will lift up and allow you to position it wherever you want on a record, then you depress the lever to make the tone arm touch the record and being playing.
I hope that helps!
Jan 04, 2009 | Crosley CR249TA Turntable
228 people viewed this question
 Grubhead
Grubhead
