Question about Amana NFW7200TW 3.5 Cu. Ft. Front Load Washer
I washed a rubber backed rug in my Amana NFW7200TW front load washer, wasn't thinking. now washer will not drain, is there a filter filt that could be clogged?
Is there a filter or hose that I should check before the pump to see if it is clogged? it tries to pump but I believe that there is that backing clogging something up.
  • 41 Answers
Yes you have blocked the drainage system sorry i am not sure if there is a filter on this mach. disconnect mach and take the drain hose and try puttind it into a basin failing that carefully tilit machine back and disconnect the hose from the base of the mach to the pumpthis will allow mach to drain but you will still have to clean out the pump hope this helps .
Posted on May 11, 2014
ginko
  • 19396 Answers
SOURCE: Amana front loader washer Model#
It means there is a problem with electronics, Amana indications are to call the service
Posted on May 31, 2008
kevin000
  • 1847 Answers
SOURCE: extreme vibration of top loading
check the bolts that connect the tumbler are tight.
you can check by opening the back cover.
Posted on Oct 06, 2008
smartr10U
  • 1305 Answers
SOURCE: amana nav5800aww water on floor after spin cycle
Sounds very similar to having something such as a sock or small article of clothing that is too large to be sucked down the drain hose into the pump. So what happens is it hangs around between the inner and outer drums and sometimes gets itself lodged over the drum drain hole, and can allow water to be centrifically flung over the top of the drum. Most times when the spin cycle stops, the article of clothing will dislodge and float around inside the drum only to do it again later....
If you can remove the top of the machine, you can usually see the gap between the two drums and use a piece of coathanger wire with a small hook on the end and "go fishing in the area between the two drums and close to the drain hole location... bet you'll find something in there... Let me know how it goes... and if I can help .. ken
Posted on May 10, 2009
  • 10865 Answers
SOURCE: how do you change the drain hose on an amana washing michine
hello. The existing drain hose is a friction fit held in place with a wire clamp. Use a pair of channel locks or pliers to slide the wire clamp about 6 inches up the hose and then work it off of the fitting it is attached to. If it has been there for a long time you will find it useful to warm up the drain hose with a hair blow dryer. Regards, Joe
PS - kindly rate my answer. thank you.
Posted on Feb 03, 2010
SOURCE: amana front load washer door locked with door open
To get the front off. (All screws look to be #2 Phillips Screws)
1. You have to unscrew (2) phillips screws from the back that holds the top on.
2. Slide the top off. (slide towards the back)
3. Then where the control panel is there is about 4-6 screws holding that plastic piece on, take those out this will allow you to pull the control panel up and out of the way.
4. At this point you can unscrew the 4-6 screws in the door area that holds the front of the washer on, once you unscrew those screws there is a tab that you have to lift the front over to pull the front off. This will allow you access to the locking mechanism.
5. There are only 2 screws holding te locking mechanism on.
Posted on Nov 18, 2010
My amana front load washer, model NFW7200TW won't drain it gets down to 8 min of cycle and stop and display nd code. Check pump, fine also I can open washer door when it get stuck in this mode
remove the drain hose from back to see if there is any foreign object stuck in there , if washer faults out on code its common for door to unlock
Aug 16, 2016 | Amana Washing Machines
Amana nfw7200tw will not run. all wash settings read 1 extra minute. Is this a code or something like that?
have you tried unplugging and resetting the computer, it seams hung in the last cycle, can you open the door and remove all inside, reset it again and try it, the washer sounds like it has water in it and needs to drain first,if it is full of water you have to drain it, by moving it and taken the drain hose off the pump,if that's the case i recommend flushing the inside with hot water and some bleach right through the front door or reservoir on top,after you get it emptied, the water sensor may be full of soap, by the way the soap your putting in this machine should only be about a 6th of a cup, I know it sound crazy but a half or a 3rd is to much, for the sensors, try this an get back to me,Matt
May 01, 2015 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
My amana nfw7200tw needs a new drain pump. ive been online trying to find the best deal and i acaully have found a few (for a really great price) that pop up when i type in the washer model # and the
make sure it a drain pump, they same will fit Samsung ,amana and Maytag, make sure it not just stopped up remove it and look at the impellers, i put one in to find out it was the water sensor was soaped up and telling the washer it was full when it was empty and i would get a nd on the front , no drain,Matt, need the answer to fix that let me know.
Sep 21, 2014 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
I have an Amana front load washer, it will run through a complete cycle when empty but will not run with a load in it.
Hi Ben
I see you have posted on this before , I think you may have done this already judging from your post , but have you checked the filter on the drain pump? also when you run a cycle empty, is it filling and draining the water correctly , or is there water left in the machine , and last is the drain hose high enough to make sure that there is not a "syphoning" effect taking place as in when it fills with water it drains at the same time , just a thought let me know.
Oct 13, 2017 | Amana Front Load Washing Machine Washer...
Can an frigidaire X091307954 dryer be stacked on a Amana NFW7200TW 3.5 Cu. Ft. Front Load Washer?
this is possible, youll need a kit that sets on top of the washer,check back where you bought the washer and dryer, they make a washer and dryer combo thats one peice, they are smaller however
Jul 13, 2013 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Amana washer model NFW7200TW drain filter
Go to www.repairclinic.com and enter NFW7200TW. You will be presented with a list of common repair parts and may be able to view a generic Amana video showing disassembly and parts identification.
May 17, 2012 | Washing Machines
Dish washer has water in bottom & double beeps when trying to start
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Hope this helps... Please post back for any further assistance.
Daniel
May 06, 2011 | LG 24 in. LD-12BW5 Free-standing...
Washing machine is not draining water from drum on completion of cycle
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps... Please post back if you need more information.
Daniel
Mar 20, 2011 | Bosch Washing Machines
Amana front load clothes washer door won't unlock.
Make sure it drains okay first as this will not open with water in the drum. Clean filter
Feb 18, 2011 | Maytag NFW7200TW Front Load Washer
Amana NFW7200TW 3.5 Cu. Ft. Front Load Washer Logo
256 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
