Question about Polaroid PhotoMax Fun 320 Digital Camera
How do i operate the polaroid image camera?
How do you turn it on? and how do you take a picture? what do I do first. do you have full intructions for the polaroid photomaxfun 320 digital camera?
  • 641 Answers
adib
  • 450 Answers
SOURCE: Fun! Digital 320: "Camera not connected." -- Serial connection
The "Camera not connected" error message indicates a communications problem in the serial port connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. Whenever an external device (digital camera, scanner, Palm Pilot, etc.) is connected to a computer through its serial port, a communications error is possible. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue. Fortunately, the most common causes of this error message are also the most easily rectified: 1.Make sure that the camera power is on. 2.Make sure that the camera cable has not been damaged. 3.Make sure that the camera cable is properly connected to both the camera and the computer. 4.Clean out the computer's Temp file.
Posted on Sep 14, 2005
SOURCE: Camera turns on for a few seconds, then off.
A light rap with a knuckle when powering up fixed the problem, at least temporarily. Lens extended, camera works fine. Not exactly a technical fix, but it worked for me.
Posted on Feb 21, 2008
SOURCE: polaroid i836 digital camera
this camera has hi-resolution which takes up a lot of memory,the internal memory of the camera is only sixteen megs. all you need is to add an sd card with 1 gbyte of memory and that will solve your problem.
Posted on Nov 15, 2008
SOURCE: serial interface cable for my 320
I have that very same camera and the male jack is a stereo headphone 3.5 mm style with hot-insulator-hot-insulator-ground as you see normal stereo headphone jacks. The opposite end is a serial female receptacle 9 pin that plugs in as the old serial mouses did. I don't know where you'd obtain such a cord or the proper pin-out diagram, but that is what it operates on.
Posted on Dec 12, 2008
fblock
  • 289 Answers
SOURCE: camera said memory full but I have memory card
You need to format the SD card before it will be used by the camera. Formatting instructions are in the manual.
Posted on Apr 27, 2009
BROKEN LCD
it is repairable. there are service centers around that can change just the screen for you.
Jun 26, 2010 | Polaroid i737 Digital Camera
I just bought this camera today and cannot access the "read me" information so am in the dark on how to operate camera properly. I have taken some pictures but now it says, "Memory full" what does that...
You can download the manual from
http://www.polaroid.com/support_detail?p=4317
The instructions will guide you through deleting/editing pictures or you can print or download to a PC using a USB connector.
Please rate this solution. Thanks.
Jun 23, 2010 | Polaroid i1236 Digital Camera
How do i set the date on my polaroid i735
This is straight from the "Polariod i735" Manual.
"• Setting Date/Time, Display On/Off
Date and time can be displayed on the picture by the following steps:
1. Set the camera to Still Image mode.
2. Press the button.
3. Press or button to select (Date Stamp).
Date StampOffDateDate & Time
4. Press and button to select the desired setting."
For the full PDF manual go here:http://www.google.com/search?q=polaroid+i735&rls=com.microsoft:en-us:IE-SearchBox&ie=UTF-8&oe=UTF-8&sourceid=ie7&rlz=1I7ACEW_enUS345US345
Hope this helps!
Sep 29, 2009 | Polaroid Cameras
How do I clear MEMORY FULL?
buy a memory card reader then transfer your images to your computer if your files is important,if not then delete or reformat
Jul 06, 2009 | Polaroid i733LP Digital Camera
My polaroid digital camera wont take pictures right.
HI,
If your camera show picture then its problem of bad ccd imager and requires replacement.
you can go to the nearest service center and ask for replacement.
thanks,
Mar 28, 2009 | Polaroid i733LP Digital Camera
How do I download pictures from Polaroid t1031 to pc?
Turn the camera off and connect the usb cable to the pc. Turn the camera on. Open my computer and you should see the drive listed under removeable drives. Double click on it and drill down until you find your pictures.
Rob
Mar 01, 2009 | Polaroid i830 Digital Camera
All my pics deleted on their own when i turned on my camera..?
Were you using an SD card while taking your pictures? If you were, it saves the pictures you take to the card while it's in.
Do this:
Turn your camera off and connect it to the pc with a usb cable. Turn the camera back on and go to My Computer. You should see the camera (or the card) in the section of removeable drives. Double click on the drive icon, or the card icon and you can find your photo's there. That should help you.
Rob
Feb 22, 2009 | Polaroid i830 Digital Camera
HI - OPERATING INSTRUCTIONS FOR POLAROID PDC 4055
How do I get another copy of the operating instructions book? I can only take 10 pictures then the camera is full. What is wrong?
Feb 27, 2008 | Polaroid PhotoMax PDC 4055 Digital Camera
Polaroid PhotoMax Fun 320 Digital Camera Logo
62 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
