Question about HP cc372aaba - Laserjet M1522n Mfp Laser Printer Pagecount= 2
Where is the adf door on
When i want to photo copy it will tell me that the adf door is open and the coping will be canceled
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 60 Answers
Follow the steps in the manual if you have a manual and if you don't have one I recommend that you get one.
Posted on May 09, 2014
My Adf its not working properly it scan only half of page.
This is simple. There are a bunch of sensors in the adf that read the paper size. Your adf is telling the copier that your copying 8.5x5.5 that's when the copier blanks out the rest of your page. So do u have any scrap of paper or sensor that is blocked they have spring loaded flags on them sometimes the spring will fall off and cause this so look very carefully and you will find the little sensor that is causing your problem. Also there are photo sencors that get dusty. So use canned air to clean them out but be careful you could knock off the springs on the flags with air.
Oct 02, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Adf door is open
Try a nvram. While the printer is off, hold down the down arrow and the cancel button and turn the printer back on, hold down until permanent storage init is displayed on the lcd.
Al
May 19, 2010 | HP LaserJet M1522nf Multifunction Printer...
I have a ricoh spc232sf multifunction printer which is giving a error message of cannot copy and it says feeder adf what do i do?
the ADF is the upper cover where you put the document to be automatic feed by the machine, that is the part which you pull up when you want to copy on the exposure glass, on the left side of the ADF has a little door which you need to open. It is opened like a car door opener and pull it on the right side. see do have some paper inside if do not have paper close the door and lift the ADF in to up position and than set it back. with this you will rest the message.
Please answer do this is helpful for i to know do i should post some more information.
Regards
Jan 12, 2010 | Ricoh Aficio SPC232SF All-In-One Laser...
Feeder does not pick up papers. The display window shows ADF door open. Therefore, I can not print copy or receive faxes.
Try doing an nv ram ( turn off the printer and hold down the right arrow and the cancel button, turn the printer back on and continue holding until you see permanent storage init). If this doesn't work call hp tech support 1800 334 5144 and ask for a case number. This printer has a service note which will cover the formatter for 2 years.
Al
Jan 07, 2010 | HP Laserjet M2727nf Multifunction Printer
Check document Open the ADF
would be a good idea to check the ADF.
the ADF if the top part of your copier, where you put the originals to be taken one by one and then copied. if it tells you to check it you must open it and check there are no paper stuck inside. and then close it back.
Sep 27, 2008 | Office Equipment & Supplies
Error msg..."close ADF cover". Where is it?
Adf : auto doc feeder
the top that you put the pappers in to copy mare than one sheet.
make sure all doors are closed.
lift doc feederas if making copy on glass look where the hinges are there should be a plunger next to one of them, that is the switch to tell it if it's open or flat. try pressing it down to see if message goes away, it may need adjusting.
Jul 15, 2008 | Ricoh Aficio 1013F Copier
Keeps Copying
transfer is the problem...
you simply want to select the photos you want to send
and then send them to my pictures and maybe put them in new folders .
do not copy and send, that is where the coping is coming from.
Hope this helps
Jan 09, 2008 | SanDisk MobileMate SD Plus 5-in-1 Media...
MP780 photocopies made using ADF have a line which obscures content
I tried the other solutions listed her - and no luck. After cleaning the ADF rollers, like the manual suggested - no change.
I finally figured out why things that I coped with the ADF had lines/marks on them, but those placed directly on the platen (glass) were fine. When you copy with the ADF, the copy is not being made from the large glass area. Rather, there is a thin glass area right next to it.
Turns out, there were a couple of smudges (goo) on that thin piece of glass which were creating long vertical lines down every sheet. Cleaned the glass - problem solved!
Gosh, I hope this helps someone else save some time, and frustration.
Nov 24, 2007 | Canon PIXMA MP780 All-In-One InkJet...
HP cc372aaba - Laserjet M1522n Mfp Laser Printer Pagecount= 2 Logo
71 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
