Honeywell emm3 panel-zone 3 off but still get ac from zone 1
2 Suggested Answers
carmin77
  • 113 Answers
SOURCE: I have a Honeywell EMM-3
Zoning, in the A/C world, refers to different areas of the house which may be cooled to different temperatures. Zoning is accomplished by closing/opening vents.
Zone 1, 2, 3 etc. do not have any particular meaning, except to indicate zone control flappers 1, 2, 3 etc. which are physically inside the ductwork which determines the zoned area.
Just because you have this fancy thermostat, does not mean that your house is actually zoned, but I am not to sure why such a thermostat would be purchased if it was not (unless it was free).
Zoning uses dampers. Is there air blowing out of the registers?
:o).
Posted on Jun 04, 2011
Honeywell HZ311 will run AC but it causes the compressor to turn off and back on in about 1/4 second and it goes "bang". Not good. How to stop this momentary power off/then on?
Looks like this is a zone system? Is this new or has this been running ok for some time? If this just started happening and it did run fine before I would have to guess that the zone panel is over amping therefore you are temporarily losing your call for cooling. By pass the zone panel with a single tstat. You can temporarily do this right at the panel. See how the condenser runs then. If ok, problem likely in the panel. Good Luck.
Apr 05, 2017 | Honeywell Heating & Cooling
My Honeywell HZ311 3 zone system (Cool & Heat) system all lights are flashing. Please advise how do i reset (restart) the stem. Thank you!
Honeywell TrueZONE HZ311, HZ322, HZ432 Manual
www.manualslib.com > ... > Other > HZ311, HZ322, HZ432
View and Download Honeywell TrueZONE HZ311, HZ322, HZ432 manual online. ...Page 3. Zoning System Design Manual IntroductIon Fig. 2 depicts a typical residential layout with three zones. ... Zoning System Design Manual Plan the Zones In planning azone system, here's what you need: Panel ... Restore password.
Sep 29, 2015 | Cars & Trucks
I have a Honeywell HZ311 an a red indicator light is on for zone 3, what does that mean if zones 1 & 2 are green ??
red lite for zone 3 means zone three is calling for heat green lite for 1&2 mean zones are satisfied
Jun 12, 2014 | Honeywell Truezone HZ311K Zone Control...
Wiring a Honeywell V8043E for two zones
Honeywell posts pdf manuals.
Google seArch Honeywell V8043E .pdf
Include .pdf in search parameter to find manual with wiring diagrams.
http://www.forwardthinking.honeywell.com/related_links/water/5000_series/install/95c_10932.pdf
Oct 26, 2012 | Honeywell V8043E1012 Zone Valve 3/4 Sweat,...
I have a Honeywell EMM-3 Electronic MiniZone Panel and my thermostat is set at 78 degrees but the house is registering at 89 degrees and it won't cool down although the a/c has been on all day for...
:o).
Jun 04, 2011 | Heating & Cooling
The Zone 1 (basement) and Zone 3 (second floor; no
On the zone damper motor, there should be a little lever allowing you to open the damper for emergency heat. Probably a bad zone motor or connection.
Dec 26, 2009 | Honeywell Electronic Programmable...
My Honeywell EMM-3 zone controller system LED is flashing orange, indicating DAT fault. How do I verify the DAT is faulty?
Hi
Thanks for using FixYa. Perofrm this test--
Connect DATS Sensor to EMM-3 (optional).
a. Reconnect power to EMM-3.
b. If system is in Purge mode, press PURGE OVERRIDE on EMM3.
c. Verify SYSTEM LED is no longer flashing. This confirms proper DATS operation. (Flashing occurs in Idle and Fan modes only.)
Also see page# 9 & 10 from this link--
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 28, 2009 | Heating & Cooling
Honeywell TZ-4 Misbehaving
there is a "zone a lone" switch on the upper right side of the panel. Make sure it is in the "occupied" position. I believe that is up. If that doesn't work reply back.
Feb 29, 2008 | Kitchen Ranges
Open Questions:
Heating & Cooling Logo
13 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
