Question about HP LaserJet M5035 MFP Printer
M5035 MFP stop received fax call report
How do I stop the Fax Call Report on received faxes with my M5035 MFP? I want to keep the Fax Call Report for outgoing but not incoming faxes.
  • 317 Answers
SOURCE: officejet 7310 HP
Follow the steps below to perform a fax diagnostics test. 1. Set up the all-in-one for faxing according to the setup instructions found in the product's User's Guide. 2. Make sure you have inserted the print cartridges and loaded paper before starting the test. 3. Press Setup, 6, and then 6. This displays the Tools menu and then select Run Fax Test. The HP all-in-one displays the status of the test on the color graphics display and prints a report. 4. Review the report. * If the test passes and you are still having problems faxing, check the fax settings listed in the report to verify the settings are correct. A blank or incorrect fax setting can cause faxing problems. * If the test fails, review the report for more information on how to fix any problems found. 5. After you pick up the fax report from the all-in-one, press OK. Then turn the printer off, and then on again. If necessary, resolve any problems found and rerun the test. If the test passes and you are still having problems faxing, check the fax settings listed in the report to verify the settings are correct. A blank or incorrect fax setting can cause faxing problems.
Posted on Aug 07, 2007
  • 5 Answers
SOURCE: Error 232 receiving fax
fax error 232 indicates a communication failure between the sending and receiving units. I'd check for line noise on the phone (you can hear it as cracks and pops) If your fax line is not dedicated, any noise from another phone pickup or an answwering machine can cause the failure.
Posted on Sep 08, 2008
SOURCE: not getting faxes
setup
Posted on Dec 12, 2008
SOURCE: I don't want fax receiving confirmation report it waste my paper.
Go to menu (wrench)
Arrow down to Reports - OK
Arrow down to Fax Reports - Ok
Hit Ok at Fax Confirmation
Select Never and hit OK
Hit Cancel when done and it should now not print confirmations.
Posted on Jan 15, 2009
frcs68
  • 1605 Answers
SOURCE: BLOCKED CALLS
If you subscribe to a caller ID service through your phone provider, you can block
specific fax numbers so the device does not print faxes received from those numbers.
When an incoming fax call is received, the device compares the number to the list of
junk fax numbers to determine if the call should be blocked. If the number matches a
number in the blocked fax numbers list, the fax is not printed.
Set the junk fax mode
By default, Block Junk Fax mode is turned On. If you do not subscribe to a caller ID
service through your phone provider, or do not want to use this feature, you can turn
off this setting.
To set the junk fax mode
▲ Some models have a Block Junk Fax button. Depending on the model you have,
do one of the following:
Block Junk Fax button: Press the Junk Fax Blocker button, select the Block
Junk Fax option, and then select On or Off.
Color display menu: Press Setup, select Basic Fax Menu, select Junk Fax
Blocker Setup, select Block Junk Fax, and then select On or Off.
Add numbers to the junk fax list
There are two ways to add a number to your junk list. You can select numbers from
your caller ID history, or you can enter new numbers. The numbers in your junk list are
blocked if Block Junk Fax mode is set to On.
Posted on Feb 11, 2009
Looking for a report that says that the faxes have gone please.
1. From the Home screen, touch Administration.
2. Touch Information.
3. Touch Fax Reports.
4. Touch one of the following buttons to print the corresponding report:
? Fax Activity Log
? Fax Call Report
? Billing Codes Report
? Blocked Fax List
? Speed Dial List
5. Touch Print.
For more information, see the fax guide that came with the device.
Aug 30, 2011 | HP LaserJet M5035 MFP Printer
We keep receiving a T.30 Protocol Trace Report with the "Type: Receive" and "Result: Communication Error (17)". How do we figure out what this means? Thnaks.
If this is printing out and consuming a lot of paper it can get annoying. This report is intended for a technician to trace problems with your machine. The report basically tells you that your fax attempt failed and gives all the technical settings. To the average user this is meaningless. The print feature for this is normally turned off, but I have seen a few cases where the default was set to print. Under the diagnostics menu, find the T-30 error setting and set it to never. Check the firware on your printer to make sure it is current. Print the configuration page and check the firmware version on the front page. The current version is 48.181.8. There are many modem fixes included with the firmware.
May 23, 2011 | HP® LaserJet M5035 MFP Laser...
How to I turn off the automatic printing of the fax logs.
To change fax confirmation
1. Press Setup.
2. Press Print Report, and then Fax Confirmation.
3. Press the right arrow button to select one of the following, and then press OK.
Off - Does not print a fax confirmation report when you send and receive
faxes successfully. This is the default setting.
On Fax Send - Prints a fax confirmation report for every fax you send.
On Fax Receive - Prints a fax confirmation report for every fax you receive.
Send & Receive - Prints a fax confirmation report for every fax you send and receive.
May 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
I have trying to configurate the fax on an hp mfp 5025 and dont know the password for the service menu
You do not need to get into the service mode to program the fax on this unit. Fax settings are done from the control panel. Administration>Initial setup>fax setup.
Follow the send and receive menus to set what you need to.
Feb 19, 2011 | HP LaserJet M5035 MFP Printer
How can I get a FAX Confirmation printed out on the HPJ4680?
If you require printed confirmation that your faxes weresuccessfully sent, follow these instructions to enable fax confirmation beforesending any faxes. The default fax confirmation setting is Off. This meansthat a confirmation report is not printed for each fax sent or received. Aconfirmation message indicating whether a fax was successfully sent appearsbriefly on the control-panel display after each transaction. NOTE: You can include an image of the first page of the faxon the Fax Sent Confirmation report if you choose On Fax Send or Send &Receive, and if you scan the fax to send from memory To enable fax confirmation
1.Press the (Setup) button.
2.Press right arrow to select Print Report, and then press OK.
3.Press right arrow to select Fax Confirmation, and then press OK.
4.Press right arrow to select one of the following, and then press OK. Off Does not print a fax confirmation report when yousend and receive faxes successfully. This is the default setting. On Fax Send Prints a fax confirmation report for every faxyou send.
OnFax Receive Prints a fax confirmation report for every fax you receive.
Send& Receive Prints a fax confirmation report for every fax you send andreceive
Jan 10, 2011 | Office Equipment & Supplies
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
each transaction.
1. Press Setup.
2. Press 2, and then press 1.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
How do I tune my fax machine so that each time I send a fax I get an individual delivery report?
Press funcktion ,dataregistration,scroll down until you get report settings,press ok and scroll down to tx report,press ok and change to output yes.
Then you will receive a report for every fax you send.
Mar 20, 2009 | Canon L295 Plain Paper Laser Fax
01.12.2008 i fax to one number. now i want aknowledgement of that fax. its gone or not. How i can find on HP Officejet 5610 all in One System?
You can get the manual here if you do not have one - LINK.
Here is an exert form the manual on this:
1. Press Setup.
Send &
Receive
receive.
Dec 10, 2008 | HP Officejet 5610 All-In-One InkJet...
FAX CONFIRMATION PAGE
Touch ADMINISTRATION then touch CONFIGURATION PAGES then MENUMAP and that will print a guide for you to look for FAX REPORTS and when to print them. You can also have a thumbnail put on a report
Aug 06, 2008 | HP LaserJet M3027x MFP Printer
HP LaserJet M5035 MFP Printer Logo
20 people viewed this question
Seeker5211
Seeker5211
