Question about Toshiba DKT-2020-SD telephone
What do i need to be able to use this phone with a headset? I have a plantronics headset but not sure if an adapter or something else is needed to enable multi line use
  • 50 Answers
For headsets no adapter is required all you have to do is plug into
the proper headset socket
Posted on May 10, 2014
Can't hear my pc to head set..can u help
Hearing a Plantronics Voyager 510 headset through a computer:
To use a Plantronics Voyager 510 headset through your computer, you either need a USB Bluetooth adapter or you must have Bluetooth built in to your computer. Once the Voyager 510 headset is "connected" to your pc (by one of the mentioned ways), you may need to go into the control panel on the computer or the specific software program being used to set the Plantronics Voyager 510 headset as the "default device". Keep in mind that the headset has to be powered on and to also have to activate the headset to connect to the Bluetooth adapter or computer.
Good luck from Headsets Direct - 800-914-7996.
Aug 20, 2011 | Plantronics 510 Voyager Headset - PLN-510...
My m100 bluetooth always calls the wrong person.
Plantronics M100 always calls the wrong person:
Unfortunately this is a common occurrence. We say one name and it says, "did you say..." something totally different. I think that most of us has had that experience. The Bluetooth headsets that have a longer "boom" type mic will pick up your voice better and have a better chance at hearing your voice properly the first time. Models like the Plantronics Voyager Pro+ and the WG100/B have a boom type microphone. The WG100/B also includes a UBS Bluetooth adapter so it can be used on a pc.
http://www.headsetsdirect.com/plantronics-bluetooth-headsets/bluetooth-for-mobile-phones/voyager-pro-bluetooth-headset.html
http://www.headsetsdirect.com/plantronics-bluetooth-headsets/computer-mobile/wg100-b-savi-go-wireless-headset-mobile-computer.html
Aug 04, 2011 | Plantronics M100 Bluetooth Headset
I have a Plantronics Voyager Pro and it will not take a charge. I plugged the charger into my phone to check it and it does work on my phone except not with my blurtooth. Thanks for your help.
If you have the Plantronics Voyager Pro headset, you should be using the ac adapter that came with the headset ( model 79414-01 ). If the headset will not charge, it could be broken or the internal battery may be worn out. Keep in mind that the Voyager Pro has a one year warranty, and Plantronics will replace it within the warranty period.
Plantronics Voyager Pro Headset
AC Adapter for Voyager Pro Headset
Good luck from Headsets Direct!
Feb 28, 2011 | Plantronics Voyager PRO Bluetooth Headset
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
We are experiencing a lot of static from the headsets - when the phone is muted the other people on a conference call won't hear the static, but once the mute is off then the static is back. There are at...
Try re-pairing the headset to the Plantronics 500A base unit to make sure that it has a good connection. And of course you also need to be within the 30ft range of the 500A base, and you can typically only use around 6-7 of those units together in the same area. Here is the link for the pairing instructions:
Plantronics Voyager 510S Pairing Instructions
Sep 22, 2010 | Plantronics Voyager 500A Deskphone Adapter...
Base unit won't work. Won't answer phone. Blue light is out and pressing switch doesn't get a response.
You want to make sure you have the approved Plantronics AC adapter, and it's plugged into a wall outlet, and connected securely to your base. If the lights don't come on like they should, carefully follow the compatibility and pairing instructions in the manual (see link below) and check to see how the base responds. If you're still having problems, then in the words of Doctor McCoy: "He's dead Jim."
Plantronics Voyager 510S User's Guide
Sep 10, 2010 | Plantronics Voyager 500A Deskphone Adapter...
My Headset does´nt have dialtone, I was connecting to cisco phone 7941, 7970, 7911, and nothing, not work.
You can use a Plantronics S11 headset with a Cisco phone, however it is not the best compatible solution. To use an S11 with a Cisco phone, you have to make sure that you are plugging it into the handset receiver jack and not the headset jack. You will need to lift the handset receiver, set it off to the side, and then hang it up after each call. If you want a more compatible solution that you can plug into the actual headset jack and just press the headset button on the telephone to answer and hang up, then you would need one of the Plantronics "H-series headsets" with the Plantronics Cisco direct connect cable ( model 26716-01 ).
Plantronics 26716-01 cable
Plantronics H Series Headsets
Aug 12, 2010 | Plantronics S11 Headset
Toshiba laptop with IOgear bluetooth adapter installed will recognize phone but won't detect plantronics explorer headpiece. I would like to use it to chat on skype
If the Bluetooth adapter can detect the phone but not the Plantronics headpiece, then there's no problem with your computer or your Bluetooth adapter. The problem has something to do with the Plantronics.
Try to turn the headpiece off, then turn it back on. Set it to discovery mode, then try to detect it using your computer. If that did not help.
Try to detect the Plantronics, using your phone. That will help you in isolating the problem.
Aside from that, make sure that no possible wireless interference while you're searching for the headpiece. Cell phone, base of the cordless phone should be away from the computer while you're searching for the headpiece. Because Bluetooth and cellphones/cordless phones are running on the same 2.4GHz frequency RF signal. They might interfere with each other.
Apr 14, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Toshiba DKT-2020-SD telephone Logo
54 people viewed this question
Top Toshiba Lands Phones Experts
george  peters
george peters
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
