Question about Eddie Bauer XRS 65 Convertible Car Seat
Where do I place locking clip on a eddie bauer xrs 65 convertible car seat?
  • Eddie Bauer Master
  • 1,629 Answers
Please contact Dorel USA directly for assistance where do I place locking clip on a eddie bauer xrs - 9a8ea2de-93f0-4a05-add1-8d4188ade911.jpg
Posted on Oct 19, 2014
SOURCE: eddie bauer car seat 22740 manual
Go to http://eddiebauer.djgusa.com/instructions/ and search for your model number.
Posted on Oct 30, 2008
  • 25 Answers
SOURCE: how to install infant car seat
The two clips are both for the LATCH system - they're not top tethers (which go to the back of the seat for forward facing seats only).
You need to choose EITHER the LATCH installation OR the seatbelt installation - doing both together can put too much stress on the belt path of the seat, causing the plastic to weaken.
If your car has the LATCH system, there will be two metal U-shaped anchors in the seat, where the seat back and the bottom of the seat meet. Some cars only have them for the side seats, not the middle, so check your car's owner's manual - if you don't have them specifically for the center seat, you'll have to either install with the seatbelt or put it in a side seat to use the LATCH - don't try using one anchor from each side, as they won't be the proper distance apart.
If you'd prefer to use the seatbelt to install, kneel with all of your weight in the seat to tighten the seatbelt. It's tight enough when it can't move more than 1 inch from side to side if you grab it at the belt path and pull it back and forth. You probably will still be able to pull the TOP of the infant seat back towards the back of the seat of the car - that's not a problem - it helps the seat to cradle the baby through an accident.
You need to have an owner's manual, though - to request a copy, contact their customer service at consumer@djgusa.com or call them at 1-800-544-1108.
Posted on Feb 18, 2009
  • 50 Answers
SOURCE: How do I convert my car seat to a boster seat
Remove the large bar holding the bottom plate. One side will have a plastic retainer which you just move to the side and pull the barr all the way out from that side. There is a rear leg that you can pull down and back which will make the seat sit more upright. Remove the strap (it is one solid strap) and be sure to save all the parts if you plan on giving it to a needy family when your child outgrows it. The center clip is easy to remove, turn the seat upside down and find the metal retainer and pull it up, turn 90 degrees and feed it through the hole and pull on the other side. Now you should have a strap/clip free seat that will be a "seatbelt positioning booster seat".
Posted on Jan 24, 2010
  • 45 Answers
SOURCE: Eddie Bauer Booster Car Seat 22-880 how to take covers off
The manufacturer's instructions are the final authority - don't trust anyone else giving you instructions! Here are the links to download Dorel/Eddie Bauer carseat instructions:
Canada:
http://www.eddiebauer.djgusa.com/can/eng/instructions
USA:
http://www.eddiebauer.djgusa.com/usa/eng/Instructions
Posted on Mar 25, 2010
SOURCE: No manual
I was just looking online for an Eddie Bauer car seat manual too. There was a sticker on the seat with the manufacturer's URL, so I went to:
The manual for mine apparently is not available online, and the message that came up after I entered the information they wanted said:
Thank you for contacting Dorel Juvenile Group. At this time we do not have your instruction manual available for download. Please contact Consumer Relations by email at consumer@djgusa.com, by fax at 1-800-207-8182, or by phone at 1-800-544-1108 and your instruction manual will be sent to you.
Posted on Jan 13, 2011
I need to put the shlder/lap strap back in
the center of the belt will be under the seat coming up through the holes, place the two clips on the strap followed by the chest clip, then the neck protector pads. Push the ends of the strap through the two top holes. Route it down over the metal but under the plastic (on the back side) and attach both ends to the metal adjuster underneath. The receiver clip, you just turn 90 degrees and push through desired hole until the end catches.
Jan 24, 2010 | Eddie Bauer 3-In-1 with Latch
How do I convert my car seat to a boster seat --I have an Eddie Bauer Deluxe 3-in-1 Car Seat
Jan 18, 2010 | Eddie Bauer 3-In-1 with Latch
I have an Eddie Bauer car seat. I have no locking
Locking clips are available at many retailers that sell carseats; WalMart, Toys R Us, etc.... They're just a few dollars but you may have to ask where they are. You may also check with friends. Newer cars don't require locking clips because the belts lock automatically when they retract after being fully extended. Therefore, a friend with a newer car may give you the clip that came with her seat. Good luck!
Oct 10, 2009 | Baby Gear
I have an eddie bauer HB3C 22-89c-BGL please send
hi i wash he coution of my eddie bauer highback 22-89c-bgl and now im having problem putting the belt togeter in their original place
Sep 28, 2009 | Eddie Bauer Baby Gear
I need to replace the plastic latch on a costco 02-480-WAL car seat. Is there a place to find replacement parts?
I've just had this same issue with an eddie bauer car seat, they are made from the same people. They no longer sell the replacement harness clips in canada for cosco/eddie bauer, you have to contact the company directly. http://www.coscojuvenile.com/can/eng/
Aug 14, 2009 | Cosco Baby Gear
Need information on how to take off harness and re-attach it
On our Edddie Bauer car seats, you have to remove the base from the chair by pulling out the metal rod that goes through both pieces. It only comes out from one side. Then there are several plastic "clips" that the straps run through and hold the fabric in place. Gently pry these clips with a flathead screwdriver by sliding the tool under the clip base and pushing in while lifting up. The arm-rest covers should just be wrapped around and come off easily. Make note of where all the straps go through as it is a little confusing puttting it all back together.
Jun 21, 2009 | Eddie Bauer 22-858 Shelton Booster Car...
Hi, I am looking for the manual to go with an Eddie Bauer 22-756
Go to the eddie bauer website, search for your model, by date it was made and model type, and u can download the manual
May 02, 2009 | Eddie Bauer 22757MRC Convertible Car Seat
Im trying to dtach my eddies bauer base to convert into a booster seat
There's a round metal bar that runs thru the bottom of the car seat. Remove this bar and the base immediately comes off.
Apr 01, 2009 | Eddie Bauer Deluxe 3-in-1 Convertible
Booster seat
Converting the seat to a booster: (Alpha Omega Elite Deluxe 2004 version, Eddie Bauer)
After all said and done, the base can probably be left on, it helps to recline the chair when the child is asleep. If you want to leave it out, the manual says the base can be removed for narrow vehicle seats or airline use. Locate the center bar at the bottom of the seat, push the tab at the end of the bar and pull the bar out. The seat can then be separated from the base. The seat has a "kickstand" that can be pulled out to sit the seat upright. Put the bar back in the base so you don't lose it.
To remove the harness, remove the base first. Then from the back of the seat, unfasten the harness from the harness bracket. Store the bracket by looping it behind and around the back spine of the shell. You can unthread the harness from that point and pull it out. From the bottom of the seat, locate the buckle's metal clip. Insert the clip up through the shell and pad, from the front pull the buckle free from the shell. Lock latch plates into buckle for safekeeping.
Once the seat is converted to adult straps don't use the latch system; hook the hooks together to keep it from swinging around, and place the top anchorage strap behind the seat with the anchor hook under the seat.
Nov 09, 2007 | Eddie Bauer 3-In-1 with Latch
Eddie Bauer XRS 65 Convertible Car Seat Logo
76 people viewed this question
Top Eddie Bauer Baby Gear Experts
Jennifer Rock
Jennifer Rock
woodzowl307
ray gallant
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
