Question about Whirlpool LSN1000LW Top Load Washer
Whirlpool top loading washer works on delicate cyle but not other
M daughters washing machine runs and never fills up but she said that when she put it on delicate cycle it worked correctly. what could be the problem and maybe we can fix it ourselves and save a little money. can anyone please help with this problem. thanks linda
Thank you sooo much we were able to fix it thanks
Posted on Jun 26, 2009
Hi, I am trying to help daughter-in-law get their
Hello annp, thank you for your post! Based on the symptoms you are describing, it does sounds like a siphoning issue. Generally speaking, the drain hose should come up above the washer tub and please make sure the drain hose is not too deep in to the house drain pipe. The drain hose should only be submerged 4-8 inches into the house drain pipe. If correct, otherwise the unit might be experiencing a communication with the control board and water fill valve. At this point, please reach out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - please do not hesitate to reconnect.
Jul 31, 2013 | Frigidaire FGX831C Top Load Stacked Washer...
I have a 15 yr old Whirlpool washer that has run great. During a cycle, it stopped full of water. I moved the dial around to different areas pushing it in and out and got a cyle to run long enough to pump...
Not always a Timer issue. could be stopping at the cold fill part of the cycle which is the 8 o clock position on the dial. This would be fault with the cold fill vavle.
Sep 15, 2010 | Whirlpool LXR6432JQ Top Load Washer
Water left in machine (clothes dripping) after delicate cycle
Whirlpool is best in the standards of top loading washing machine when you are going for the front loading you can buy the IFB washing machine to get the better result
May 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer stops after wash cyle
need to check out the DRAIN MOTOR PUMP located at the bottom side , the motor with the propellers , it could be clogged , get some rags and remove PUMP to remove any lint or debris , replace and give it another try , hope it helps AJ
Sep 18, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washer won't rinse & drain
The lid wasn't locking in all the way- when we put something heavy on top of the latch it started working.
Sep 15, 2009 | Whirlpool Washing Machines
Washing machine fills, but won't agitate
We have not heard back on this in about a week. I'm presuming It's been repaired?
Jun 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LSN1000LW Top Load Washer Logo
103 people viewed this question
Dan Webster
Dan Webster
Sal De
