Question about Home
Nortron smoke detector
My nortron smoke detector (model:tr8ws) is making sound every 20mins.what to do?
  • 23 Answers
It may be urging you to change the battery...
Posted on May 09, 2014
    Champion:
  • 216 Answers
Replace backup battery. Clean or replace detector if still chirping after battery replacement and cleaning. All detectors have a service life and if it is old better safe than sorry.
My nortron smoke detector hard wire has no battery does it need one
It should make a noise if it has no battery after all, electrical fault means house burns and no mains power so no smoke alarm. A bit fundamental.
Aug 19, 2017 | Home
We have a Nortron Modrel TR8WS, 120 Vac 60 HZ Single station The alarm does not stop beeping, even with the power off. How can we stop the beeping?
The smoke alarm lady. Read my other message to you how to fix it, and a cautionary tale.
Here is your unit if you need to replace it.
Nortron Modrel TR8WS Google Search
Feb 23, 2017 | The Audio Players & Recorders
Where are batteries on model ac12w
Am unable to find much information on Nortron Model AC12W detectors. I do know they are pretty old and may not have a battery back up. Because of the age you may want to think about replacing the detector.
Jan 14, 2016 | Home
I have 6 smoke detectors & two CO2 detectors hardwired in. The smoke detector in the kitchen went off and now all the detectors will not stop alarming. How do I reset?
First of all, you really should not have a smoke detector in the kitchen as it will be far too prone to false alarms, especially since most household smoke alarms are ionization type, which respond to the presence of gases caused by combustion. A proper system as recommended by NFPA will have one detector in each bedroom, one in each bedroom hallway, and recommended one per floor thereafter, with placement being near exit points to help guide you to the exit during an actual fire (by sound, since it's difficult to see through smoke). I would be inclined to remove that device or try to find a heat detector replacement, such as Kidde Model # HD135F. For now I would vacuum out the device or try a can of compressed air to blow it out, but I would not leave that device long term.
Sep 13, 2015 | Home
How do I troubleshoot an intermittent problem with a 2 wire system sensor smoke detector
Intermittent problems are often difficult even for professionals. That said, I would need more specifics on the problem if you want to continue on your own first. The model of the system, keypad indications, whether the problem is a trouble or alarm, what make/model the detectors are (there could be more than 1 type on a 2-wire fire zone), etc.
Oct 14, 2014 | Home
Had customer with CO detector sounding quick double chirp about every five minutes. What is this?
This is not a beeping smoke detector. It is probably a CO detector that was installed by your alarm company. GE model 240-COE will give a double beep every 5.5 minutes when the device reaches end of life. Call your alarm company to have it replaced.
Jun 07, 2014 | Kidde DC Voice-Alert CO and Smoke Alarm
bro there is a possibility that the sensor is going off due to power surges while using the dryer, turning it on and off will cause power fluctuations, you need an electrician to measure the current\voltage while you which on the dryer, if this is the cause he will advise you on how to avoid future false alarms.
vinaka from fiji
Feb 05, 2018 | Kenmore Dryers
I just replaced 3 old interconnected Nortron AC 12W smoke alarm with 3 kidde direct wire 120V units- ( no battery back-up) when i turn the AC breaker on- all three Kidde chirp every 10 seconds. I ...
The Kidde website does have a lot of manuals but you need the model number. Try going to this URL, then browse by subject. You'll probably find the answer there.
Jul 24, 2011 | Kidde 120-Volt Front Load Battery Smoke...
Our hard wire smoke detector model i12060 just beeped really lound a few times and stopped, it glows green and flashes red every few minutes?
Change the 9V backup battery,with a new one.Push and hold the reset button for a minute or two for the alarm to to go off like about 30-40 sec. for the smoke detector to dectected the 9V backup battery power sourced.The green power LED light indicator will stop flashing also the beeping sounds too.
Jul 12, 2011 | Kidde 120-Volt Front Load Battery Smoke...
BRK smoke/co2 detector - won't stop beeping
sometimes the alarms are ganged to other apartments .. that's so if there is a fire in one apartment then others are alerted as well .. so the low battery warning could be from a neighbor ... also there may be a common ceiling space that will allow you to hear your neighbors detector .. at any rate someone around you has a low battery in their detector .. if they are ganged then that may be an apartment management maintenance item ..
Sep 19, 2009 | Kitchen Appliances - Others
Home Logo
624 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
