Question about Tanaka Garden
What is the two stroke mix for tanaka tht 262
5 Suggested Answers
  • 124 Answers
SOURCE: my blade on my tanaka tht-2108 is very slack
The blades need to be adjusted. Take this to the dealer where you purchased the blades. This adjustment is important and could damage your blades.
Posted on Sep 13, 2009
jyackle5
  • 8197 Answers
SOURCE: parts list tanaka hedge trimmer
You can get the service manual on link below.
http://tanakapowerequipment.com/pdf/serv/Tanaka_HT_Service_Manual.pdf
On this link below is the parts list.
http://www.tanaka-usa.com/pdf/dpl/hedge_trimmers/THT-2100dpl.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Posted on Jun 27, 2010
eugbug
  • 479 Answers
SOURCE: where in ireland can i get parts for a tanaka THT
Try http://www.gardenmachinery.ie/
They have a list of dealers who may supply parts.
Posted on Dec 10, 2010
SOURCE: Tanaka THT 1800 Hedge Trimmer
2% (50:1)
see http://tanakapowerequipment.com/pdf/manuals/Hedgetrimmers.pdf
Posted on Jun 03, 2011
Hedge trimmer
possible problem with dirt or blockage in the main jet of the carby
remove carby and blow out all holes and jets
fit new diaphragm
ensure that the oil / fuel mixture has not excessive oil in the mix
do not use e-mix fuel
Aug 10, 2016 | Tanaka Hedge Trimmer Tht-2100 Trimmers...
How to mix fuel for the engine?
50:1
100ml of 2 stroke oil into 5L of petrol
Apr 19, 2016 | Tanaka Garden
THT-210, what is recommended fuel mix
50: 1
100ml of oil in 5L of petrol
Feb 17, 2015 | Tanaka Garden
Tanaka TBC 160- very hard to start, any suggestions for possible reasons? Replaced the gas mix but it starts up & then stops running. tried new gas mix, checked throttle- seems to operate, Any...
hi there
paul 46 here.
all being well and compression and spark and timming , muffler is clear , carby is clean , and diaphrams are all ok , fresh mix , and fuel filter and lines are good
does the unit run with 2 stroke mix in the plug hole - ?
if yes assume compression and spark are ok,, if no check compression and spark and muffler
will the unit run with 2 stroke mix sprayed into the carby throat ?
if it does sounds like you have a air leak somewhere in the intake system
could be at barrel base gasket, c/case joint, manifold boot/ block gasket, carby gasket , impulse hose ,if this unit has one , c/case main seals leaking
2 strokes need air tight c/cases in order to pump fuel / air / oil mixture from c/case to cylinder
and to create a vacuum for entry of fuel/ air / oil mix from carb to c/case
symptoms of air leak are -: hard to start, wont idle, stalling, low power, inconsistant idle, over rev
overheat
pressure and vacuum testing can be done by blocking off intake and exhaust with rubber and metal plates , then fitting adapter to spark plug hole , and placing piston at bdc , pressureise cylinder to 7 to 8 psi of pressure and check areas , base gasket, manifold joint, main seals, , impulse hose ? for leaks with soapy water - if leaking bubbles will be evident
if no leaks and pressure is held at 7 psi for at least 2 minutes with dropping - presure test is good
next do the same test using vaccuum again go to 20 - 30 inch / vaccuum
if vaccuum held unit is ok
suggest take a good look at carby particularly if P and V test are good and spark coil tests good with a coil load test using a spark gap of 6.00 mm to stress the coil ( simulates spark under compression load)
have a look and let me know what you find
cheers pauly46
Apr 30, 2011 | Tanaka Commercial Grade "Inspire" Design...
Where in ireland can i get parts for a tanaka THT 2100 hedge trimmer
Oct 20, 2010 | Tanaka Hedge Trimmers: 20" Dual - Sided...
Parts list tanaka hedge trimmer
Jun 27, 2010 | Tanaka Hedge Trimmers: 20" Dual - Sided...
Garden Logo
140 people viewed this question
Top Tanaka Garden Experts
john h
wadingriver
wadingriver
Are you a Tanaka Garden Expert? Answer questions, earn points and help others
