Question about Northstar 952 GPS Receiver
The control unit FS-2571C's screen only shows "now initializing..."
KYOCERA FS 1118 MFP SHOW ERROR CODE C6000 WHAT B I CAN DO
replace the fuser will fix that. Or if you want to stip it down check the lamps and if their ok change the thermistor and thermostat. But your better off just replacing the whole unit
May 04, 2014 | Kyocera FS-1118 Printer
FS1128 whats the setup for dev on this?... is it like the CS2550 ? U130
1-5-5 Developing section
(1) Detaching and refitting the developing unit
Procedure
1. Open the front cover.
2. Remove the developing unit.
3. Check or replace the developing unit and
refit all the removed parts.
NOTE:
When the periodic maintenance (replacing
the maintenance kit, see page 2-4-4), perform following maintenance modes.
1. U251 Clearing the maintenance count (see
page 1-3-39)
2. U111 Clearing the drum drive time (see
page 1-3-33)
3. U130 Initial setting for the developing unit
(see page 1-3-34)
Jan 28, 2013 | Kyocera Ecosys Fs-1128mfp 30ppm All-in-one...
SA-HT730 need help with the above problem it just shows INIT and nothing else happens
Are you trying to reset the password for Ratings or re-initialize the unit to all factory defaults?
http://www.retrevo.com/support/Panasonic-SC-HT730-Home-Theater-Systems-manual/id/356ci961/t/2/
Page 27 shows one instance of INIT.
Re-initialize Setting
This returns all values in the Setup menus to the default settings.
≥Yes: The password screen is shown if "Ratings" (??? page 26) is set. Please enter the same password. After "INIT" on the display disappears, turn the unit off and on again.
≥No
Page 36 shows how to reset everything.
You have forgotten your ratings password. Reset all the settings to Factory Preset.
While stopped and "DVD/CD" is the source, press and hold ['Square Icon' button for STOP] on the main unit and [S10] on the remote control until "Initialized" disappears from the television. Turn the unit off and on again. All settings will return to the default values.
Jan 13, 2011 | Panasonic SC-HT730 System
I have a kyocera FS-2000D with error code: Call for service 0150:0000049. Help...thanks in advance
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
May 20, 2010 | Kyocera FS-2000D Laser Printer
Sony ericsson k750i mobile is do not shown display,only white flash is show in my mobile screen. when i switch on the mobile all programme are don't showing but all functions are working.
1.repair erom
2.flash main. K750i_CXC125955_HongKong_R1CA021_Red49.ck75sw
3.flash fs. K750i_CXC125953_HongKong_R1CA021_Red49.ck75fs
4.Customize FS
5.Shutdown FS
Jun 24, 2009 | Sony Ericsson K750i Cellular Phone
Panasonic dvd home theatre system,
Try restoring your unit to factory shipping conditions:
Press stop button on the main unit and (>10/ENTER) on the remote control at the same time for about 3 secconds, you would see the message "Initialized" on your tv screen, Once the message disappears from the tv, let go of the buttons. Try this and let me know.
Jun 08, 2008 | Panasonic Audio Players & Recorders
NEC fs 5197 tv blank screen
I cannot assist but do you please have an owners manual for the FS 5197. I'm not sure if its against this sites "rules" but little fingers have tuned the menu's instructions into Arabic. Contact me directly at factotum.inter.alia@gmail.com. Thanks
Feb 10, 2008 | NEC-Mitsubishi AccuSync LCD72V 17" LCD...
FS-85USB, 2 problems
According to the manual:
1. Start the Digital Voice Editor
2. Select [options] from the [tool] menu, click the [transcribing key] tab, and check the settings of the [enable transcribing keys] items.
Make sure they are as follows:
[playback] F10
[stop] F11
[skip forward] Ctrl + Right
[skip backward] Ctrl + Left
As to why it's hanging at the screen, have you installed the usb drivers for your operating system?
They can be found here:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=FS85USB
Jan 14, 2008 | Sony FS-85USB Desktop Digital Transcriber...
Northstar 952 GPS Receiver Logo
Top Northstar GPS Experts
Are you a Northstar GPS Expert? Answer questions, earn points and help others
