Hi, Sorry if this is a duplicate. .. issues uploading my original post... My Hotpoint DRYER TVM570 Aquarius is making a loud screeching noise occasionally. It isn't doing it every time my partner just used it for an hour with no issues. However I used it for 5 minutes this morning and it was like nails on a chalkboard. Thanks in advance
  • 1,140 Answers
It could be a loose or worn out belt.
Posted on May 29, 2014
  • 11 Answers
SOURCE: Hotpoint Aquarius 1100 - Grinding Noise From Drum
This sounds like the min bearings have gone, open the door and see if there is any play up and down on the drum. if so its the bearing if not it could be something that has fallen from a pocket and got stuck between the metal clothes drum and the oute drum casing. a take apart job i am afraid for both issues.
Posted on Feb 18, 2007
  • 145 Answers
SOURCE: dryer makes a loud noise then stops
If it stops running when hot it may be the motor. The belt or drum rollers would not stop it from running.
Posted on Apr 24, 2008
barkencoa
  • 3463 Answers
SOURCE: Hotpoint aquarius 1100 bangs while spinning
Several possible reasons for this. M/C not level, causing it to move about.
Overloading of m/c.
Loose concrete balance weight, there is one at top and one at bottom.
Suspension spring broken or unhooked.
Suspension leg loose or broken.
Main drum bearings worn, to check this, turn drum by hand and if it feels noisy or rough , then bearings have gone (expensive repair).
There are other possible causes, but these are the main reasons.
Plz rate my solution.
Thanks.
Posted on Dec 29, 2008
bostonguy08
  • 32 Answers
SOURCE: hi,i have a hotpoint aquarius wf340.which makes a
I had the same issue with a similar machine. Need to replace the spindle assembly (or otherwise make sure) that the belt is tight. Try replacing belt first.
Make sure machine is level. test it by putting some stuffed sockes in the machine, let them get thrown around. Listen for the banging noise, apart from the soft socks hitting the tumbler.
Posted on Aug 08, 2009
apart4u
  • 213 Answers
SOURCE: I have a hotpoint aquarius condenser tumble dryer
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Posted on Jan 10, 2010
My hotpoint Aquarius tumble dryer isn't heating, model tvm570
heating elements do burn out . call a repair service locally
Dec 02, 2016 | Hotpoint Dryers
Hi, My Hotpoint TVM570 Aquarius is making a loud screeching noise occasionally. It isn't doing it every time my partner just used it for an hour with no issues. However I used it for 5 minutes this...
wonder if you are overloading the machine and the noise is the drive belt screeching. if it sounds similar to a loose fanbelt on a car, it could be drum bearings that are seizing up (check by manaually rotating the drum. if it spins freely its ok) or the drive belt is getting worn and needs replacing
May 09, 2014 | Washing Machines
Hotpoint aquarius tvm570 dryer
Either the belt is broken or possibly the motor starter has failed. Very often the belt. Be warned though, modern day tumble dryers use stretch belts that can be very difficult to fit.
Oct 18, 2013 | Hotpoint Dryers
My Hotpoint Aquarius TVM570 started making a funny noise then cut out... I changed the fuse to see if it was that but no luck. You can turn the timer but as soon as you press 'start' it just trips...
if you check this link it shows the basics for getting in the dryer ,, after that , you may have to remove the vent tube inside ,, you will see a fan attached to the back of the motor, your missing Rib could be rubbing against that or possibly even the drum as it turns,, be sure and unplug the machine anytime you remove the back
Jun 12, 2011 | Hotpoint Dryers
Drum makes loud noise as rotates clockwise
put few clothes in it drum to switch on its ball in there
Oct 06, 2009 | Hotpoint Aquarius WD63 Front Load...
Hi,i have a hotpoint aquarius wf340.which makes a very loud banging noise every time it spins,it works fine otherwise!
Aug 08, 2009 | Hotpoint Washing Machines
Hotpoint WD 865- washes ok, dryer won't work makes loud popping
sounds like the dryer heater element has worked loose perhaps and shorted out against the metal dryer box which sits on top of the drum.
best to get an engineer out i'd say.
Jan 14, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius wd440g washer/dryer
Hi claire your problem is the pump braking down check to make sure there is nothing in the pump if you still cant get the door open pull the mains plug out and turn off the water valves red and blue take off the top of the machine and get a basin take the drain hose out and put it in the basin and bring the two down to the floor empty all the water out you should now be able to get the door open remember to check the pump and the bearings
Jul 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Oct 29, 2006 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
