I have water coming in to passenger footwell i think its through my pollen filter anyone know how to fix it
Lift bonnet, peel away rubber seal underneath windscreen towards passenger side, you should have water collecting, pull rubber bung out and water will drain. Best just to throw the rubber price away, it's not needed.
Try this site Mark
Vauxhaull Vectra Inside water Leak Problem Fixed Wet floor in the car...
SOURCE: My opel vectra leaked rain water possibly through
Yes it sounds like the drain pipe from the vent infront of the w/screen was blocked up as usual and it comes out down either side under the front mudgaurds as its the place were the wiper motor is fitted and the place that ****** the air from out side for your heater .so when its bunged up then yes it will overflow into the car through the heater vents,,so keep them clean with a 10lbs of air from a compressor.
DO about just after summer each year.. RON
and blow from the pipe under the mudgaurd up as it will only take you 10 minutes that way,just find the drain pipe ..
hi all sorted it found a blocked drain just under pollen filter which allowed bulkhead to fill up with water which then ingressed in through filter so all replies was appreciated
