Question about LG LS-L1210CL Mini Split Air Conditioner
What is pfc protection - LG LS-L1210CL Mini Split Air Conditioner
    Novelist:
    Champion:
  • 373 Answers
( Power factor correction ) Circuit protection on controls. The LG a/c is manufactured using the PFC and sign wave technology, By the PFC control, Raising the operating voltage from the existing DC 280 v to DC 380 v can be done. Thereby it makes operation smooth in high-frequency area. The sine wave control enables soft operation in low frequency area, Thereby expanding the product's operating range. This also markedly improves the product's energy efficiency. hope this helps
Posted on Jul 02, 2014
The red is blinking 8 times and green 4 times. The error charts states PFC circuit error. How can this be fixed ?
Power off at the isolator for 10 mins then switch back on and try again. If error code persists, then it is most likely the controller in the outdoor unit.
Excessive voltage of DC voltage on PFC circuit in inverter PCB is detected, or the excessive current in the circuit is detected.
> Permanent stop.
[Diagnosis Point]
Controller PCB defective (Refer to after mentioned "PFC circuit diagnosis")
Mar 21, 2015 | Fujitsu 15RLQ Halcyon Wall Mounted Mini...
What is pfc circuit error?
> Permanent stop.
[Diagnosis Point]
Jul 03, 2014 | Fujitsu Heating & Cooling
Panasonic a/c
F90 = PFC control
Abnormality judgement: 4 times occurrence within 10 minutes
Location to verify: Voltage at PFC
Jan 26, 2014 | Heating & Cooling
46RV535U 46 in. HDTV LCD TV where is the fuse
There are several fuses on the power supply board.
Usually the one that fails is not the main AC line fuse (which is close to the AC line input), but the PFC fuse located, you guessed it, next to the PFC regulator IC on the board.
When the PFC fuse is blown (measuring open) you also need to replace the PFC IC and possibly other components on the board. Most of the time the PFC is sufficient though.
Here's a link for repair service for the board:
http://www.coppelltvrepair.com/p/751/toshiba-46rv535u-power-supply-board-repair-service-for-dead-refusing-to-power-tv-or-faint-display-problem
Also search there for the TV model, we may have repair kits or exchange services available!
Hope this helps!
Jul 30, 2012 | Toshiba Regza 46RV535U 46 in. LCD HDTV
My PFC IGBT is blown again and again. I had tryed 60Amp and 1200Vots IGBTS. I also changed it OPto,s as well SG3525, and SG3854 with lm358N and c40660B. But problem did not reslove yet. now can you send...
Fixya is not associated with any manufacturer. So unless someone here happens to have the schematic you would have to get that from Liebert/Emerson.
Unless the igbt's are being overloaded then the usual suspect area is the driver/switching. Usually that section fails and they latch on and POP.
May 01, 2010 | Liebert UPStation GXT 2U GXT2-1500RT120...
I have a 2006 Dodge Charger Daytona R/T. What
O'reillyAutoParts Brake Best Select - Brake Pads Part Number: SM1057B Line: BB
  • Rear
  • Semi-Metallic Pads
  • Police Package
  • With Heavy Duty Brakes
  • Limited Lifetime Warranty Performance Friction - Brake Rotor Part Number: 348.067.01 Line: PFC
    • Police Package
    • Rear
    • Limited Lifetime Warranty $139.99 Each
Brake Best Select - Brake Pads Part Number: SM1058 Line: BB
  • Front
  • Police Package
Performance Friction - Brake Rotor Part Number: 342.055.01 Line: PFC
  • Heavy Duty
  • Front
$132.99 Each
Apr 29, 2010 | 2006 Dodge Charger
My ups cannot give backup when AC power fails no power supplied to PC then PC is restarted but i replaced a new battery but no result found. What is the solution for this problem ?
It sounds like you have a computer with an Active PFC (Power Factor Correction) Power Supply.
Back-UPS units, when running on battery power, output a Modulated / Stepped Sign Wave. Active PFC Power Supplies are NOT compatible with this pseudo-sign wave power, which is the reason it will not stay running.
You need a Smart-UPS unit, capable of delivering a true sign wave when on battery output.
Feb 13, 2010 | APC Back-UPS 400VA (BK400) UPS System
Toshiba e-studio 160, c56 error code.. how can i reset this code.. pls help me..
C56 indicates Communications error between the PFC and the CPU on the main PWA. What u can do:
1.Check if the connector CN36 or CN35 on the relay PWA is disconnected.
2.Check if any conductor pattern (PFRXD, PFREQ, PFACK, MACK/PF, PFTXD, or MREQ/PF
between the IC, IC2 and CN36) on the relay PWA is open- or short-circuited.
3.Replace the relay PWA.
4.Replace the PFC PWA.
5.Replace the main PWA.
Jan 25, 2010 | Toshiba e-Studio163 Copier
When the message call for service is displayed, I pressed the C key and the 8 key at the same time an alpha numeric code C56 appeared. how do i go about from here?
Communication related service call C56-Communication error between PFC and M-CPU
(1) Check the signal patterns (REQ, ACK, RXD, TXD) between IC11 (G/A) and IC21 (PFC) on the
LGC board for open-or short-circuits.
(2) Replace the LGC board.
Jan 25, 2010 | Toshiba Office Equipment & Supplies
LG LS-L1210CL Mini Split Air Conditioner Logo
85 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
