Toshiba mini,I replaced screen now I have error code realtec issue something about the cable being unplugged. I double checked all connections, and all connections are in properly.i read it was a bad hard drive so I tried other hard drives and I get the same error code. Only one works and its password locked.help please
  • 151 Answers
Realtec is mainly sound and network, if it says cable unplugged it's likely the network. The antenna for wireless is usually embedded in the screen part so it could be that unplugged.
Posted on May 09, 2014
maklean
  • 1665 Answers
SOURCE: Trouble Reloading Start-Up Disk on Toshiba Satellite 1905-S301
Checl all internal cable connections (unplug-plug
Check all internal cable connection to be correct, start and observe messages to see if your HDD is recognized by bios and memory test is ok.
If problem remains try to boot from CD with original operating system disk in CDROM.
Posted on Mar 07, 2008
IB4G2008
  • 3587 Answers
SOURCE: New Laptop Optical Drive Causes 0203 failure ide #2 error at boot
it's in the bios, hit F2 when it's booting, and go to drives, and set it from there..you will see them..you may need to turn them off, and then restart, then F2 again, and then turn them back on.
check your computers warranty here 4 FREE
Posted on Mar 13, 2008
SOURCE: Compaq Presario Laptop ERROR CODES
on boot into post select F10 enter the bios - correct boot order to dvd 1st hdd 2nd and fdd as 3rd boot devices - highlight network boot and hit enter then disable boot from network the hit F10 to save and exit unit will boot from dvd unit with recovery dvd disc installed
Posted on Mar 03, 2009
  • 298 Answers
SOURCE: Replaced hard drive in Toshiba Tecra M9. Laptop.now refuses to re
Look on the back edge of your old HDD where all the gold pins are and on one side there is a group of 4 pins in two rows of two... and see if there is a tiny jumper installed across two of them (white or black about 1/8" tall and 1/16th wide).
Now look on the new HDD and see if there is one there. The NEW HDD must be set up exactly like the OLD one or it won't be detected by BIOS or Windows.
I am beginning to think your LT has the CD as MASTER and the HDD as SLAVE, which may require adding or removing a jumper. Some new ones come with, some without ;-) I didn't think of this earlier
Check that. Email me the result
Posted on Mar 27, 2009
dnewcombe1
  • 1564 Answers
SOURCE: Toshiba Qosmio laptop with Phoenix securecore
You've probably got to have your computer configured to boot from a rescue CD before it can recognize and install the new harddrive. Also make sure that there is an operating system installed on the hard drive . If not it will not do anything until you install one. This will be automatic if you install a new XP or Vista DVD into the computer's DVD drive the reboot.
Posted on Sep 07, 2009
Testimonial: "I'll go out to Toshiba and get a rescue disk. FYI:I booted up with an XP disk to try to load the OS, but keep getting the blue screen"
Fault3e coming up onscreen
Faulty motor in your washing machine.
Samsung uses the 3E error code to indicate a drive motor tach fault. If that sounds complicated, it's not. If you're handy, you can fix your Samsung front load washing machine error code yourself.
Below is a list of several things you can try before ordering and replacing parts to fix the 3E fault code.
How To Fix 3E Samsung Washer Error Code:
1. Unplug The Washing Machine:
Unplug the washer for 2-3 minutes. If the fault is displayed because of an electronic glitch, or communication issue, unplugging the washer for several minutes may possibly reset the electronic panel. Make sure to leave the washer unplugged for at least 2-3 minutes. Leaving unplugged for that long will allow the capacitors located on the printed control board will discharge. letting the capacitors completely discharge is the best way to reset these electronic control boards.
2. Check Wire Connections On Drive Motor:
One fairly common issue that causes the 3E error code is connection problems. Double check the wire harness on the motor. To do so you will need to remove the small back access panel to see the motor and connections. On the back right side you'll see the motor and the motor wie harness. If this was my call I would remove the connection and check the inside of the molex connection. Sometimes the contacts inside the contain burn/melt. If that check good examine the first several inches of the wire as it leaves the molex connector. I've seen the wire break a couple inches away several times. I'm not sure if it's from stress or friction but I've seen it a couple times so double check that.
3. Check Wire Connections On Control Board:
The control board could possibly have a faulty wire connections or loose connection. Not very common at least not in my area but it could happen so It's worth mentioning. Double check each connection on the control board. Make sure each connection is tight and the wires are not pinched are burnt anywhere. Again if this was my service call I would remove each wire one at a time and plug back in making sure each wire connection is seated tightly. That just ensures everything is good and sound and one more thing is ruled out.
4. Check Hall Sensor:
The hall sensor on the back of the washer monitors the speed and direction of the tub. The sensor can be out of range or it could also have a faulty wiring connection. I've also seen the wire harness on the motors hall sensor break. I know of other technicians who have seen the same issue. Double check the hall sensor. If you have a multimeter, you could ohm the sensor out. You can ohm the sensor out from the board or directly at the sensor. If you tested the hall sensor from the board, that would rule out a broken wire at the same time. That's usually how I test these hall sensors. You don't have to slide the unit forward and you can test it from the front.
Finally if all the above test good. The motor is going to most likely need to be replaced to fix the fault code. The motor on these units are actually very reliable. Unfortunately a few of them most have made it out of the factory with issues because the 3E error code on Samsung washers is becoming more and more common. I used to see this code very rarely. In the last two months I bet I've seen it 3-4 times. Electronics Appliances Tablets Laptops Phones TVs Samsung US
Oct 13, 2015 | Computers & Internet
Toshiba Canvio 1 TB connection problem - physical layer issue may be on cable or on HDD mini-USB port itself
More than likely, this is some sort of fault in the logic of the external enclosure. The solid light indicates that the drive is powered and is awaiting access while the blinking light means that it is busy working. If you are unable to get the drive to do anything (whether reading data from the drive or storing data to the drive), then I would guess that it is time to see whether you still have warranty coverage on the drive and, if so, get it replaced under warranty.
In my experience, I have found that Toshiba drives are very unreliable and therefore would recommend that you replace it with a Seagate if this drive no longer has any warranty coverage. Of all the drive manufacturers, I have found Seagate drives to be the most stable and reliable. Others may recommend Western Digital but I replace failed Western Digital drives on a constant basis in my computer repair business each and every week while Seagates keep on going. I base my recommendation on being in business now for over 25 years.
Sep 10, 2014 | Toshiba Canvio Computers & Internet
Not able to turn on the TV after hearing some clicking sound. please assist on what should I do, how to repair. many thank
See if you can find a fuse on the back near the power cable where it connects to the TV. It sounds like the fuse might have "popped". If it is good, see if the TV is showing a blinking light (probably on the power button) which will indicate an error code. Finally, unplug the TV from everything (cable, power, DVD, etc..) and wait for 15 minutes to see if it will reset incase a thermal issue is occuring. Also check your AC outlet by plugging something that you know works into it to see if the power is dead at the outlet. Plug TV back in and see if powers up with nothing connected to it. Lastly, check your manual to see if there is a base-reset button on the back somewhere to reset it back to factory default settings incase something has locked up your initiation processes.
Hope that helps some!
Stan
May 29, 2014 | Toshiba 42wl55e Flat Panel Tv
Roku error code 011
Roku error code 011
This error occurred during the Roku player setup. If the Roku lost connection from Roku update server, then this error occurs.
Steps To resolve this issue:
Unplug the devices:
• Just unplug the Roku player, wireless router, and modem.
• And then reconnect them in the following order.
• Plug the modem, wireless router and Roku player.
• And then boot up the modem and gateway. Then follow the on-screen instruction.
Still getting the same error, you must reconnect your wireless network.
Reconnect the wireless network:
·Go to settings?Network?your wireless network
Enter the password to your wireless network.
If this not works then reset your device. Otherwise, call our technicians +1-855-804-1313 to resolve your issues and visit us https://www.rokucodelink.com
Dec 10, 2012 | Roku 2 XS
Error code of E1 F2 on a kitchenaid double wall oven. What does that mean?
F2 - E1
Keypad cable unplugged
1.
Check keypad connector for firm connection (keypad connects to control
board).
2. Press CANCEL. If error code returns after 60 seconds, replace
keypad (also called touch pad or membrane switch). Some models incorporate
keypad in to control board as one unit. In this case, replace control board
(also called ERC or clock).
Feb 15, 2011 | KitchenAid KEBC207 Electric Double Oven
F2 &F3 error codes, oven keeps beeping, I already tried turning off circuit breaker did not solve problem
F2
- E0 Shorted keypad (also called touch
pad) 1. Check keypad connector for firm
connection (keypad connects to control board).
returns after 60 seconds, replace keypad (also called touch pad or membrane
switch). Some models incorporate keypad in to control board as one unit. In this
case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open F3 - E0 Oven temperature sensor (RTD) opened (upper oven,
if double oven) Replace Oven temperature
sensor (RTD)
Note: Applies to all F3-E...
codes. F3 - E1 Oven temperature sensor (RTD) shorted (upper
oven, if double oven) F3 - E2 Oven temperature is too high (Cook
mode) F3 - E3 Oven temperature is too high (Clean
mode) F3 - E4 Oven temperature sensor (RTD) opened (lower oven,
if double oven) F3 - E5 Oven temperature sensor (RTD) shorted (lower
oven, if double oven) F3 - E6 Warming drawer sensor open F3 - E7 Warming drawer sensor
shorted
Dec 20, 2010 | Whirlpool Accubake RF362LXTT Electric...
I cannot get my Toshiba Satellite M305-S4910 to switch its' display to a stationary monitor. Is there something I need to do besides plug in the monitor cable?
Are you in windows 7? If so, hold the windows key and press P. Select the monitor output configuration you want (being careful to make sure you can still see the screen on something).
If you lose the screen entirely, unplug the vga cable and reboot the computer.
May 26, 2010 | Toshiba Satellite M305-S4826 Laptop
My oven has gone out and gave this message before dying.(.E1 F2) I think that means I need a new panel but not sure. Can you help? Where can I buy the part if need be?
HI. This code is in reference to a unplugged key pad cable. Use the check list below to address this issue further.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
CLICK HERE TO BE DIRECTED TO AN ON-LINE PARTS DEALER.
Dec 16, 2009 | Whirlpool GMC275PD Electric Double Oven
F2 error code
F2 E6 says this:
1. Check keypad connector for firm connection.
2. Press CANCEL. If error code returns after 60 sec., replace keypad.
3. Replace control
Nov 10, 2009 | Whirlpool GBD277PD Electric Double Oven
I ordered the three repair kits for the WD62725 TV. I was having a "34" code and the local service provider said I needed a Format, signal, and power board. I replaced all of the caps provided in the kits....
Most likely a wire plug connection between the boards or where you unplugged one, as the code 12 means there isnt any errors with the set, so its almost certainly a wire connection double check the ribbon cables extra good.
Jun 21, 2009 | Televison & Video
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
