Where are the hdmi connections to a JVC LT-39DG52J tv?
  • 319 Answers
SOURCE: JVC LT-32DA8BJ LCD TV. Is
Use remote to access "display off"
Posted on Apr 22, 2008
funkyjacob
  • 76 Answers
SOURCE: When connecting my Blue Ray
It all depends on the dvd that you are watching you cant change it to anything bigger than what is was recorded.
You will have to just watch it like it is. I have the same thing with my dvd player its really thin picture its annoying
Posted on Dec 04, 2008
bernardlunda
  • 318 Answers
SOURCE: JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Posted on Apr 30, 2009
  • 105 Answers
SOURCE: JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Posted on May 06, 2009
SOURCE: JVC LT-42DA8BJ
How are you connecting your laptop to the samsung TV? Is it DVI/HDMI or thru more-common S-video cable? I have successfully ported laptop screen to TV with S-Video. After you connect your S-video cable, right-click on blank desktop of laptop and bring up the Display Properties (usually the last entry on pop-up menu). Got to last tab, usually called Settings. You should see two monitors displayed on top part of this page. One of these (most likely #2) is your TV. Click on #2 monitor and check the box that reads "Extend my Windows desktop to this screen" (or words to that effect). Be sure you have the TV turned on and facing you because you may find yourself clicking on icons on the TV screen. You'll probably have to play with which is primary display because some video players have trouble playing to a secondary screen. You may also try the Fn+F8 (CRT/LCD) button on your laptop (those are the keys on my Dell). That may turn on the TV-out on the laptop. Lastly, remember that this will only get you video. You'll have to connect a 3.5 mm cable to you Line-Out port on the laptop and connect it somehow to your TV or SurroundSound speakers. There should be a audio-in port on those other devices for that. Or you can just play the sound thru your laptop speakers.
I'm not that familiar with the DVI-out but I suspect that it would work very similiarly. Good luck.
Posted on Jan 25, 2010
Trying to connect my JVC LT-42N700 TV TO MY LAPTOP VIA HDMI,NO SUCCESS
You may have to connect the laptop using the VGA port and PC audio connector so the TV will know a Laptop is connected.
Oct 07, 2016 | JVC Televison & Video
Why can't I use the HDMI port on a JVC LT-42E478?
your hdmi is not connected tight or the cable is bad,or it is dirty,use canned air to clean out plug.extend your comp screen to the tv
Jul 14, 2015 | JVC Televison & Video
Laptop will not connect to tv
the tv might not be able or new enough to handle the picture of a laptop or computer check to see if it is able to
Apr 23, 2013 | JVC Televison & Video
JVC LT-42X579 42 in. LCD TV
If it has more than 1 port try another---If it has component try connection there.
Mar 22, 2012 | JVC LT-42X579 42 in. LCD TV
Can you hook a JVC lt-42x579 tv up to your pc for netflix
It should be as simple as taking an HDMI cable (if your computer has an HDMI output) or VGA (monitor) cable and hooking it into the TV. From there, go to Control Panel and Display Settings, and click which option you want for the TV screen under "Connect my PC to a projector."
Oct 03, 2011 | JVC LT-42X579 42 in. LCD TV
Where is the hdmi port on my jvc hdmi tv
Hello
There is a socket at the rear panel of your TV to which an HDMI to DVI cable connection. It will look like a large telephone wall socket. OK.
Mar 26, 2011 | JVC LT-40X776 40 in. LCD HDTV
JVC LCD TV (LT-42X688) input panel not working!
1. This TV has setting for the HDMI input that allows you to select the HDMI Audio or Analog(red/white wire) audio. Make sure this is correct
2. Most cable boxes are DVI not HDMI. If DVI then you actually do need to use those Red/white cables. If HDMI, refer back to #1.
3. The cable box has a setting to select the Audio output, HDMI (digital) or Analog(red/white cables). Just like #1, this has to be set.
4. Contact your cable company to help you set up the box correctly. JVC can probably help you check the TV
Mar 05, 2009 | JVC LT-42X688 42 in. LCD HDTV
Jan 12, 2009 | JVC AV-36D303 36" TV
Try this
1. Turn ON TV
Dec 17, 2008 | JVC LT-32X575 32 in. HD-Ready LCD...
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
