Question about Kenmore Refrigerators
What causes the drain hole of a Kenmore freezer to freeze-up and water fills the refrigerator
  • Kenmore Master
  • 4,655 Answers
There are many reasons and I will send you to the Samurai for answers. Click link below. Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
Posted on Jun 22, 2009
  • John Tripp
    John Tripp Jun 22, 2009
    Please note that all are not for this reason. Sometimes something is blocking the drain line further down ot the drain tube has an uneven kink in it before it leaves the freezer. Some are because the freezer temperature is way below 0 degrees. If you need help feel free to contact me. Sea Breeze
I need to stop water from getting on the floor of the freezer?
If your refrigerator is frost-free, water may not be draining into the evaporator pan underneath. The drain tube may be clogged.
Dec 18, 2014 | Refrigerators
The refrigerator drain hole is freezing and not allowing the water to drain out, flooding the inside.
Make sure the drain is cleared ( hot water down the drain ) You may try to adjust your freezer temp just maybe to cold ? Hope this helps
Feb 23, 2011 | Kenmore 63074 Top Freezer Refrigerator
My freezer is building up water in the freezer and leaksout the door.
Here is a tip that I wrote about the drain hole freezing shut and causing water to run into the refrdgerator.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 18, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice at bottom of freezer
Make sure defrost drain is completely cleared of ice and anything else obstructing it. Pouring hot water in it is correct, but make sure it is going all the way through to defrost pan under unit.
Oct 11, 2017 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore colspot freezer drain line keeps freezing
Hi, The defrost drain behind the rear freezer panel is plugged. Remove the rear panel and clear the ice away from the drain. Then you will need to flush the drain hole with hot water to make sure it is open.
Some models require an after market drain heat kit.
Please get me your model # and I can look this up to let you know if you need that heat kit.
Thanks
Vic
Jul 17, 2009 | Refrigerators
Ice buildup on floor of side by side freezer floor..
Inside the freezer in the lower part of the back wall there's a drain hole wich probably is clough and the water from defrost doesn't go through and freezes up .Put hot water to defrost it and keep pooring it until goes through.If is still clogh try with a wire but do it ery carefull to not put a hole in the drain plstic tube.
Apr 22, 2009 | Kenmore 50522 / 50524 Side by Side...
Water under the bottom of the frezzer
I would thaw all ice out use hot water in the drain hole. also use a heat probe in the drain hole. Is the drain tube straight or does it have a trap in it.
Mar 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water freezing up in the bottom of the freezer
your defrost drain is stopped up then when it defrosts in steed og going down the drain its running in the freezer floor remove the back panel in the bottom of the freezer and clear the drain hole under the evaporator
Mar 12, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore Refrigerator-Freezer top
install a defrost drain tube heater call sears for a part number have the model handy befor calling
Apr 21, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Kenmore refrigerator freezer not freezing
Yes that is a proplem...when ever that compressor is running that fan motor should be running too.. also you evapurator fan motor should be running also
Aug 20, 2007 | Magic Chef CTB1722 Top Freezer...
Refrigerators Logo
216 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
