How can I get the outputs on my tv to work with an optical lead for my soundbar without it making a screeching noise?
Philips 46PFL7007T and Humax soundbar. Connect using optical lead and built in freeview works fine but all the other outputs give a screeching interference noise. Headphone lead works fine, but would rather use optical.
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=gb&ctn=46PFL7007T/12
Please check this link to download its user manual in PDF. See its specifications page, to know whether the TV has an optical out socket, to take out optical out signal from it. If yes, you can find the exact way. If not, it is impossible. Gopakumar Gopalan Google
Posted on May 09, 2014
  • Vikki
    Vikki May 09, 2014
    Yes the tv has optical audio out, so how do I stop this noise?
  • The Knight
    The Knight May 09, 2014
    If there is optical output, it should be so silent. Check it by using an other optical cable connected in between amp and TV.
SOURCE: Connecting laptop audio to tv
i had the same issue with a thinkpad T61 which i was connecting using VGA and a audio jack going straqight from the headphone socket to the back of tv.
I had picture but no sound and i found that once connected the issue could be solved by rotating the projection setting on the laptop(Fn+F7). Basically switched back to laptop only display, then back to laptop and projector display again and teh sound just kicked in.
i think it's related to the projector setting on the laptop rather than an issue with the tv.
Posted on Nov 01, 2007
SOURCE: how to record freeview programs off tv with built in freeview
I have recently purchased a TV with built in Freeview. How can record programs onto my VCR? How many scart cables do I need?
Posted on Nov 11, 2008
SOURCE: built in freeview locked up in tv
I also got a black screen! I then turned the TV off, pressed TV and while it was lit, quickly pressed info, menu and then mute. Then switched the tv back on and amazingly......the menu was there. Go to item 12 and reset. I am please to say that we are back in business,
Posted on Dec 25, 2008
JollyRoger00
  • 59 Answers
SOURCE: Digital Audio Output Problem
connect the optical line from the DTV box to the audio system directly.
Posted on Sep 24, 2009
SOURCE: how do i get my built-in freeview to work?
I have freeview inbuilt on my tv. I hav sky at the mo so hav the satellite dish but want to get rid of sky and just hav freeview. So how do I make freeview work? Do i need to buy some sort of cord/connection to hook up the satellite cord/connection to the tv?
Posted on Apr 18, 2010
Having problems connecting using RCA cables (TV to Sound Bar) - No sound on Sound Bar
I assume by using your phone (cable rca to mini jack) the sounbar functions normal. Next time give more info like tv and soundbar make and model no and what connections are available on both components and if its input or output connections.
On the tv make sure the rca cable (tv to soundbar) is plug into the stereo output of the tv and not in a av input. Some tv's have a mini jack out and not rca. Some have a earphone socket which could also be used.
Some tv's only have a digital or optical output port. Iin basic sound work and can be connected with the following combinations .
Minijack to minijack
Minijack to rca
rca to rca
digital to digital
optical to optical
Oct 26, 2015 | RCA Televison & Video
A LG soundbar to a Laurus TV I've fix a optical lead one end and jack plug on the other but it doesn't work
A fiber optic cable carries infrared light path only. It's a digital signal, you can only connect this to equipment that has an optic connection. Adapting it with any kind of analog jack just simply won't function.
laurus tv images Google Search
checking the Google images of the Digital module does not show a tos-link connection for the module.
Apr 17, 2015 | LG Televison & Video
How do I connect my Sony soundbar ht-ct 260h to my blu ray player etc, I have no optical port or arc hdmi port,at the moment connected through the audio lead to soundbar & tv ?
hook your dvd player up to the tv via hdmi, then take the optical audio output from you tv to the soundbar. Make sure to enable to audio output jack in the tv setup menu as some manufacturers disable this jack by default.
Mar 30, 2015 | Sony HT-CT260H Soundbar and Wireless...
I have a Sharp Aquos LC-60LE640X TV and I am trying to connect a Samsung HW-H751 Soundbar to it. I have hooked up the optical cable, adaptor and sub woofer, I have tested the Bluetooth function throug
If you are connecting the soundbar to your TV with the digital audio cable, make sure to select "D IN" using the source button on the soundbar. Bluetooth (BT) is a separate source from another device. (phone, etc.) The TV will need to be set to use the digital audio output and probably PCM format. (?) The subwoofer is preconfigured at the factory to mate up with your soundbar. (See below instructions - your soundbar includes the amplifier:)
Digital audio output setting:
After connecting an amplifier with digital audio input and
external speakers as shown, you should set an audio
output format compatible with the programme you are
watching or the device connected.
Go to "HOME" > "TV Menu" > "Setup" > "Option" >
"Terminal setting" > "Digital audio output" > select
"PCM" or "Bitstream".
NOTE
• When set to "Bitstream", Dolby Digital is output when the Dolby
Digital or Dolby Digital Plus audio formats are received. When
set to "PCM", PCM is output no matter what audio formats are
received.
• When set to "Bitstream", HE-AAC audio formats can be output
as Dolby Digital.
Jan 24, 2015 | Sharp Aquos Televison & Video
I have a Philips soundbar that I have hooked up to my flat screen tv using audio (red,white) cables directly from soundbar to tv and there is no sound coming out.
Be sure you are hooking up the Audio Output from the TV or satellite to the soundbar.
From the satellite box both Audio Output and Video Output go to the TV, and then Audio Output from the TV goes to the soundbar.
Or
From the satellite box Video Output goes to the TV and Audio Output goes to the soundbar.
This may help as well:
https://www.youtube.com/watch?v=Z27WtBy4IUs
Jan 07, 2015 | Philips HTL2101A/F7 Soundbar 40 Watts
Do i need to buy anything extra for my ilive 37' soundbar for my tv? The sound doesnt work with my tv, but the bluetooth works just fine.
You'll need some sort of audio cable to connect the TV's sound or audio output to the soundbar. For the most basic connection, use an RCA-style cable ( like the one found here: http://goo.gl/5F8yLh ) to connect your TV's audio output to the soundbar's input. Most soundbars also have an SPDIF input ( like the one found here: http://goo.gl/2F2rKs ) and most modern TV's have an SPDIF output. Get an SPDIF optical digital audio cable to connect the two devices together. Once you've decided which type of connection to use and have connected the TV's audio output the soundbar, then make sure you select the proper input on the soundbar. That should fix your problem.
Nov 28, 2014 | iLive 2.1 Channel Sound Bar ITP152B
How to connect soundbar to a TV with a skybox
Connect the soundbar either to the TV's optical output. Or use an Optical to stereo phono/RCA converter box and then a pair of stereo phono cables (red & white) to the soundbar.
If it's a very basic soundbar with just a headphone jack input then you can go from the TV's headphone output instead.
As for the Sky box, just leave it connected via either an AV lead or better still a HDMI cable direct to the TV. The TV will send sound out to the soundbar.
Sep 04, 2014 | Televison & Video
Sound bar compatibility
Make sure red glow is coming from TV's Opt out cable when TV is on. If it is, it is working. The best solution is use an LG soundbar with an LG TV. There is a differnce in digital outputs and with a "service remote" (used by authorized LG servicers) you might be able to change the TVs factory setting to make the vizio soundbar work. but I think you'll be better off with the LG soundbar.
Feb 18, 2014 | LG 47LH55 47 in. LCD HDTV
PhillipssoundBar htl2101A
You have to use the TV remote to set the TV sound option to external. Look on TV setup menu for 'external output' or 'external speakers'.
Dec 15, 2013 | Philips HTL2101/F7 Soundbar Speaker Spkr -...
Soundbar wont work
It basically has an Optical input, or a coaxial input. Use whichever input is available for you from your TV digital output, to the soundbar. If it still doesn't work, the soundbar is probably damaged. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 27, 2013 | Philips CSS2123B/F7 SoundBar Home Cinema
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
Electro Med Services...
