Question about Panasonic KX-FM220 Plain Paper Thermal Fax
Fax machine won't power up
I have a Panasonic KX-FM220 that won't power up. It worked fine just before I put it in the closet (bought new all in one). A month later, I plugged it in and it won't do anything at all. The outlet works fine but the fax unit will not power up.
Any suggestions or should I just trash the machine?
  • 58 Answers
Try pushing the power cord firmly into the back of the machine
Posted on Jun 22, 2009
RECORDING AND LISTENING GREETING MASSAGES
The manual indicates where you may need to reset the unit if the memory is full or even if you just want to clear it, page 89-90.
You may use code: [MENU] [*][8][0] [SET] or [START]
You may also call - 1800-211-7262 for Panasonic's capable Technical Support; be sure to have the serial number of the product ready.
Mar 05, 2014 | Panasonic KX-FM220 Plain Paper Thermal Fax
5 AMP FUSE BLOWS
There is a short in the power supply that needs to be corrected, usually not cost effective for repair.
Jan 05, 2011 | Panasonic KX-FM220 Plain Paper Thermal Fax
I need drivers Panasonic KX-FLB758 for windows 7 please... thank I´m from Argentina
KX-FLB758 was apparently a clone of KX-FLB756 and KX-FLB751 model. Drivers available on the following page should work fine:
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Laser-Multifunction-Fax/Drivers-Downloads/model.KX-FLB756.D#ts
Aug 19, 2010 | Panasonic KX-FLB756 Plain Paper Laser Fax
Panasonic KX-FM220 fax machine does not have a dial tone
is your line provider ok.connect your line to ordinary phone to check if there is really a dial tone from the line provider.if there is a dial tone please let the analog board be cheked by a technician near you
May 01, 2008 | Panasonic KX-FM220 Plain Paper Thermal Fax
Panasonic KX-FM220 fax machine does have a dial tone
I would double check your phone cord. There is usually 2 jacks in the back of the fax machine. 1 is for Line, and 1 is for phone.
Your phone cord should be hooked up in the LINE jack that goes to the wall.
I would also double check your phone cord on another phone to make sure the cord is good.
If you look at the clear connector that you plug into your wall and fax machine, does it have 4 copper/gold color wires contacts imbedded in the clear plastic connector?
Another thing to try, if you fax machine has a Line and a Phone connector, try plugging in a phone in the PHONE connector. Then hook up another phone cord going from the LINE to the WALL jack.
If you get a dial tone on your Phone, then you know you have it connected correctly. If no dial tone, then I would go back to the phone cord.
check those things and get back to me and I will see if I can help you with more suggestions.
Good luck.
Mac =)
Fax not working
unfortunately it sounds like the thermal head is defective, could possibly be a few other things but either of them to be fixed is going to be not far off the cost of a new mc, probably better to put the money into a new one rather than pour money into an older mc, before you do though, check the paper/film for anything visually wrong.
Mar 01, 2008 | Panasonic KX-FPC95 Plain Paper Thermal...
Fax film pulls through with copies
timing is usually associated with a motor, try and see if the motor can be dismanteld, clean with alcohol and put oil on finger to lube inside.
If not then motor needs to be changed.
Feb 11, 2008 | Panasonic KX-FM220 Plain Paper Thermal Fax
Panasonic KX-FM220 Plain Paper Thermal Fax Logo
130 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
