Question about Kenmore 24 in. 17602 / 17604 / 17609 Built-in Dishwasher
Dishwasher will not operate but "lock on" light is lit up.
We tried to run our Kenmore dishwasher quietguard plus and the only light lit on the unit was the "lock on" light and it would flash when you tried to get unit to start a wash cycle
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
SOURCE: Kenmore Ultra Wash Dishwasher: Lock On Button Issue
Have to hold the Air Dry button down til your finger hurts. Release button and the light will go off. The "4 second press" in the manual is incorrect!
Posted on Jun 24, 2008
SOURCE: Kenmore ultra wash dishwasher control lock light flashing
Hi jabberr216,
I'm Harvey the Master Plumber.
Your question is: You have an older model Kenmore ultra wash dishwasher model #15805890. The control lock light is flashing. No buttons are working. The dishwasher does not turn on. Any solutions?
Sure! Someone must have activated the lock. It is next to either the 'air dry' or 'heated dry' button.
Press and hold that button till the lock light goes out. About 6 seconds. That's it. It turns on the same way.
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 03, 2008
  • 338 Answers
SOURCE: Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Not draining may either need new drain motor. or something is blocking the drain pipe.
Spots on dishes means you are using to much detergent or the wrong kind of detergent.
Your owners manuel should tell you what type to use.
Posted on Nov 25, 2008
  • 121 Answers
SOURCE: Kenmore UltraWash QuietGuard 4 making horrible
you have a peace of glass or plastic stuck in bottom
around the sprayer arm
Posted on Apr 17, 2009
  • 71 Answers
SOURCE: hello,
On our Kenmore Quietguard the lock light is at the Air Dry button. Holding the Air Dry button for about 8 seconds turns the lock light off if it is on and on if it is off.
Posted on Jan 04, 2010
0 characters
1 Points
Kenmore elite dishwasher mdl 665.16919001 all lighs out, won't come ont
try a simple step to reset unit unplug and then plug back in
May 26, 2012 | Kenmore Dishwashers
How can I turn off heated dry on my kenmore ultra wash quietguard
We had the same problem and called a local service center for some advice since the dishwasher was no longer under warranty, Sears 1-800 number would not troubleshoot with us. The local technician suggested we open the panel behind the keypad (with the power disconnected) and unplug the main "ribbon" for 10 seconds. After plugging the ribbon back in and restoring power the keypad had reset itself and the lock button was no longer an issue :) I hope this helps someone else that may be in the same boat someday. (I apologize if the term ribbon is vague here but when you look at all of the wires running around the back of the panel it's easy to see, ours was various shades of grey and appox 2" wide)
May 03, 2012 | Kenmore Dishwashers
Kenmore Quietguard 2 dishwasher not filling.
There is a solenoid that keeps the water in the washer. It is either faulty or there is something preventing it from closing completely. If there is no power applied to the washer, does it then hold water?
Apr 28, 2010 | Kenmore 24 in. 17002 Built-in Dishwasher
Hello, i have a Kenmore Quietguard standard dishwasher. it is in the "lock" position under dry options and the dishwasher will not start. can you tell me how i might be able to re-start this?
Jan 04, 2010 | Kenmore Dishwashers
Help! I have a kenmore elite ultra wash quietguard delux. the other day my toddler was playing near it so i pressed the button to lock it. Problem is I don't know how to unlock it! Please help me...don't...
Here are the instructions to set and unset the child lock.
Setting the Child Lock:
1. Press the Sensor Dry or Lock pad and hold for
three seconds.
2. An indicator light next to the lock graphic will
illuminate when the controls are locked.
To cancel:
three seconds.
2. The indicator light will go off.
Alan Hood
Dec 04, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Ultrawash Quietguard Deluxe Problem
kenmore washers nothing but problems, my washer says clean and will not do any cycles...... less that 2 years old
Oct 21, 2009 | Kenmore Dishwashers
Dishwasher Clean light blinks constantly.
Try turning off the power to the dishwasher at the circuit breaker box. leave the power off for 5 10 mins and then turn breaker back on and try to restart dishwasher. This may reset the board and it may work
Feb 05, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
check the water inlet valve first
May 05, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Quietguard Plus/Ultrawash - Kenmore
drain hose may be partially clogged or kinked up. ensure that the hose is not bent up thus restricting the flow of water out.
Nov 26, 2007 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 24 in. 17602 / 17604 / 17609 Built-in Dishwasher Logo
26 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
D. E. Hev
Raisin Brann
Level 1 Expert
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
