Question about Durabrand Audio Players & Recorders
How do i work radio ?
Model CRD 7650
Chrysler grand voyager 2003 radio code
hey from London.
names LeeZ trying to get noticed as a coder.
code is : 2133
on the house from me ;)
Dec 10, 2012 | Chrysler Scosche Factory Radio Interface...
Tip
Bluetooth Connection Guide Part 1
This is a "How To" for Connecting the Nokia Series 60 device (Nokia 7650, 6600, 3650, 3660 etc...) via Bluetooth TM with the Windows Widcomm software used by TDK, Billington, MSI and others Bluetooth USB Vendors. The steps are similar for other Series 60 devices and have been checked with the 3650 and 6600.
1.Pairing the computer and the Series 60 Handset
Pairing is the process of swapping pass keys and setting up a trusted connection between the Bluetooth USB adapter / card connected to the PC and the 7650 handset. Save any files and close any applications you may have been working on.
2. Set up Bluetooth TM on the 7650 by going to the Main Menu, selecting Connect and then Bluetooth.
3. Make sure the Bluetooth option is On and My Phone's Visibility is Shown to all. Remember what is in My Bluetooth Name - or edit it to one of your choice - this is what your 7650 will be seen as by other Bluetooth TM devices.
4. Right Click on the Bluetooth Icon in the system tray, on the menu that appears go to Setup and then click on Security.
5. A window appears and all being well the right hand pane will have your 7650 (titled what ever you have entered into the phone's My Bluetooth Name entry). If nothing appears click Refresh and your phone should then appear. Highlight the 7650 and click Execute Pairing.
6. A window will pop up asking for a PassKey. Enter in a numeric only passkey and click OK.
7. On the 7650 a screen pops up asking you to enter a passkey - key in the same number you just typed into the PC.
8. By default any connections from your PC to the 7650 must be manually accepted on the 7650. You have an option to set up a connection from the PC to your 7650 as authorized, this means when you connect from the PC to the phone it won't ask you if it's ok and will connect automatically.
9. To set it as automatic: On the 7650 in the Bluetooth TM Setting Screen, you joystick right to the Paired Devices screen, highlight the Computer you just paired with and press Options, select Set as Authorized and Yes. You will then see a padlock icon beside the paired device - this device will no longer require manual authorization for connections to the 7650.
Now you should set My phone's visibility to Hidden - so that unknown devices searching won't see your phone. You can still be connected to by any paired devices. Remember to switch it to Visible if you want to pair with a new device or receive a file / business card from someone with an unpaired device.
on Mar 06, 2010 | Cell Phones
What is the model number for radio out of a Jeep Grand Cherokee 2.7 CRD Limitd 2004? Thanks x
Welcome to FixYa!
The Radio was manufactured by "INFINITY by Harman".
There were a lot of variations used in the Jeep Grand Cherokee series including the limited edition (1999-2004).
Get in with INFINITY to get the exact model number.
Contact: 1-516-682-6438 (US)
I am not a car expert, I just want to help since I am seeing your post unanswered for more than 2 hours already.
Thank you for using FixYa.
Jas247
Apr 05, 2011 | 2004 Jeep Grand Cherokee
I have a CRT monitor hp 7650 and i have a problem that monitor power supply not working
I hate to sound nasty but these days it would be cheaper to buy a used but working CRT monitor than try to get one repaired. I've seen 22inch CRT's going for $10. Nobody wants them now there's LCD and LED monitors.
If you are really set on getting yours repaired, try Ebay. You may have to wait a few weeks for your specific model to come up but it could even be available right now. It may even be better to ask the seller to pull the power supply for you and just send it to save on freight.
Strange it's the exact model name for a scanjet too.
Good Luck
Apr 24, 2010 | HP Computers & Internet
Driver of digital voice recorder 7650-X
You can download the drivers for this machine at www.dictation.philips.com in the support section.
Nov 25, 2009 | Philips DVT 7650 Digital Voice Recorder
Radio gone mute
pull radio out on the back of it is a studed screw there should be a strap attached and a black wire plugged in to it also if the black wire is not there find it and plug it in its the ground for the factory amp
Feb 10, 2009 | 2004 Chrysler Town & Country
HP ScanJet 7650 Flatbed Scanner
The model is actually discontinued now, but you can download Driver Software and a Manual for the Scanjet 7650 from the HP website:
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=uk&prodTypeId=15179&prodSeriesId=434502&lang=en&cc=uk
You can also get Parts information.
Hope this helps
Chris (ziraffa)
Jan 11, 2009 | HP ScanJet 7650 Flatbed Scanner
GE Spacemaker TV/Radio combination Model #7-7650
Yes, you will need an external antenna to pull in the digital signals. It will not work with the built-in antenna on the GE. Alternately, you can use an external antenna (ie, rabbit ears), connect them to the converter box, then connect the converter box to the antenna jack on the back of the TV (I think it has one). Granted, not an elegant solution for a kitchen TV, but it beats not using it anymore.
Cheers
Nov 11, 2008 | GE Televison & Video
Hp scanjet 7650 urgent issue...
just reinstall scanner driver and software
Mar 20, 2008 | HP ScanJet 7650 Flatbed Scanner
Nokia 7650
whether you have changed the buzzer? Check the buzzer first. you can use a multimeter, if the buzzer is still good, this means that the ribbon cable problem, you need to change the ribbon cable.
Aug 31, 2007 | Nokia 7650 Cellular Phone
76 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Jonathon summesfield
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
