Question about Ricoh Office Equipment & Supplies
Lanier 7228 lanier copier 7228 says enter job access code what code is this, and how do i get this
Cogz
  • 1326 Answers
SOURCE: Lanier 5645 copier - Code sc546
Try this press the "yellow/ca" botton, then enter 1-0-7, then press and hold the "red" stop" till the display changes. Once, it changes turn the Main power switch OFF. Not the one on the control pannel. Let it power down then turn it back ON. If the problem is still there try to turn the copier Off again and unplug the sorter/ finisher and turn the copier back ON. Is the problem gone, if so you may have to get a service person come in and repair the sorter. Good Luck.....
Posted on Apr 06, 2009
SOURCE: lanier copier ld145 locked up, code is
Fuser warm up problem. Cause needs to be fixed and then code can be reset in service mode by a tech.
Posted on Jul 29, 2009
  • 158 Answers
SOURCE: helo, I have just bought a used lanier copier
could be a failed ccd unit or it needs the charge corona replaced or the drum replaced
Posted on Oct 03, 2009
  • 46 Answers
SOURCE: We have an error code SC998 on the Lanier 5645
according to the book this is
software or missing RAM or missing DIMM
i don't do ricohs, so i can't help you any more with this sorry!
Posted on Oct 26, 2009
Gunslinger
  • 62 Answers
SOURCE: Lanier LD225 copier with a error code 541
What sp code did you use. It should have been 5810 or 7807.
It it came back after that you have bad thermistors or they are too far away from the heat roller.
They ride on the heat roller, no spacing.
Posted on Feb 10, 2010
Lanier printer spc240dn engine menu nsequence
Go to the Lanier web site and download the manual. If you can't find them then contact them through the site and ask for help. See: http://www.lanier.com/downloads/Default.aspx?hbn=manuals
Apr 01, 2015 | Lanier Office Equipment & Supplies
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
LANIER 5637 FAULT CODE SC542 UPON POWER UP
You have a Fuser Temperature warm-up error, Hot roller warm-up error.
Verify the heater lamps, thermistor and thermofuse continuity.
Enter in the SP mode, turn OFF the main switch, unplug the machine, wait 10 seconds,
plug in and turn ON the copier.
If you need to reset the fuser,
Enter SP 5-810 (SC code reset) and
select "1". Then simultaneously press the Original Type key and the OK (or
R/#) key. (There is no need to turn the main switch off and on.).
Jan 22, 2011 | Lanier Office Equipment & Supplies
Lanier model 5627,fault code SC542 upon power up
try this:
1. Press the clear mode key (yellow key)
2. Use the keypad to enter "107"
3. Old down clear/stop for at least 3 secunds. (red key)
4. Enter the service mode.
5. Exit all the way and turn off.
6. Turn ON
And thats it
Jan 22, 2011 | Lanier 1205 Copier
Describe your lanier sc 542 Problem Machine turns on and then gives this code.
This is a hot section problem, can be reset by entering service mode (pushing in sequence clear modes 1-0-7 hold stop button down for 5 seconds) but this is a bad code...service call? -Carl
Nov 13, 2010 | Lanier 1205 Copier
Sc 546 lanier ld
This is a fuser error code resetable by entering service mode. -Carl
Jun 10, 2010 | Lanier 1205 Copier
Lanier MPC 3000 copier won't print faxes
Try opening up your web browser and type in the ip address of your lanier.
You should to access the facsimile function located on the left side. Once youre in the facsimile function, you should see a thumbnail view of the faxes stored in your lanier. Simply click on the faxes and delete them.
Sep 22, 2009 | Lanier Office Equipment & Supplies
How do you reset a lanier 6112 copier so the wrench stops flashing. thanks
The maintenance time is flashing.To be use the service enter code C-0-0-C or C -Interrupt-0-Interrupt,then press 20(maintenance counter clear) and 72 maintenance preset counter setting for a new value.
Aug 07, 2009 | Lanier Office Equipment & Supplies
Service code 561 error
Hello sir; Just follow my direction, it will reset your machine;
1, press "clear mode", "107", then press and hold down "clear/stop" key.
2, touch "copier SP" on the screen.
3, enter "5810-001" press enter.
4, set value to 0, then turn power off and back on again.
May 15, 2009 | Lanier Office Equipment & Supplies
19 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
