2006 e90 325 when I turn on the ignition and push the button it will not star, Headlights go radio works etc. Im pretty sure the fuel pump switches on also, but the car will not start, I had a few ideas first off being the starter motor but theres no noise at all second the battery in the key, its fine, now im thinking it must be an electrical problem perhaps a relay or a fuse, any ideas would be much appreciated, sincerely Andre Watty [email protected] hope to hear from you shortly
SOURCE: 97 chevy suburban wont start
try putting a dab of solder on each one of the contacts on the fuel pump relay. i had a similiar situation where the relay contacts in the fuse box got strectched out over time so i put a dab of solder on each terminal to beef the contacts up and it worked perfectly. i think this will work because if the mechanic put a wire jumper in the contacts then electrical it is fine.
SOURCE: 1995 chevy chayenne 3500v8 2wd automatic transmission no shift
dude there is a wire that goes from your dash to the trans. that has a short I myself had the same thing wrong with my 1995 chevy 1 its like $450 from the 1500 i for got whats its called but its behide your dash go to the dealer and ask them to show you the wireing for the trans. and you will find it.
SOURCE: I'm not getting power to the fuel pump relay when
could either be ecm/pcm or ignition control module
SOURCE: gas not spraying at throttle body
replace the injector - before you do that test voltage going to the injector- is should pulse on and off to open and close it
SOURCE: both remotes failed to either
no reset button, sorry. If the starter is turning over, then it's more than likely not an alarm or keyless problem. if it was even connected, the starter kill feature is used to "cut" the starter wire from the ignition and the starter itself, and if you say it's turning over, that's where i get my answer for it not being the avital. of course there could be more to it, remote start added, and the type of car make a huge difference, could be a bypass module for bypassing a factory security system, so without any more info, that's all i can give you. hope this helps, dave
Car not starting or turning over indicates towards multiple possibilities.
It can be issue with battery or weak battery. But if battery checks out ok, then
it can be starter issue or faulty alternator or problem with low fuel pressure
or no spark at spark plugs due to dirty spark plugs or faulty
ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks.
