Why does the detergent drawer of our Asko W6021 refuse to open or close easily?
Opens the first centimetre or so then requires some force to open fully. Closing is also the same, the last centimetre is very reticent to close.
  • 328 Answers
It probably needs cleaning. Best thing to do when you pull it out, is to release the conditoner tray at the sides, or find out how to remove it completely. It should come out for cleaning - you may find a build up of sludge at the back that is preventing it from opening and closing properly. Clean off using just water and a little vinegar and put back in. You should find that it opens and closes easily after that.
Posted on May 09, 2014
Testimonial: "Thank you for your suggestion , but I have already tried this. Any other thoughts"
  • Ryan S
    Ryan S May 09, 2014
    Well it has something to do with the plastic. The runners in the machine could be broken that holds the drawer in but those are tested to last the life of the machine. It could be that if it has been slammed with brute force that the drawer is no longer able to move freely. There are ways around this but they are temporary like sliding soap down the sides so that the drawer moves more freely. If it has been slammed using brute force previously the runners on the drawer itself may be broken.
maklean
  • 1665 Answers
SOURCE: detergent dispenser stuck, I think the detergent cup is preventing the drawer from opening
Here there is a user guide and instructions of a similar washer model.
http://www.laundrymanuals.com/manuals/mfg/lg/wm2496h.html
and also all available LG washer manuals to download.
http://www.laundrymanuals.com/manuals/mfg/lg/lg_frontload_washer_product_list.html
Have a look of how top lid is mounted.
Posted on Feb 15, 2008
MNTECH
  • 1543 Answers
SOURCE: Detergent dispenser drawer stuck
You may have to remove the washer top (three phillips screws at the back, then push top back about two inches and lift it off) then drill a hole in the top of the plastic dispenser to allow you to use an object like a screwdriver to maneuver the offending part around so it will drop down and allow you to open the dispenser drawer. Use foil tape to seal hole if you don't want to buy a new dispenser. Clean out blue plastic dispenser parts so detergent will siphon out completely. Pushing down on the center tab at the back of the dispenser should allow you to take the dispenser drawer the remainder of the way out. In the future, make sure you do not use over 1 tablespoon of HE soap (and 1 teaspoon of fabric softner) max per load. Even less if you have 2x or more detergent.
Posted on Oct 11, 2008
SOURCE: Asko Washer W6021 Problem
CHECK THE BRUSHES ON THE MOTOR, FOR BEING WORN DOWN!
REGARDS........TREVOR. FLEETWOOD UK.
Posted on Mar 09, 2009
SOURCE: laundry detergent drawer stuck
I had the same problem - the fabric softener cup cam loose and I had to break it to get it out and the new drawer cost me about $65 to replace. I hope you made out better than I did.
Posted on Jan 21, 2010
SOURCE: detergent drawer will not open
The soap dispenser in my LG WM2277H front loading washer keeps getting stuck shut. I have tried wiggling it, jiggling it and yelling at it. Nothing works. I can not pry open the back as suggested and drill a hole. There has to be a solution! Please?
Posted on Jul 07, 2010
How can I open detergent drawer, opens about 20mm & won't come out any further
Pull the drawer out as far as it goes then lift it up and pull it out completely. It may be stacked due to detergent remainings.
So, you should clean the drawer with a soft brush under warm running water. Do not put the drawer into a dishwasher!
Replace the drawer by tilting it into position.
Hope it helps.
Jun 08, 2015 | Asko W6021 Front Load Washer
The detergent drawer is jamming and extremely difficult to open,any suggestions please?
Hi I would think its probably built up detergent in the runners take the whole drawer out and give a good clean use a steam cleaner if u have one
Mar 14, 2015 | Asko W6021 Front Load Washer
W6444 washing machine door won't close
Try some WD40 spray on the door and lock. Just a bit. Try closing and opening the door. The machine should be in the <off> position.
Mar 16, 2013 | Asko W6021 Front Load Washer
The detergent draw won't pull in and out easy. You've really got to 'pull' to get it open and 'push' really hard to make it close.
theres is probably soap inside the track where the drawer slides, just clean it out and you should be fine.
Jul 09, 2011 | Asko W6761 Front Load Washer
My Asko Front load washer model W6021 Prewash
hi you need to replace the inlet valve,take off the top panel and you will see the valve behind the soap drawer with the black hoses.you can get a book from asko.com.au
Jun 15, 2010 | Asko W6021 Front Load Washer
After a power serge caused by the local power authority we can not open the door to our ASKO W6021 - we have washing locked in the machine and want to take it out before the machine is taken away to be...
prise open the samll square door at the bottom left using the divider in the soap drawer. Once open extract the red loped handle and pull on it ot manually open the door.
Apr 03, 2009 | Asko W6021 Front Load Washer
ASKO 6021 washing machine, drawer locked
Reach under the drawer, right side and move the lock mechanism to he left. The drawer will unlock.
Mar 22, 2009 | Asko W6021 Front Load Washer
Asko front load washing machine
Try some WD40 on the door mech,(on door, ie.) And with switch off, close & open door 4 or 5 times.
May 09, 2008 | Asko W6021 Front Load Washer
Asko W6021 front load washer door stuck! If any one can help me please do thanks, Dwayne.
there is a little red loop that you can pull on to release the door manually. it is located behind the little door on the lower left of the machine. Pop that door open and take the phillips head screw out of the lever hen pull on it and the door will open.
Oct 24, 2006 | Asko W6021 Front Load Washer
Washing Machines Logo
110 people viewed this question
Top Washing Machines Experts
