Bizhub 250 memory
Need to clear the scanned memory of Bizhub 250. Says memory full
SOURCE: Cannot scan to email Konica Minolta 250 Bizhub
To scan to email, Administrator email address must be set in the machine (any bogus email address will work too).
Also, email server address must be input as IP address if DNS or WINS is not running in LAN.
Posted on Mar 09, 2008
SOURCE: Bizhub 250 scan to email error
Change your account information from external to internal, i.e. yourmaildomain.com to yourADdomain.local. Change on the scan account as well as the email addresses.
Posted on Dec 22, 2008
rcampsr
  • 90 Answers
SOURCE: Ocr scan for Bizhub C450
according to what I read on the C450 biz hub, in order to do OCR you need to use the option that scans to SMB, that sends the scanned documents to your computer on the network. You can then process the documents on your computer with the OCR software program so you can edit the finished documents. I did not see anything that indicated the Bizhub had OCR software capabilities built into the unit. Regards, rcampsr
Posted on Feb 20, 2009
  • 12 Answers
SOURCE: Our bizhub-250 receives a C2557
hi,
open and close front door cover to reset error.
If it persists you have to execute (TCR Toner SUPPLY)
Tell me if you need to execute it.
Bye.
Posted on Mar 20, 2009
SOURCE: BizHub 250 Malfunction Code C2557 - HELP!
I can even reach the "service mode".
The screen shows the error (c2557) and I can not access to anyother function.
Posted on Oct 01, 2009
Memory full
add additional memory, contact local KMBS dealer
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 14, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub reads "server disk full": how to unfill server disk? or how to fix?
CAUSE: Machine memory is corrupt and the max out time needs to be increased.
SOLUTION: Perform a Data Clear:
1. Enter the Tech Rep mode.
2. Press System 1.
3. Press Initialization.
4. Press Data Clear.
Also browse to the NIC, enter Admin mode and set the connection timeout for E-mail to 300 seconds.
Apr 23, 2010 | Konica Minolta bizhub C351 All-In-One...
Have a bizhub C353 conected to a network. Using a
have a bizhub 250 trying to scan to pc via smb on a network. Keep getting login failure. Can you help
Nov 12, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Konica minolta bizhub 250 I need to scan many documents to computer says user id and password incorrect
the user name and password have to match the pc. if the pc does not have administrative rights the scan will be rejected most network security software will cause a scan to be rejected also
Sep 25, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Bizhub c-250 deleting fax jobs because it is saying memory full
the copiers hard drive is probably corrupt and needs to be formatted physical and logical formats
Jun 25, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Bizhub 250 Scan to searchable pdf
This copier scans as an image. The contents of this file are not searchable. The output type (as default) can be set by logging into the web interface of the machine. As for one- touches that are allready setup as tif, you would need to edit the one touch parameters to set the device to PDF. (image only)
Jan 14, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Try re-entering user name and password or try a different user name and password for email account saved in the machine.
Jan 25, 2008 | Konica Minolta bizhub C250 All-In-One...
12 people viewed this question
k24674
jasbo
jasbo
