Question about Timex Expedition Watches
Replace stem AND crown of timex field expedition
VOTIT
  • 2071 Answers
SOURCE: Removing the crown
The video i want to see you,is using older kind of watch,screwing before he can pull the crown ,the new model watches now like your Tag Heuer is pushing, use a needle to push, while pushing the stem lock you pull the crown .That's why ill tell you in advance so you aware.I know because i'm a watch technician working in rolex before...
remove the crown
if i helped,please,click FOR RATING .It is the only way i get paid for my works also,please consider leaving feedback..
Regards,
VOTIT
Posted on Sep 08, 2008
escapement
  • 2334 Answers
SOURCE: i pulled on the crown and it came off the stem
Do not open the watch yet, as you do not know how to get the stem out.
Take an eyeglass and examine the crown. You will find the small hub in the centre of the crown. If the centre of this hub is hollow and you can see the thread in it- you will be able to screw it back on stem (all watch crowns are screwed on to stems, never pressed).
If the centre of that hub looks filled with metal, then the stem end is broke and you will need replace stem AND crown (the metal filling the hub is the broken end of stem).
In case if the crown still in tact, let me know by asking questions and I'll guide you through all the process HOW TO.
Rate me, please.
Posted on Mar 24, 2009
  • 12 Answers
SOURCE: Broken stem (or came off)
You could send it to Timex yourself and they might fix it for free if it looks like it just unscrewed.
Posted on Jun 14, 2009
SOURCE: How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
Posted on Jun 17, 2009
  • 2501 Answers
SOURCE: Timex Expedition Compass watch stops randomly.
Some watches have crowns that screw in after being pushed home, is this the case with yours? If it is then that could cause the problem described. (Turn crown clockwise).
I looked at one or two of the Expedition instructions (the are a lot) but couldn't find any mention of a screw in crown.
I suggest that you go to Timex.com and at the bottom of the page is "manuals/downloads" select this and the "product manuals". Put your watch type in the search box to obtain your manual.
If you are still not able to solve the problem, the I suggest you take it back to a Timex dealer to sort it out.
Posted on Jan 28, 2010
How do i set the time on a timex Expedition T49949
Hello. You just have to pull and turn the crown found in the 3H location of your watch. Normally for timex watch with date function, you have to pull the crown on the 2nd pull position or until the hands move when you turn the crown.
Mar 10, 2015 | Timex Mens T49949 Expedition Digital CAT...
How to advance date 4 or 5 days on a Timex T40021
This watch should have a "quick set" date function that lets you advance the dates by turning the setting crown. To get the watch in this mode, pull the set stem out half-way. At that point, turning the setting crown will advance the date on the watch without turning the hands. One some watches, finding the right position for the set stem can be a bit tricky--either it's not out far enough or it's out just a bit too far and the time hands turn. You may have to try pulling the stem in and out a few times to get it just right.
A word of advice: watches are generally designed to advance the date, not to turn it back. It's suggested that if you need turn the date back, you actually advance the date wheel up to 30 days to get to the date you want. Some watches do permit you to turn dates backwards, but I prefer not to risk the chance of hanging up the little springs and mechanism that are designed to advance the date indicator.
One final note: I have serviced several Timex mid-size (ladies or kids size) Expedition watches that lack a quick-set date. Many Timex watches in that size do have a quickset date like I've just described to you, so I have no idea whether these watches happen to have a cheaper movement or if they have some internal damage (it's been the same model each time). At any rate, for those watches, I have had to use the incredibly slow and painful process of advancing the time 24 hours to advance the date. With those watches, if the date is too far advanced by a day or two, it may be easier to stop the watch for 24-48 hours until the date is correct, rather than spend a huge amount of time spinning the crown to advance the time. Hopefully, your watch will have the more sophisticated movement, though.
May 28, 2011 | Timex Expedition® Metal Field 47042...
How to replace stem and crown in timex indiglo watch?
If you have the stem and crown take it to a watchmaker. If not it is cheaper to buy a new watch
Mar 16, 2011 | Timex Indiglo Analog Watch
How can i change date on my watch
mcdevito75 here, If your Timex has a Stem (winder) do this, Slip a fingernail just under the stem and gently lift the crown just a bit, the stem has 2 positions, it may take practice so be patient, once the crown is in it"s first position you"ll be able to change the DATE, set the date 1 date before the date you want so that the date will change on time at about Midnite. Now with the date 1 date before the date you want, push the crown back in and pull the crown out to set the hands, go thru the 24 hour cycle once till you reach the date you want, set also the time of day and your done. Hope this helps.
Jul 20, 2010 | Timex 27191 Wristwatch
How do I re-wind the date on my Timex Easy Reader Woman's Watch?
mcdevito75 here, The stem (crown) on your timex shou;d have 2 positions, this allows you to set the date without haveing to turn the hands around so many times. Place a fingernail just under the crown (winder knob) and lift to it"s first position, it may take some practice so if you don"t get it the first time keep trying, Once you lift the crown to it:"s first position you shoulsd be able to set the date, set the date a day before the date you need, Now, push the stem back in all the way, now pull out the stem and set the date and time you want, you"ll have to go around the 24 hours once to set the correct date and time. Hope this helps. If you can"t do this adjustment, see a small watch repair shop in your area.
Jul 01, 2010 | Timex 27191 Wristwatch
How to set date in Timex T2M710?
mcdevito75 here, Your Timex stem (winder) has 2 positions, slip a fingernail just under the crown (winder) and lift the crown to it"s first position this will allow you to change the DATE (number) with out haveing to go thru the 24 hour cycle some many times. It may take a little practice but the stem has those 2 positions. Set the date to the date before the date you want then push the stem back in, Now pull the stem out and go around the 24 hours to set the date and time of day you want.
Jul 05, 2010 | Watches
Jan 28, 2010 | Watches
Timex EXPEDITION® E-TIDE-TEMP-COMPASS T45581
This is the link;
http://assets.timex.com/instructions/w225instr.pdf
Jun 14, 2008 | Timex Expedition Metal Field 47022...
Watches Logo
64 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Mark Schmit
Mark Schmit
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
