Question about Facebook Apps
How to calibrate velo9w - Facebook Apps
My 2007 checy impala read "calibration complete" what does that mean ????
CALIBRATION COMPLETE
Refer to Electronic Compass Calibration do you have an owners manual ?
Compass Calibration
The compass direction will show CAL if it needs to be calibrated. Before calibrating the compass, drive the vehicle to an area that is magnetically clean (free of large metallic objects).
  1. Turn ON the ignition.
  2. Before calibrating the compass, make sure the compass is set to the variance zone in which the vehicle is travelling. See Compass Magnetic Variation Adjustment below.
  3. Press the vehicle information button until the PRESS TO CALIBRATE COMPASS screen is displayed.
  4. Press the set/reset button to start the compass calibration.
  5. The DIC will display CALIBRATING: DRIVE IN CIRCLES. Drive the vehicle in circles at less than 8 km/h (5 mph) to complete the calibration. The DIC will display CALIBRATION COMPLETE when the calibration is complete.
Oct 02, 2016 | 2007 Chevrolet Impala
Problem with the HP LaserJet 4730mfp All-In-One Printer Unable to use ADF. Red light under start button.
Do the calibration for the scanner.
1. Place letter- or A4-size paper in tray 1, and adjust the side guides.
2. On the control-panel Home screen, scroll to and touch Administration.
3. Touch Troubleshooting.
4. Touch Calibrate Scanner.
5. Touch Calibrate to print the first pass of the calibration target(Print out).
6. Place the first pass of the calibration target face-down in tray 1 so that the arrows are facing into the MFP.
7. Touch Start to print the second pass.
8. Place the calibration target face-up into the ADF, and adjust the side guides.
9. After the calibration target has passed through the ADF once, reposition it face down in the ADF and touch Start.
10. Place the calibration target face-down on the scanner glass, touch Start, and scan the page.
After this pass, the calibration is complete.
Calibration will fails if print quality is not good...ensure that print quality must be in order..
Once calibration successfully done, restart printer several times & verify start button light, if its green every time 'u' re success. if not cleaning required for CCD which is major work & not suggestable..
Aug 30, 2011 | HP LaserJet 4730mfp All-In-One Printer
I am printing the supplies print page but that print alinment was shifted
Calibrates the printer again and again to align
Calibrating the printer using HP Toolbox
Use the following steps to calibrate the printer using HP Toolbox.
1 Open the HP Toolbox.
2 On the Troubleshooting tab, click Calibrate now.
Calibrating the printer at the control panel
Use the following steps to calibrate the printer using the printer control panel.
1 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select SYSTEM SETUP and then press (SELECT).
2 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select PRINT QUALITY and then press (SELECT). CALIBRATE COLOR will display on the control panel.
3 Press (SELECT).
4 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select CALIBRATE NOW and then
press (SELECT).
5 Press (SELECT) to start the calibration.
Aug 19, 2011 | HP Color LaserJet 2600n Printer
Printer colour alignment out. How do it align this?
CALIBRATE THE PRINTER
Use the menus
1. Press OK to open the menus.
2. Press the Left arrow ( ) or Right arrow ( ) button to navigate through the listings.
3. Press OK to select the appropriate option. An asterisk (*) appears next to the active selection.
4. Press the Back arrow ( ) button to scroll back through the submenus.
5. Press X to exit the menu without saving any changes.
Color Calibration
? Power On Calibration. Specify whether the product should calibrate when you turn it on.
? Calibration Timing. Specify how frequently the product should calibrate.
? Calibration Mode. Specify the type of calibration the product should use.
? Normal
? Full (slower)
Full calibration improves the color accuracy of photos printed on 100 x 150 mm (4 x 6 in)
HP Color Laser Photo Paper.
? Calibrate Now. Set the product to calibrate immediately.
NOTE: You must click Apply before your changes take effect.
Jul 18, 2011 | HP LaserJet CP1515n Printer
I have a hp cp4005dn on a network. The prints have color repeating dotts . I have change the toner cartidges and transfer belt. I still have issues.
Calibrate the printer after replacing the ETB.
Full Calibrate Now
Use the following procedure to calibrate the printer whenever you replace the DC controller, the ETB,
the drum drive motors, the drum drive gears, or a laser/scanner. Full Calibrate Now includes theQuick Calibrate routines and adds Drum Phase Calibration and Color Plane Registration. Full
Calibrate lasts for about four minutes.
1. Press Menu to enter the MENUS.
2. Press to highlight CONFIGURE DEVICE.
3. Press to select CONFIGURE DEVICE.
4. Press to highlight PRINT QUALITY.
5. Press to select PRINT QUALITY.
6. Press to highlight FULL CALIBRATE NOW.
7. Press to select FULL CALIBRATE NOW. Wait for the printer to calibrate.
Jul 15, 2011 | HP Color LaserJet CP4005dn Network Printer
When calibrating, it onlt feeds a couple labels
Use the Menu system to calibrate, follow the instructions and it should calibrate with New settings. Calibration by setting it to calibrate on head close or bootup only loads factory settings.
May 03, 2010 | Zebra 170XiIIIPlus Thermal Label Printer
Upper body workout arms on Startrac 6230 crosstrainer are locked in the ''None'' position. How do I switch to ''Pushing'' or ''Pulling''?
You May have to recalibrate Here is the procedure
Engaging Maintenance Mode 1. Press and hold the , and keys together. 2. A beep will sound and the “MAINTENANCE MODE” will display momentarily in the information window. 3. Release all keys. “SERIAL NO XXXXX” will display in the information window.
Modifying the Maintenance Mode The following keys are used to modify Maintenance Settings: Upper and Lower Data Information Window SCROLL keys: Display the next and previous settings. Increase and Decrease Level Keys: Adjust the value of the displayed setting up and down respectively, in increments of 1 unit. OK Key: Updates (saves) the value of the display setting in the Flash
Diagnostics - UB Calibration UB (Upper Body) Calibration (Elite Only) The UB Calibration will set the minimum and maximum range of the upper body arms in which they can move within. You can do a Manual Calibration or an Auto Calibration. Auto Calibration is recommended. To calibrate the Upper Body: 1. Enter the Maintenance Mode (see Settings – Maintenance Mode). 2. Press until UB Calibration is displayed in the information window. 3. Press to enter UB Calibration Mode. Manual Calibration 1. For Manual Calibration press 1. 2. Press the until the upper body arms stop moving (None Position), and then press to save. 3. Press the until the upper body actuator stops, and then press the to save. Auto Calibration For Auto Calibration press 2. The display will automatically raise the arms up, then bring them back down to calibrate the positions.
Mar 15, 2010 | Startrac Fitness Products Exercise &...
Calibrate LTD 29Cobra classic
The misconception is that you can calibrate a radio. You do not calibrate the radio. You tune the antenna. The calibrate knob on the radio is to calibrate the meter in it so you can check the SWR.
This article will tell you everything you need to know.
Nov 04, 2009 | Cobra 29 LTD CB Radio
China mobile
have a china made handheld double sim touch-screen phone. The device is Winkoy T6688. The touch screen got damaged and after reseting the device, the following notice appears after turning it on:
"Calibration wizard. You have to calibrate the touch-screen. Click anywhwere on the screen with your stylus to start calibration".
Of course you can´t but there´s no other option because it won´t accept any other input until it´s calibrated apparently. Does anyone know how to bypass this calibration wizard on start up?
Sep 10, 2008 | Nokia 6300 Cellular Phone
NO CALIBRATION SHEET
Hello, you can print a calibration sheet from the front panel of the printer. Hit menu on the panel of the printer and scroll down to calibration printer and hit ok. Then hit ok on print calibration page and it should proceed to print a calibration page. After it is done printing, it will tell you to scan the calibration sheet.
Feb 10, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Facebook Apps Logo
Top Facebook Apps Experts
David Payne
David Payne
Bill Boyd
Are you a Facebook App Expert? Answer questions, earn points and help others
