Question about Haier HLP23E Top Load Washer
Haier Condenser gives an error: F9.
Manual states: F9: The thermal sensor(near the heater) is open-circuited or short-circuited. Please contact the service center. If I knew where that sensor was located, I could fix that myself.
  • 41 Answers
Most of these machines have the sensor fitted either on the heater or just close to it remember the sensor is not very big and they are quite reliable check the heater hope this helps
Posted on May 11, 2014
2 Suggested Answers
  • 43 Answers
SOURCE: Haier washing machine E2 error
normally pump filter is the best place to start it could be jamed with a coin or hair clip if you take machine outside and empty it then lay it on its side you can access the pump take it off then stand up the machine and pour hot water into the soap draw check water should run out of bottom freely taking any fluff or bits with it now take apart the pump and clean it all out dry all components before reasembly if the machine still doesent wory could need a new pump
Posted on Nov 11, 2008
ERROR COMING OUT F9
Hi Navin, The link below is a Air conditioner error codes manual, Good luck and CHEERS..
F9 light
discharge temp. sensor of compressor fault
1? Check whether the resistance of sensor is normal, otherwise replace it.
2?Check whether the sensor wire is short circuit or open circuit, and whether the plug is well contacted, whether there is welding off or rosin joint on the electric control 9 board, repair it if there is any above.
3?When the 1 and 2 are both normal, then the components or integrated circuit is damaged, the electric control board should be replaced.
http://www.chigo.bg/resources/pdf/Failure-code-manual.pdf
Apr 14, 2016 | Heating & Cooling
Malfunction
Error 1 is a defect in the steam heating unit.
Possible solutions:
Thermal sensor is defective -replace.
Cable to the thermal is broken or contact pins are corroded - replace, repair.
Heating or thermal cut-out are defective - measure and replace parts if required.
Triac on the power board is defective. The heater heats up triggering the overtemperature protection - Replace the overtempereature protection (thermal cut out) and the power board or the single triac.
Oct 08, 2013 | Jura Capresso Impressa F9 Espresso Machine
My canon IR 3100 CN displays an error code E000004-0001 plaese help me solve
E004
The main thermistor (TH1) has an open circuit or has poor contact. The sub thermistor (TH2) has an open circuit or
has poor contact. The thermal switch (TGP1) has an open circuit. The main heater (H1)/sub heater (H2) has an open
circuit. The AC driver PCB is faulty. The DC controller PCB is faulty.
E004 0001 protection circuit error of the fixing unit
Description: A short-circuit is detected in the triac (for 1 sec or more continuously) while the heater remains off (hardware detection) for 40 msec continuously.
Remedy: Turn off and then on the main power supply.
Remarks: fixing assembly triac malfunction/13V power supply error
Feb 04, 2011 | Canon imageRUNNER C3200 Color Printer
Kemore Mod# 911 4298814 Ser# 9762371 it is giving me a code F1 what is the proplem&
911= Roper stove made by whirlpool
F0 Defective ERC Replace ERC (ERC electronic range control; that expensive stove electronic control)
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
Jan 24, 2011 | Kenmore Ovens
Check engin light on. There are four error codes P0137,P0141,P0342, and P1792. How do I fix it. Will I pass inspection with these codes?
P0137 Error code Faulty O2 sensor Exhaust leak near the rear sensor
  • Plugged catalyst
  • Short to voltage on O2 signal circuit
  • High resistance or open on O2 signal circuit
Possible Solutions
  • Replace faulty sensor
  • Repair exhaust leak near the rear sensor
  • Check for restriction in catalyst and replace as necessary
  • Repair short, open, or high resistance on o2 signal circuit
P0141 Error code means Downstr Heated Oxygen Sensor Heater circuit fault - Bank No. 1.
- replacement is needed for this issue.
P0342 Error code means Camshaft Position Sensor Circuit Low Input
P1792 Error code means P1792 means the computer isnt properly programmed so if this code keeps comming back the pcm may need to be replaced
Aug 13, 2010 | 2002 Daewoo Lanos
When spin .computer box error ''f9''
Depending on the machine
F9: MOTOR FAULTS - the common cause of this is just worn out motor brushes. The other causes of an F9 error are TACHOMETER short or open circuit, motor short or open circuit, or motor jammed.
Feb 24, 2010 | Washing Machines
My roper range model 2496XOA is beeping a F1Code. Not sure how to fix.
Generic stove manual
Feb 15, 2010 | Kitchen Ranges
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F7 Shorted Touch Panel Replace Glass Panel
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
Dec 18, 2009 | Ovens
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Samsung scx4216
Open heat error, you have a fuser problem, replace fuser. Fuser consists of Upperheat roller, lower heat roller, exit claws/rollers, and a heating circuit with a lamp, thermal temp sensor (thermistor) and a thermal fuse/cutout.
You could measuring fuser removed from machine, checking lamp etc for open circuit, thermistor should be neither short or open circuit.
These days we dont, we just change assembly due to it being a common constantly wearing part, and if for example I pull it apart, fix the lamp, put it together then soon enough I will need to pull it apart again to fix worn roller etc.
I could give you the part number ... JC81-01690A but dont use it, cause that part is for 220volt cause thats what we use in Oz, so contact Samsung and ask for dealer in your country who can supply you.
P.S. Fuser is the Hot bit (180 deg c) at back near paper exit that bonds(melts) the print into the paper.
Nov 14, 2007 | Samsung SCX-4216F All-In-One Laser Printer
Haier HLP23E Top Load Washer Logo
62 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
shaun taylor
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
