Question about HP Office Equipment & Supplies
I have a HP Photosmart C7280 all in one printer i bought it in the UK then took it to Australia with me and had to change the ink to the OZ one now i need to put it back so i can buy ink in the UK aga
Need to buy ink in the UK but printer is ste for ink from Australia. The Printer was originally bought in the UK.
nalin_elliot
  • 224 Answers
SOURCE: My HP Photosmart C7280 does not recognise refilled cartridge.
Yes that is because when you get a cartridge refilled then what may have happened is when you gave a print command some of the ink may have splattered onto the ink spraying sensors(usually happens with refilled cartridges on any printer).Its because of the heat generated with which the ink nozzles cannot handle as the ink that is sprayed from refilled cartridges is a little more than regular original ink cartridges.Dip a cotton swab in water wipe the copper contacts on the cartridge.Then wipe around the place where the cartridges sit and also wipe the carriage rod which is inside the printer (metal rod)along which ur spraying mechanism(carriage) moves. If this does not resolve your issue call in to hp at 1800-474-6836 and you can purchase original cartridges that are just for 11 dollars each.........or you can purchase a combination pack which will be cheaper
Posted on Jun 16, 2009
hsanfor
  • 71 Answers
SOURCE: HP photosmart c7280 printing photos with purple hue
Does the c7280 use seperate Magenta and PhotoMagenta cartridges? If so make certain the right cartridge is in the correct slot.
Posted on Jun 20, 2009
  • 1684 Answers
SOURCE: Ink System Failure: Errow:Oxc18a001 with a HP C7280
Check our web site at: www.ccl-la.com/hp.htm We have a step by step guide to correct this problem. This error is caused by air in the ink feed tubes and the guide will help you do a purge on the lines.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Aug 19, 2009
Testimonial: "Thanks a million!!!!. Saved the day. Instructions were on point... Reply was timely. THANKS."
kornho
  • 781 Answers
SOURCE: Run out ink error warning message
are using a refilled cartridge?
if yes, install an actual brand new one.
are you using an official cartridge that you've had laying around for a while?
the cartridges expire so check if your cartridge has expired and replaced accordingly.
Posted on Mar 29, 2010
The pink and magenta cartridges won't print. We have replaced them again thinking the cartridges were faulty, but still we just get yellow print. HP Photosmart C7280 All-in_One
Sounds like you need to run a printhead cleaning cycle. Dried inks can block nozzles - if they're blocked no amount of cartridge changing will make them work.
www.inksave.co.uk
Feb 11, 2011 | HP Photosmart C7180 All-In-One InkJet...
My uk printer photo smart C4180 is not recognising black ink98 and colour95. i cant find any other suitable inks in australia
Buddy you need to contact HP Support. Your printer which you bought and were using in UK is not regionalized for Australia so contact Australia HP Support and get your printer set to that region and then the cartridges will work which you buy in Australia.
Dont worry if your printer is out of warranty,You will get free support because you are facing regionalization.
Don't talk to Level 1 technicians talk either to Supervisors or Level 2 Tech
Jan 04, 2011 | HP Photosmart C4180 All-In-One InkJet...
HP Photosmart C7280 color ink running out despite not using it?
  1. Unplug power cable while the printer is ON.
  2. Press and hold the '#' and '3' buttons, and plug the cable back into the printer.
  3. Continue holding the buttons down for 20 seconds, and then release it.
if doesn't initialize successfully repeat
on step 2 press and hold the '#' and '6' button and plug in the power cable.
May 13, 2010 | HP Photosmart C7280 Printer
HP02 Ink (Expired)
I HP made cars they wouldn't start until you change your dirty motor oil.
May 07, 2010 | HP Photosmart C7280 Printer
HP C7280 All in one. Ink delivery system failure.
check original ink cardrige. And send to the repair store.
Dec 20, 2009 | HP Photosmart C7180 All-In-One InkJet...
0xc05d1281 HP-C7280 Ink System Failed -- tried clearing the error status still same problem, also noise from the print head sounds like plastic gears sliping, print head moves back and forth gears slip and...
printer did not tell about empty cartrigde it just showed that the black was low but not empty -- decided to replace the cartridge early and that ficed the problem!! ?????
Oct 19, 2009 | HP Photosmart C7280 Laser Printer
Error 0xc18a0105 - ink faillure for HP c7280-help
Go to our web site at : www.ccl-la.com/ and click on the printer service section. We have a walk thru that will get you back going. The problem you have is caused by air in the ink feed tubes and the repair guide will show you how to do a feed tube purge.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Sep 23, 2009 | HP Photosmart C7280 Printer
Jun 20, 2009 | HP Photosmart Pro B8350 InkJet Printer
21 people viewed this question
Seeker5211
Seeker5211
