Question about Brother MFC-8860DN Printer
Brother MFC8860dn not answering - Brother MFC-8860DN Printer
Print unable 71
Print Unable 71 means Polygon Mirror Failure on the Brother HL-4040, MFC-9840 and MFC-9440.
Pretty safe to say it means the same thing on the MFC-8880.
The Polygon Mirror is part of the Laser Unit, and its rpm isn't within specs.
The Laser Unit must be replaced.
Jan 08, 2015 | Brother MFC-8880DN Mono Multifunction...
Mfc8860dn
replace the paper feed kit. message comes on after a # of copies.
Jun 06, 2014 | Brother MFC Office Equipment & Supplies
I have 4 faxes in memory and I cannot clear them
Hi there,To clear your fax memory have at the link below. Its the manual for your machine. Have a look on page 45 and 82 here is also a manual if you might need ithttp://www.brother.ca/en/products/pdf/manuals/MFC8860DN-UG.pdf
Hope it helps,
Jul 26, 2011 | Brother MFC-8860DN All-In-One Laser...
Hi i have a mfc8860dn, i want to make it wireless conecting it to my linksys router. what i have to do?
You will need to connect an RJ-45 ethernet cable from the MFC8860DN to the router. Then all you need to do is install the drivers on all the computer you wish to use it with.
Dec 18, 2009 | Brother MFC-8860DN Printer
Brother mfc8860dn what do you mean by sort button
The sort button is one of the 6 buttons on the bottom right side of the control panel within the series of buttons in the COPY controls. When making multiple copies of documents with more than one page, it tells the MFC to sort the multi-page coping jobs into the correct order of the original document rather than the seperate individual pages.
Mar 07, 2009 | Brother MFC-8860DN Printer
Drum Ends Soon
you need to replace the drumkit, or have it replaced.
Oct 24, 2008 | Brother MFC-9440CN Laser Printer
Brother mfc8860dn copier
Open front cover with power ON
press set
read display....
choose change drum and yes/ok
close cover
will reset bias voltage aka light copies, to suit new drum
Jan 11, 2008 | Brother MFC-8860DN All-In-One Laser...
Brother MFC-8860DN Printer Logo
13 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
