I have a sharp ar-336 and it gave an error code E7-11 what shod i do
    Scholar:
  • 130 Answers
Look the error up on google.
Posted on May 11, 2014
jqsababa967
  • 145 Answers
SOURCE: Sharp copier/printer AR-336
do the folowing to access service mode
enter,the folowing keys Program, Interupt,Clear,Interupt
once the service screen is displyed .enter the number 14 than press the enter key
Posted on Nov 29, 2008
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
  • 126 Answers
SOURCE: Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Posted on Feb 01, 2009
SOURCE: sharp ar 5320 error code f2
Dear sir.
I have a sharp copier machine AR-5320 when i switched on it shows U2 .Please help me ;
With beast regards
sayed Masood Osmani
Posted on Mar 10, 2009
  • 990 Answers
SOURCE: sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
Posted on Apr 28, 2009
How to fix a H5-02 code on a Sharp AR-336
input C + interrupt + 0 + interrupt +start +14 +start
Dec 05, 2013 | Sharp AR-C160 Color Copier
Sharp ar 336 copier
remove the fuser unit and clean the thremister, but 1st turn machine off, upon reinstall of fuser enter service mode p*c* and choose 014 to reset the code, if that doesn't work you may need a new fuser
Nov 09, 2013 | Office Equipment & Supplies
Salut je cherche solution par rapport à un code Code H3-01 sharp AR 336
The problem is in your fuser section. You may have a bad thirmistor or heater lamp or the main pcb. Good Luck...
Jan 22, 2010 | Sharp AR-M237 Copier
HAVE A SHARP AR-336 WITH A CODE H3-00 HOW DO I FIX THIS
You can try this it works for older Sharp models.
  1. Press # key
  2. Press * key
  3. Press C key
  4. Press * key
  5. your display will stop flashing H 3, if not re-enter the keys again, some machines are temparmental, when it goes blank
  6. enter 14
  7. press the start key then turn it off and back on, if it comes back with an h code there is a problem with the heat section and will need a service call and probably parts.
  8. good luck
Apr 21, 2009 | Sharp AR-M237 Copier
I have a Sharp AR-336 that's showing me F1-00 error code. What is this and how do I fix it?
F1-00 is a communication error between the copier and the finisher. It could be a loose connection (wire that connects finisher to copier) or it could be worse like a failed board. It could be the finisher board or the PCU board on the copier.
Make sure the finisher cord is firmly connected to the copier.
Make sure the copier is not plugged into the same wall outlet as another piece of equipment that might be drawing excessive power. do not plug into a cheap surge protector with other items.
If problem persists call a tech.
Hope this helps
Apr 13, 2009 | Sharp AR-5316 Advanced Digital Imager...
I have a Sharp AR-336 with an error code of E7-11. How do I turn this error message off?
The E7 can not be "turned off". This error usually indicates a bad laser unit or "shading" problems. You could try cleaning all the glass/mirror components including the white shading strip under the glass - it may help.
Probably need a new laser.
Mar 19, 2009 | Sharp Office Equipment & Supplies
Ar 336 sharp copying machine code F1-05 please help
If you have a finisher on that unit ,that code is upper limit switch problem. Check to make sure your upper tray is in the right position. Otherwise your either your tab is broken or your led is popped.
Jan 02, 2009 | Sharp AR-5316 Advanced Digital Imager...
jasbo
jasbo
