How to reset Pioneer vsx d814 to factory specs
5 Suggested Answers
  • 3422 Answers
SOURCE: Pioneer VSX D814 will not
Your receiver has internal overload protection systems to prevent permanent damage. On SOME Pioneer models, these can be "reset" but you can't do it yourself. Your dealer or authorized service center must do so.
Goodluck..
Posted on Mar 20, 2008
  • 30 Answers
SOURCE: pioneer receiver vsx d814 amp error
The Pioneer VSX-D814 has a couple of Power Hybrid bricks that do all the power amplification. These are the infamous PAC011A. You should have 2 of those in your receiver.
If the amp detects some unusual activities, it may shut down the unit to prevent damage. “Amp Err” usually means some DC in the output.
Disconnect all the speakers and turn on the unit; if it acts normal, reconnect speakers one set at a time very carefully. If the unit still shows the error message you can try to reset it. If the reset works, again carefully reconnect the speakers connections. If the reset does not recover the normal operation of the unit, you may have one of the PAC011A damaged, and the unit will need repair.
The reset can be done by disconnecting the unit power cord for a few minutes, then plug it in and press “FRONT ENTER key + ADVANCED SURROUND key” continuously for 2sec.
Good luck
Posted on Apr 02, 2009
  • 5 Answers
SOURCE: I have a pioneer dvd
LAZA got a haircut .
Posted on Dec 21, 2009
SOURCE: pioneer vsx-d814 will not power on after power surge
I pressed the front Enter and Advanced Surround for 2 seconds on my VSX-D814 and that worked. Thanks.
Posted on Feb 07, 2010
How do you troubleshoot a Pioneer VSX-1023 A/V receiver?
Try to do the factory reset on the Pioneer:
Switch the Pioneer into standby (turn it off).
1. Simultaneously press old the buttons on font panel for 5 seconds - BAND & STANDBY/ON
2. "Reset" on the front panel press
AUTO SURROUND/STREAM DIRECT
3. Then press ALC/STANDARD SURROUND
OR
Simultaneously pressing "down" and "on/off" for 5 seconds to reset the Pioneer
Mar 05, 2015 | Pioneer VSX-1023-K Receiver 7.1 Channels,...
I have the pioneer vsx-d814 with the xxd3069 remote but the remote wont work anything and it has power.Need help
Hello
Get into this link and see the faults that can occur with a remote control. Just check all that suggested. Even after all che checks are found OK ,and your device does not repeond to the remote control, the remote sensor inside the unit must be checked.
http://www.fixya.com/support/r8733688-common_faults_in_infrared_type_remote
Dec 15, 2011 | Pioneer XXD3033 Remote Control
How to reset pioneer vsx-819h
http://audio.manualsonline.com/manuals/mfg/pioneer/vsx819hk.html
It's in the manual. Page 12.
Resetting the Main Unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the BAND button, press and hold the STANDBY/ON button for about two seconds.
3 When you see RESET? appear in the display, press AUTO SURROUND/STREAM DIRECT.
OK? shows in the display.
4 Press STEREO/A.L.C to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory settings.
Sep 08, 2011 | Pioneer VSX-819H-K A/V Receiver
Improper equalizer between VSX-49TXi and LD player,no sound now
You may want to buy the service manual (SM) from Pioneer for this unit. It has a lot of info on resetting and testing the receiver under the "Test Mode". It is highly improbable that you could ruin the firmware by connecting the receiver in an unusual way. You may just need to reset it to factory specs. Another option if you bought it from a local Pioneer dealer is for them to reset. It usually involves getting into the secret menu to do so.
I had one of these for a short while and they are quite nice receiver.
Good luck
Dec 22, 2008 | Pioneer VSX-49TXi Receiver
Pioneer receiver vsx d814 amp error
Good luck
Dec 18, 2008 | Pioneer VSX-D510 Receiver
Pioneer vsx-d814 will not power on after power surge
Mar 21, 2008 | Audio Players & Recorders
Center channel
Just to rule out the easy solutions, have you made sure no settings changed? Make sure that you didn't accidentally turn off any surround sound settings or turn off the center channel in the MCACC setup or the like (I have the VSX-D814, so your receiver should have MCACC as well). If you're sure no settings changed and the center channel should be working according to the receiver, then it would appear that the center channel amp went out in the receiver. You can either get a Pioneer service center to take a look at it, or if you're comfortable with electronics, I believe you can get the parts straight from Pioneer.
Dec 10, 2007 | Pioneer VSX-816-K/S Receiver
201 people viewed this question
 Grubhead
Grubhead
