Why my 2002 cadillac seville wont stay started?
It will start and run for about 5 seconds then stalls out and battery is continuely getting drained
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
You have a short in car
Posted on May 11, 2014
My cadillac saville sts 2002 changed battery wont start now not cranking
This may be related to the antitheft system The system is known for turning off the starter and/or injectors when it fails. Normally when the injectors are turned off, the car will run for a second or two, and then stall. Is there a light on the dash that says SECURITY or a picture of a car with a lock through it? This is a common problem worth looking into. http://www.diy-gm-security.com/
Jun 29, 2016 | 2002 Cadillac Seville
1999 cadillac Seville starts up for a second and dies right away anyone have an opinion on what can be the problem
Sounds like it could be the immobilizer of the security system. With key on, does the security light go off after about 5 seconds? If it stays on, probably the security system.
Another possibility is a weak or failing fuel pump causing low fuel pressure.
Mar 14, 2015 | 1999 Cadillac Seville
Why my 2002 cadillac seville sls wont stay started
If it starts for around 3-5 seconds and then stalls, it is most likely the antitheft security system. The system has been known to regularly fail and cause owners the be stranded by their own vehicle's antitheft system. http://vatspasslockpasskeysecurityhelp.yolasite.com/
May 09, 2014 | Cadillac Cars & Trucks
My 2003 cadillac escalade ext stalled yesterday & wont start. If it does start up it just runs for a second & shuts off. It has power & is deffinately not the battery. It turns over & seems...
This sounds to me like the antitheft security system. If the computer doesn't read the transponder frequency coming from the key, it goes into anti theft and shuts down the starter and/or the injectors. If it starts for 1 to 5 seconds and then shuts down, its probably this. Read up about this on this link, it gives you symptoms and causes, plus a "do it yourself" solution if you decide that this is the problem. I've been dealing in GM vats-passlock-passkey securities for quite a while now. From your description, I'd guess this is the issue. http://vatspasslockpasskeysecurityhelp.yolasite.com/
May 11, 2011 | 2002 Cadillac Escalade Ext
Why is 95 Seville sls stalling and dying while driving?
First question: When was last "healthy" tune up? Plugs, plug wires, ALL filters especially FUEL filter? I'd start there, giving yourself a good base/ "ground zero" starting point. 90% of stalling issues are maintenance related. If it continues after tune up, run a good fuel system cleaner through it, then have a good local parts store IE: Advance, Autozone, etc... do a FREE OBII (fault scan) that will pull all faults computer has logged,
Feb 26, 2011 | 1995 Cadillac Seville
1994 Cadillac Seville is draining the battery. Pulled the modular fuse and Radio fuse and still getting a drain on the battery. Disconnected the altenator and still getting a drain on the battery. What...
Check the cells on the battery, if they are dry or not full of water then they can go bad. That would incorporate the battery to keep dying. When you start the car it feeds off the alternator, and then starts to die.
Check your charging system, test the battery.
Sep 26, 2009 | 2000 Cadillac Seville
1995 Cadillac Seville SLS stalls out
It sounds like it may be time for a new fuel filter, try replacing the fuel filter first. The filter has a life of 30,000 miles or one year, if it has not been changed, good chance that it's the fuel filter. Take not that a dirty fuel filter will make your fuel pump run hotter and will shorten the life of the fuel pump which is the more costly repair of the two. Good luck and keep me posted, Be glad to help you get your car running 100% again.
Aug 04, 2009 | 1995 Cadillac Seville
Won't stay running
sounds like you have a bad ECU unit. have it checked.
Dec 28, 2008 | 2002 Jeep Grand Cherokee
1998 cadallac seville
Hi geofitzpat,
I need a little more info.
Do the switches on the passenger side work?
Are the windows and door locks both inoperative ? How about a electric mirror control?
Did the switch get wet ( as in rained on ) ?
Is everything else OK?, starts good, headlights are bright? Let me know.
Regards, P.
Jul 12, 2008 | 1998 Cadillac Seville
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
