Question about Star 530TD Deep Fryer
Where is tefal fz7000 wiring diagram - Star 530TD Deep Fryer
My tefal iron exploded . Why?
how to exploded? the only way is some chemical inside leak a touch some electrical wires or the thermostat or heating elements. You must report to the supplier manufacturer about this situation. SEE your instru. manual and see the phone, or email, or web .
God bless you
Sep 30, 2012 | Tefal Irons
Need to install a starter on a tractor,have a new one to put oni woulr like a detaited diagram of the instalion
need to install a starter on a tractor,have a new one to put oni woulr like a detaited diagram of the instalion; tefal actifry manual replacing the element tefal actifry ..
Sep 17, 2011 | Computers & Internet
Tefal clothes iron model "Superglide
sparking can be cause by lightning/spikes and broken wires/ wrong voltage.
if u use it in usa at 100v, the current is doubled and will melt the cables.
so:
please discontinue to use it. its not worth your life.
Sep 12, 2011 | Tefal Irons
BROKEN LID ON ACTIFRYER, MODEL FZ7000 15
Hi there.
You will be able to locate the nearest authorized parts dealer in your area when you visit
http://www.t-falusa.com
Regards.
Dec 06, 2010 | Tefal ActiFry Deep Fryer
Iam attempting to fit a new dual cord to my steam generator model 2935 and I have misplaced my drawing of the connections to the iron. Is it possible to get the wiring diagram for the electrical...
The Dual Kilowatt Switch MUST be set to the proper kilowatt rating in accordance and Connect incoming power to floating black pigtail leads labeled "L1" and "L2. keep updated,
Dec 24, 2009 | Tefal Irons
Replacing the on/off switch with a new one
i think the red ones are power in and power out and the blue one is ground get a test light and find out witch wire is power then plug it in turn switch on and test witch leg the power is comeing from and go from there
Aug 17, 2009 | Tefal FR4016002 Deep Fryer
Tefal steam iron not heating up properly
That is probably because the contacts to the element at the base of the iron are broken.
To disassemble you have to remove the casing, then remove the steam pump at front top of iron and then undo the safety screw mounted on the front of the base plate.
Apr 22, 2009 | Tefal UltraGlide plus 1656 Iron
I have a 4 slive tefal deluxe toaster which has stopped working
often is the switch as you press down its a steel wire like a pin that snaps i have repaired 2 same problem i soldered a fine steel wire on its easy part to replace but so far i cant buy a replacement switch
Sep 08, 2008 | Tefal Avante Deluxe 4 Slice Toaster
Star 530TD Deep Fryer Logo
Top Star Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Bill Boyd
Dale Morten
Level 1 Expert
Are you a Star Kitchen Appliances - Other Expert? Answer questions, earn points and help others
