Question about Onkyo TX-SV636 Receiver
Error dsp when i switch on my reciever, i heard a klik, its ok, but when i chance between cd or phono, you can see error dsp in the display, and there is no sound, did somebody know how i can solve this problem
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: dsp display on the 5.1 Onkyo receiver
Do you want to turn off the whole display?
There is a 3-way Dimmer on the front panel and the remote controller. The manual doesn't say if it will turn completely OFF.
Posted on Apr 03, 2009
Looking for windows 7 driver for canascan n640p
Download the CanonCraft CS-P 3.8 (if you losse your cd installer) After installing your CanonCraft CS-P 3.8 (the software from your canon scanner)Try this : Open your CanonCraft CS-P 3.8 than go to setting (klik setting button) --> preferences --> loss the ColorGear Color Matching checklist -->klik Change Profile and chose SMPT-C and klik ok. Hope this work (i've try this on win7 and win8 and work well)
Feb 27, 2013 | Canon CanoScan N640P Flatbed Scanner
Cd playing but no audio
check first the RCA chord
Feb 27, 2013 | Cars & Trucks
I have recently purchased a an XLS1000 amplifier. If the speakers (Peavey Hisys 2) are connected and the amplifier then switched on, an error code is displayed (LEDs sequenced in red and displayed the...
It sounds like speakers are loading down internal DSP - contact any Guitar Center and ask one of their techs for sure. Double check your speaker connections also.
Feb 13, 2011 | Crown XLS202 2Channel Amplifier
SETTING CLOCK ON JENSEN PHASE PCD120U
Display Selector (DSP)
This unit can display either the clock time or
radio frequency/CD player functions. Ordinarily,
the radio frequency or CD player track
indication is displayed, but the unit will display
the time when the DSP button (18) is pressed.
The time will display for approximately 5
seconds then return to the radio or CD player
function display. The correct time-of-day can be
set by pressing and holding the DSP button.
Setting the Clock
To set the clock, perform the following steps:
1. Turn the vehicle ignition and radio on.
2. Press and hold the DSP button (18) until
the time display flashes.
3. Within 5 seconds, turn the MULTI/JOG
control (3) clockwise to adjust the minutes
to the desired setting.
4. Turn the MULTI/JOG control counterclockwise
to adjust the hour and the “AM”/
Jan 28, 2010 | Vehicle Parts & Accessories
No sound output
Known problem w/Onkyo. Resolder Q710 transistor on DSP board.
Onkyo is aware of this problem.
Apr 11, 2009 | Onkyo TX-DS575 Receiver
Just bought refirb. Onkyo 805, hooked up front l&r plus sub and getting no sound. I set up am and fm as per manual and connected a cd changer thru the cd in via rca cables. Radio shows a signal but no...
After few sec when you turn on your receiver did you hear a click noise ? if yes your receiver is OK not in protection mode if no click noise is output protection in that case you must return where did you buy for service and update firmware a lot of update
However you can reset your receiver and debug the DSP section ( digital signal processor ) as follow
To reset
1. Press and hold down VCR/DVR button, then press STANDBY/ON button when the unit is Power on.
2. After " Clear " is displayed, the preset memory and each mode stored in the memory are initialized and will
return to the factory settings, and turn to Standby mode.
Now turn back on and check if it work or not and make sure check input mode such as analog or coaxial or optical input if stil no sound then debug DSP as follow
To set in DSP debug mode
1. Press and hold down DISPLAY button, then press STANDBY/ON button while the unit is powered ON.
The version number of m icroprocessor is displayed only for 3 seconds.
Main:
8 1.05/07903A
2. Press TONE+ button within 3 seconds above, the version number of 1st DSP is displayed.
DSP 1st:
SR8051:07601A
3. Press DISPLAY button while the 1st DSP version is displayed. The status of DSP and DIR will be displayed.
E1A48K0N/0FFPo
FFFFFF0 0 000
To exit
Press STANDBY/ON button.
Then unplug the unit for 30 sec then plug in it should work now if not you need to return it to 1 of the service center Onkyo in your town to repair it
Good luck
Nov 30, 2008 | Onkyo Audio Players & Recorders
Program error
what system is this?
does the Program error apear when you press a button?
if it does, then the keys need to be reprogrammed.
let me know and I will help you with the rest.
Jul 20, 2008 | Executone IDS 82200 Corded Phone
How do I connect a reciever to Gemini pmx-2500
look for pre out on your gemini hook up phono cables to these then to any input on your reciever,eg cd, switch reciever to cd turn up and away you go
Jun 20, 2008 | Gemini Audio Players & Recorders
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
