What are the identification numbers of the output ICs?
  • Audio Player... Master
  • 5,391 Answers
You will have to post the make and model number of the Audio system before any expert can tell you that.
Posted on May 12, 2014
How can I find the part number to order a Vertical Output IC for a Sansui Model tvs2746a
The vertical output IC will have a number printed on it. You mus send this number to get a new one. Normally, all vertical ICs are available from local electronic spare part selling shops. It is not a difficult to get component. Won't cost more too.
May 21, 2012 | Sansui Televison & Video
Oh, I cannot turn it on! Are you the Panasonic Factory Service person? Thanks, tplife69@yahoo.com
Most common cause of no high voltage is bad high voltage capaitor 2k feeds hori output and
Bad STK ICs,they will be Big Black ICs and will have Part number on them example STK392-110
Mats Electronics has Parts 1-800-628-1118
Jun 27, 2011 | Panasonic PT-53TW53 53" Rear Projection...
The set went off and will not turn on the led blinks 15 times then 11 times when pushing the power butten
First check the Hori output Transistor,then small blue capacitor 2k see if it has a burt hole in it, if they are OK the replace Both STK ICs they are big black ICs and will have Part number on them STK392-110 Mats sales ICs 1-800-628-1118
Jun 07, 2011 | Sony Grand WEGA KDP-65WS550 65" Rear...
Convergence is bad on left side...good on right.....where convergence is good the picture is great
Re-solder convergence output ICs pins and nearby big resistors that might solve your tv picture problem and if that does not help then replace both convergence output ICs to fix the problem.
Convergence output ICs would be available in local repair parts shop or google it.
Thanks.
Feb 25, 2011 | Sony KP-65WV700 65" Rear Projection HDTV
Separated picture, one bright pink, the other bright lime green. The top and bottom of picture is distorted. The center of the picture is the best in all respects.
Please replace convergence output chips in tv to solve this issue, tv has two big black ICs at right side and number is STK392-110, replace both ICs to fix picture problem
Thanks.
Jan 25, 2011 | Hitachi 65SWX20B 65" Rear Projection...
On the screen there is a green shadow on one side and a red shadow on the other side of every object in the scene
This tv has two big black ICs as convergence output on deflection circuit board that are defective and causing problem in tv, IC number is STK392-110
replace both ICs to solve tv problem, also chekc for faded color big resistor nearby these ICs or those got burn mark, replace these resistors with same value, aslo check cold/ dry solder joints in deflection circuit board and resolder these joint/ connections.
Thanks.
Jan 21, 2011 | Hitachi 65TWX20B 65" Rear Projection...
Our Sony TV has just started not coming on...it will click like it's coming on then won't. The red light will blink on it a few times then nothing.
Dec 27, 2010 | Sony Grand WEGA KDP-65WS550 65" Rear...
Have three different color images (red,blue,green)
It is symptom of convergence output ICs failure, replace convergence output ICs located on D board to fix this problem.
Call local tv repairman to replace defective ICs if you do not have prior experience of electronics stuff repair.
Thanks.
Dec 15, 2010 | Sony KP-51WS500 51" Rear Projection...
I have a panasonic PT-47wxc43 projection tv. I have green and purple halos coming up from the bottom. The screen has purple and green double images which are worse from the bottom up.
This problem is due to convergence output ICs failure and both chips will be replaced to fix the issue.
There are two big black ICs installed with aluminum heat sink on deflection board, these are convergence output ICs and will be replaced to correct the problem, it is common problem of rear projection tv.
Below image of deflection shows ICs (marked in red) that are need to be replaced.
IC number is STK392-110 and available with Part Store for $32 each.
Click above link to see an image of IC.
If you are handy with electronics stuff repair and can replace parts in tv circuit board then can replace these parts yourself or ask local tech to help you.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
May 25, 2010 | Panasonic PT-47WXC43 47" Rear Projection...
Power light is blinking...will not turn on shop said it was a $3 switch..then it turned into a $400 repair
First CK your hori output Transistor and a small blue high voltage capacitor 2k teh if they are OK it will be Your STK ICs they are big black ICs will have part number on them example STK392-110 replace Both of them if 110s use 150s ICs are $10.00-$15.00 Call Mats Electronics 1-800-628-1118 you will also need heat silicon compound to put on Back of New ICs !
Dec 10, 2009 | Toshiba 50H81 50" Rear Projection...
 Grubhead
Grubhead
