Logik log32lw782 I can't seem to scale my pc screen when it's connected by hdmi. Does it have a pc socket or a scaling setting that would work?
    Problem Solver:
  • 3 Answers
Go to settings resolution and try to play with it. See which is the best fit for your screen.
Posted on May 10, 2014
4 Suggested Answers
acoi
  • 22 Answers
SOURCE: CGA5722 - Boxed in "A
can you a little bit describe what other device that you are using. maybe access point. Are you using an access point?, or switch?
Posted on Feb 17, 2008
flexion1
  • 737 Answers
SOURCE: Casio TK-3200
Hi. IPLs can be tricky. Why do you need to load a new IPL? Is your scale one that is supported by the register? I would need to know everything you have tried. Also, don't forget, you must flag clear when you change any I/O settings, or they will not take effect.
Mark
Posted on Jun 23, 2008
SOURCE: I have a Avery Berkel
this means the loadcell (weight sensor) is damages and needs replacing,this is best done by an avery dealer as you ned to know how to set up the calibration and trade approval,bob
Posted on Mar 22, 2011
I cannot change my Visio resolution from 720 to 1080
If it is a 1080p TV, then the TV always displays at 1080p. The source device and/or the TV will scale and frame convert the image to match the TV resolution and frame rate. When you power an HDMI device, it reads the TV's supported resolutions and audio formats over the HDMI cable, then it chooses whether or not to scale the image for the TV. The television then receives the signal and performs whatever image processing is needed to match the display needs. With many Source devices, you can use a setup menu to configure whether video should always be scaled up to 1080p. Some people prefer the image scaling of the television. However, if the Source does not upscale, it will limit the resolution of on-screen graphics, such as the program guide. So you'll probably prefer to scale your source devices to 1080p through their menus.
Mar 21, 2017 | Visio Computers & Internet
How to change kgs to lb
There's a small "unit" button on the bottom/back of the scale. Press this until it goes back to lbs. It should cycle between kg, stones, and lbs. If that doesn't seem to be working, press and hold for 4 seconds or more. The screen will flash "reset" and it will have gone back to default, factory settings.
Mar 23, 2014 | Ozeri Scale. Touch Digital Bath Scale in...
Wont retain audio settings
Try just using the optical cable alone. connecting the HDMI and the optical cables at the same time might be confusing the TV.
Mar 27, 2017 | LG 42LC2D 42 in. LCD HDTV
Where can I get a manual for a logik TV model LOG26LW782
The link in post one has a LOG32LW782 listed this is the same TV with a larger screen and the instructions are the same
Dec 12, 2011 | Televison & Video
I have hooked up my br to an onkyo home theater through hdmi. i now get an unusable signal on my flat screen. This also happens when I hook it up directly to the tv. What can I do to get this to work
hi,
The Blu-ray player outputs full HD VIDEO (1080p) through HDMI, if your tv is not a full HD one then you can't see the video. Do one thing connect the Blu-ray player to any full HD tv and go to it video setting. Down scale the video to 1080i. All HD ready tvs supports only resolution up to 1080i. only full HD tvs supports 1080p. Down scale the video to 1080i surely you will get video. Also check the version of HDMI cable you have used. It should be 1.2 or above.
ok
Feb 15, 2011 | Sony BDPS570 Bluray 3D Player
Changed HDMI settings and can't now see image on screen
I did the same thing, if you hold the hdmi select button on the player (not the remote) while ejecting and inserting a dvd, it will reset so you are able to access the setup menu again.
Feb 08, 2009 | Toshiba SD-4700 DVD Player
Dymo stamps doesn't see USB Dymo scale
You might try connecting the USB cable directly to one of the computer's USB ports.  My scale (DigiWeigh) showed as not connected when it was connected to a USB hub.  When it is connected directly to the computer, it shows the scale as connected.  Unfortunately, it still won't transfer weights to the Dymo Stamps software.
Dec 11, 2008 | Dymo DateMark Date/Time Stamper
New Logik TV Standbymode
If you're relying on cheap cables - like the ones that are usually tossed in with electronics - you could be running into a signal issue because they aren't shielded and they lose alot of signal due to leakage.
You don't have to overpay for Monster cables, mind you, but cables that are shielded - in gold is even better - should help improve your signal.
J. DeRuvo
[url=http://www.digitaladvisor.com]Digital Advisor[/url]
Nov 30, 2007 | Televison & Video
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
