Question about Dell Vostro 1015 Laptop
Subaru 2002 key problems - Dell Vostro 1015 Laptop
CRASHED MY 2002 SUBARU OUTBACK AIR BAGS DEPLOYED AND AM TRY TO GET ENGINE TO TURN OVER, NO POWER TO CAR EXCEPT FOR KEY IN IGNITION NOISE
Hi i believe these have a type of immobilizer that deploys when airbags go off for safety that maybe your prob and will need reset at a dealer
Mar 20, 2011 | 2002 Subaru Outback
Subaru impreza 2002,will not start. The light for
needs a good battery to turn over and start up check bat leads,clean,tight,is bat okay
Jul 05, 2010 | 2002 Subaru Impreza
2002 Subaru Impreza Sport Wagon electrical - door locks
Make SURE your door key, outside in the door... is straight up and down. The security system is protecting the car, it thinks the doors need to be locked. This is sometimes caused by the keyhole not being verticle.
Apr 07, 2010 | 2002 Subaru Impreza
2002 Subaru Forester - door ajar light is always on even with all doors closed & ignition key off
This is bound to be a courtesy light switch on one of your doors. Check all the switches to see if they have been damaged. You may have to remove the rubber protection boot to do this. Once you find and replace the faulty switch, all should be well again.
Mar 23, 2010 | 2002 Subaru Forester
My 2002 subaru wrx temp goes up a then dwn to
Replace your thermostat...Thats usually the problem when this occurs....Goodluck...
Mar 02, 2010 | 2002 Subaru Impreza
Subaru 2002 outback occasionally will not start(when car is cold-mornings only) I usually get a single click, thats it. I will then turn the key on and off a max of ten times and it will engauge and start?...
have battery check out it should be 12.5 volts if not its too weak need to replace. make your alternator is charging battery. it should be 13.5 to 14.5volts with engine running.if not alternator faulty. but make sure battery cables is tight and clean free from corrossion.turn off radio before disconnecting battery cables to keep from losing radio code.
Nov 25, 2009 | 2002 Subaru Outback
I lost the only key for my subaru outback. how can i get a new one
Go to the subaru dealer bring proof of ownership and vin number they can make you a new one. probably will cost about 100 dollars.
Nov 02, 2009 | 2002 Subaru Outback
Subaru won't start
You've got to assume that the trans oil change is unrelated. With the key in the run position see if the wipers work, if not the battery is dead. Otherwise, try rocking the car back and forth while in park and then hope for a miracle. If all fails, get out the volt meter and start measuring voltages at the starter and the power pack (coil).
Jul 09, 2009 | 2002 Subaru Outback
Dell Vostro 1015 Laptop Logo
13 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
