Question about Dell Inspiron 1501 Notebook
Why does vodacom dongle shows device enabled with tick on other pcs, but not on my acer
Vodacom 3G card dongle not accessing the internet after installing the drivers
Restart the laptop, and see if it still doesnt work, then check device compatibility with your OS, if even then it still doesnt wok it probably needs a software update, even then if it doesnt work you should call up customer service and have them take a look
Dec 08, 2014 | Internet Computers & Internet
The built in speakers is not working and the volume is not on mute
Go to your control panel, click on "Hardware and Sound" and among the selections, choose "Manage Audio Devices" once you click it, a little window should pop up and would show the sound device on your computer usually the default is "Speakers/Headphones". It should show you a "check" on the device meaning it is enabled so that you should be able to hear sounds on your computer. if it doesnt show you a tick mark (usually) or if it shows you in "red color" it might be disabled and thats the reason why you dont hear anything on ur pc. if that's the case, simply "right click" the device and it will give you option to "enable" it. Choose enable,and make sure to click "OK" otherwise it wont take effect. try playing any audio on your pc again. If it did not resolve your issue, then maybe it must be some sound card issue which is another story.try doing this one first.
Aug 23, 2011 | Acer Audio Players & Recorders
Cant get the pulsar 590 works with windows 7
I finally solved this problem. Buy a CSR v4.0 enabled bluetooth dongle on ebay, plug it in to a usb slot. Right click the bluetooth icon in system tray and select "Settings" and tick "Allow bluetooth devices to find this computer." Then click "add a device", turn on your bluetooth headphones and the headphones will show up in bluetooth devices. Add the device, then right click your speaker icon in the system tray, select playback devices. From the menu, select the headphones and set them as default. I did this and they work perfectly. Furthermore when I turn the headphones off, the sound goes back to normal speakers - no other adjustments made. Turn the headphones on again and the sound defaults to them. I noticed on an earlier failed install of the headphones when they did appear in Devices and Printers that the drivers were CSR something enabled. I did try some cheaper dongles and the actual Plantronics USB dongle(expensive) to no avail. Get a CSR 4.0 enabled device. Mine cost 6.00AU total.a199a342-df05-4c7a-89f7-c82a948f31c9.jpg
Feb 21, 2011 | Plantronics Pulsar 590A Wireless Headset
Does my E627 have a built in mic.CHEERS Ron
I had the same problem and received the following from eMachines support:
We would suggest you to please follow the steps mentioned below to resolve the issue :
1. Open control panel
2. Open the Sound in control panel
3. Go to the Recording tab
4. Right click anywhere in the blank white area of the window to display the show disabled devices context menu
5. Click on "Show disabled devices" (See below)
6. Once your microphone is visible, right click on it and be if not already ticked, click on "Enable" - this should get your microphone working.
The device (microphone) that needs to be enabled is actually called "Stereo Mix". --Ted
Feb 04, 2010 | Acer eMachines 520-2890 Notebook
I have a new ACER LAPTOP which works good a home on a router. I have install a Verizon UM175 usb modem for away from home but I go through the instlation alright and at the last part when I install the...
I am sure you have a WiFi laptop as these days it is the industry standard. Even if you do not have one then all you have to do to install WiFi on your laptop is to buy a WiFi dongle and install it. To install it you must follow the following link.
Installing Devices on PCs and Laptops
Jan 07, 2010 | Acer Aspire 5500 5570-2609 Laptop
When bluetooth switch in acer TM4335 is made on no b/t device is found written on screen,while in device manager it shows device working,but BT is not enabling.
Uninstall it in device manager, and if it asks if you want to delete installed drivers put a tick in the box and carry on with the uninstall.
Now restart your laptop, it will redetect on boot up.
Make sure your bluetooth software is up to date, use Acer support page for this, Don't use any other 3rd party apps.
If that fails then are 2 things left, reinstall windows, if that doesn't sort it then the bluetooth module is faulty and needs replacing, cheap as chips these days.
Thanks
Sep 03, 2009 | Acer TravelMate 4150LCi Notebook
Acer aspire 4730z bluetooth problem
Yes your Machine got WPAN: Bluetooth® 2.0+EDR (Enhanced Data Rate).
If its not working then you need the drivers, you can download them free here
If you problem was solved, Kindly do Rate!
Jul 31, 2009 | Sony MEX-BT2500 CD Player
Vodacom gprs settings for i-mate
If you are with Vodacom, just dial *111# , select “Device Setup” and follow the instructions.
Name APN Username Password Primary DNS
Vodacom internet None None 196.207.40.165
Secondary DNS
196.43.46.190
1. Try leaving out DNS addresses first. DNS servers are usually assigned automatically to your device on connect.
2. If you are using Vodacom and GPRS does not want to work, first call customer support and make sure your sim is activated for the “internet” APN.
Apr 09, 2009 | i-mate SP JAS Cell Phone
Acer Aspire 1650 bluetooth useage
You can use the Bluetooth already in the laptop. You do not need a dongle to do the same. All that you need to do is pair the notebook and your bluetooth enabled device like your cellphone to be able to Transfer files.
Mar 17, 2009 | Computers & Internet
Network Crad Problem ( Re-install)
You can download latest network drivers for acer laptops from acer support site http://global.acer.com/support/download.htm
Dec 09, 2008 | Acer Aspire 5315 Notebook
Dell Inspiron 1501 Notebook Logo
23 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
