Ricoh 5000 machine error code sc460 appears - Office Equipment & Supplies
SOURCE: Ricoh CL2000N Error Code SC230
The manual says this code means " BCU Received no Feedback from LD" I have no idea what that means, but maybe it will help a tech on hear tell you more.
Posted on Jan 24, 2008
SOURCE: Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
Posted on Jun 23, 2008
M2Tech1
  • 313 Answers
SOURCE: error code SC998 on Ricoh Aficio 1045
The error code 998 is usually for the dimm or application boards read errors try taking the memory out and the app board out and reseat them again.. then go into the service mode via yellow clear button and then enter 107 then hold down the stop button till the panel changes and turn off the copier wait for 5 secs then turn back on.. If you dont know where boards are take the back panel off and on the right hand side there is a box with a steel plate on the dimms Ram..and app boards are there.. Good Luck A..
Posted on Jul 30, 2009
santosj27
  • 263 Answers
SOURCE: I have a ricoh 2051
After turn the main switch off and on the error appears again????
This error means that there is a bad comunication between the controller board and the operation panel.
Did you intervew in the machine? Some tecnical intervewing?
Posted on Feb 17, 2011
  • 504 Answers
SOURCE: Ricoh ft 4022 photocopy machine displaying error code E-3.
cleaning requird clean properly with any quality cleaner then rty
Posted on May 17, 2012
My copier machine comes up with functional error code sc672. can anyone help
That error code appears to indicate 'Op panel to controller problem' see here http://multifunctionalcopier.blogspot.co.uk/2012/06/ricoh-error-code-list.html
Sep 05, 2015 | Ricoh Richo KR-5 with 35-70mm f3.5-4.5...
What is error code 460 on a Ricoh Aficio SP C811Dn
SC 460 The problem may just be dirty separation components that a cleaning may resolve. The code refers to the following:
High voltage power: Separation bias output error
The status of the power pack is checked every 20 ms. This SC is issued
if the EGB detects a short in the power pack 10 times at D(ac).
1. Replace the high-voltage supply cable.
2. Replace the high-voltage power supply unit
3. Replace the IOB.
Aug 26, 2014 | Ricoh Aficio Office Equipment & Supplies
I have a ricoh 2051 with this error message: Functional problem within the machine. Turn main power switch off and then on. if the error appears again, then call Here is the error message code: SC...
Feb 17, 2011 | Ricoh Aficio 1035 Copier
How can I reset a SC 547 error on a Ricoh Aficio SPC 811 DN? I've already replaced the fixing unit.
Hi
Error code sc 547 means "Zero cross signal malfunction". This error appears due to a faulty power supply. This error code may also appear if the input board is defective or the BIC Unit is defective. Turn off the printer and unplug the printer for 30-40 minutes and check if the error still appears. If you see he error still appearing then try and rest it using the following reset method--
To reset the SC code by entering SP5810 and select 1.
Now hold down the photo mode key and the # key at the same time for at least 3 second.
Then turn the machine off and on again.
If the same issue still appears, you'll need to check and replace the Power supply or the Input (IOCC) boardt.
Hope it helps...
Oct 11, 2010 | Ricoh Aficio 150 Copier
What does troubleshooting code 326 of ricoh copier 1045 means?
2nd laser synchronization error. F gate 1 error. This is an optics issue. Try unplugging the machine and plugging it back it to see if the error goes away.
Nov 13, 2008 | Ricoh Aficio 1035 Copier
Jan 24, 2008 | Ricoh Aficio CL2000N Laser Printer
Ricoh Fax 3800L Error code
Hi there the error code that you are getting appears to be for the left lock where the fuser is make sure that the door is shut fully and turn the machine off then on again if this doesn't work then it is more likely to be the laser unit and this will need replacing.
Hope this is of some help to you.
Thanks J
Nov 07, 2007 | Ricoh FAX3800L Plain Paper Laser
41 people viewed this question
jasbo
jasbo
