Canon MP550 ScanGear Code 7,202,1 ? - Office Equipment & Supplies
What is error 6C10 on Canon Pixma MP540
This video concerns the MP550 but according to the comments, it worked for someone with a MP540.
Canon MP550 Ink Absorber Reset 6C10 Error Code
Feb 04, 2017 | Canon Office Equipment & Supplies
Code 2,250,200
Re: Error code 2250,2 or 2155,33 on scanner 9000f - Canon ...
community.usa.canon.com/t5/Printer.../Error-code-2...2.../123789
Nov 6, 2014 - Dear all Canon staff, I brought my 2 years ago. And I had not used it for around 1 year. When I used it again, Scangear run out error code 2,...
Sep 05, 2015 | Office Equipment & Supplies
Is There A Way I Can Create A Desktop Shortcut To ScanGear So I Can Previre Then Scan Items Manually
In start menu, programs , look for scangear icon.
Right click, send to, desktop (create shortcut)
or use windows explorer, program files, find scangear folder
Jul 10, 2011 | Canon Office Equipment & Supplies
Canon IR3300 Scanner
1) install Network ScanGear software from canon officiall site, search under ir 3300, and among all drivers there is scangear too.
2) when you install scangear, open it and press discover button, but the light scan on copier must be on, and set on ONLINE.
3) Then over eg. word2003 go to insert-pic.-from scaner or cam.-choose scangear- custom insert.
Jun 14, 2010 | Canon (6981A002AA) for imagerunner 2200,...
How to get ScanGear Software?
www.canon.usa it is part of the original installation CD for your scanner
Jul 06, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon ScanGear CS driver error Code: 2,252,0 - Can't preview Actually I have the Canon CanoScan LiDE 80 Flatbed Scanner - but this wasn't presented as an option, so I thought I'd try the nearest...
Canon ScanGear CS driver error Code: 2,252,0. Error when trying to Preview scan using ScanGear in your program, e.g. Word, PhotoShop...
I had the same problem, Canon Technical were clueless on this error code. Yes the problem occured when trying to preview first however I could scan but without any preview, pointless really.
I have fixed it for Windows Xp SP3, Canon Lide 80. To Fix:
You need to download the latest ScanGear driver and Deldrv.exe from the canon website. You don't need the Toolbox, http://software.canon-europe.com/
It would help if you have Tuneup 2009 (even Trail version) for the later parts of this fix: http://www.tune-up.com/download/ just click download, you don't need to give them your email address.
1. Save these on C:
2. Remove the USB cable from your scanner - make sure it is unplugged.
3. Run Deldrv.exe, select your scanner and uninstall.
4. Now you will need to go into 'C:/WINDOWS/TWAIN_32' folder; you must remove anything in this folder - safest thing to do is CUT any items and paste them on the C: or personal folder.
5. Now the register parts - you need to purge your registry of any left over values. I found out after several attempts that this final step fixed the problem for me.
Basically through Windows XP Regedit or TuneUp Reg Editor search the ENTIRE registry for first 'ScanGear', second, 'Canon' and third if you have installed previously, 'Canon Toolbox'. Find any entries relating to any Canon scanner software and delete them. I only found around 6 or 7 entries to remove.
6. If you have TuneUp run '1-Click maintence' (correct problems) and afterwards run the 'Register defragger'. Restart.
7. On the next bootup your register should be optimised. Ok, disable any Anti-virus software.
8. Run the scangear setup winzip file you saved on C:. * it will extract a folder to C:. If get an error with the extraction, try running it anywhere else except C drive. Alternatively if you have WinRar, right click and manual extract contents. The scangear setup winzip file/folder (called lide80vst7250a_xpen) only contained a readme and setupSG.exe.
9. You must run the setupSG inside this folder. And you're done. Enable your anti-virus.
9. Now connect USB to scanner, Windows should pick it up. Open Word or PhotoShop > run the scangear program to preview.
10. Done! It worked my end.
Please let me know if this helped you.
Mar 14, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
I have no manual and I need to figure out how to scan on this machine. Canon Imagerunner 50001.
Download the network scangear from the canon web site.
Install the scangear on all the computers you want to scan to.
On the scangear tool there is a discover icon,click that icon and wait till the ir 5000 is picked up by the network.Select the machine in the scangear tool.Now you will be able to scan to mirosoft word and exel like you normally do with a scanner.
If the scangear tool was unable to discover the machine,the network settings of the IR must be checked.
Hope this help.
Mar 09, 2009 | Canon imageRUNNER 5000 Copier
About scan
First your copier must have a networkcard installed and link to your network.
Download canon network scangear from the canon website.
Install the scangear.In the scangear tool select discover and your copier will apear in the block,click on the copier and click select.
From Word or Exel you will be able to insert it as a picture by selecting the scanner.
Network scangear link
http://software.canon-europe.com/software/0028070.asp?model
Jan 21, 2009 | Xerox CopyCentre C20 Black and White...
Canon ScanGear Ir - how to set defaults?
ScanGear won't run under Vista. The scanner works with other programs. (Twain works) ScanGear fails and Vista closes it.
Don
quantm@localnet.com
Sep 21, 2007 | Canon imageRUNNER 1023N Black and White...
44 people viewed this question
k24674
jasbo
jasbo
